Question about Sewing Machines
Serger won't stitch
After my left needle broke my machine stopped stitching. I replaced both needles and re- threaded about a million times but still not working!
  • Sewing Machines Master
  • 7,365 Answers
Did you put the needle in the correct way?
some times when the needle breaks it causes the machine to jump time and has to be fixed at a sewing machine repair shop.
Posted on Jul 24, 2013
  • Mitza Nieves Jul 25, 2013
    What exactly does that mean? When the needle broke it sounded pretty bad!
  • there are flat sided needles and the are round needle with a groove . usually with the flat sided needles, the flat side goes to the back of the machine , you have to look in the manual to see how to correctly put the needle in the needle holder, turning the needle the wrong way ,the machine will not sew or serge. since the serger sounded pretty bad it's possible that the serger could have jumped time or caused a part to be damaged or broke a part, only by having the serger checked will you know for sure.
  • 323 Answers
SOURCE: Loose stitching underneath. HOW CAN I FIX!!!!
Sounds as though you may have a burr or rough spot on the hook where the bobbin inserts. Run your finger along the edge of the hook to see if there are any rough spots.I'm sure you're going to find at least one from the time you broke the needle.Once you locate it, remove it with an emery stick or small sharpening stone. Polish it so that it is smooth. Should work okay.
sewman7
Posted on Jun 27, 2008
  • 15 Answers
SOURCE: I have a white superlock 228 jaguar serger problems with right needle
Couple of things I could think of: tension disks need cleaning, there is a site that tells how to clean them, maybe 2 as I recall. Other thing is it is a much older serger, (I have one I am slowly working on to bring up to working level), so it could be that a tension spring internally has lost its tension. It might need a trip to the repair man if that is the case. Another thing is are you using correct needles for the machine? Have you changed them recently? Even new needles can be bad, so if you have to change three times to triple check it can be worth it.
Posted on Sep 09, 2008
SOURCE: White Serger 1934D not stitching
No, Sounds like the loopers are not passing properly to pick up the thread, from off the needles.
Posted on Jan 12, 2009
Zenqi
  • 208 Answers
SOURCE: My brand new Kenmore serger
The loopers must be threaded before the needles.
Make sure that the needles are not threaded. Thread the loopers and have the loose ends behind the presser foot. Then re-thread the needles and place a scrap of fabric under the foot and sew. Make sure that the edge of the fabric is not to the right of the plate, but where it would be if the knife had cut it.
Posted on Jun 17, 2009
SOURCE: Juki DDL-8700--top & bobbin thread won't hold together for stitch
What bobbins do I use on a Juki DDL-8300
Posted on Mar 11, 2011
I am new st this but my serger will stitch but the left needle thread will not join the others why ?
It could be that the serger has an independent left needle. Some older sergers were. Built like this so that a single stitching line with an overcasting stitch beside it. This is so that you can stitch a garment with a single stitching line and an overcast edge beside it instead of having to do two operations.
Oct 10, 2014 | Sewing Machines
I have re-threaded, changed needles, adjusted the differential and cutting width but cannot sew a single seam without the stitches skipping, sometimes several in a row and sometimes only one.
SKIPPED STITCHES ON A SERGER
1. Is the needle bent or worn--replace
2. Is the needle inserted correctly into the needle holder--check needle
3. Is the Serger threaded correctly--rethread
4. Is the presser foot pressure right for the fabric--adjust
5. are the needles the correct ones for the serger
6. Possible timing problem--need to be checked at a sewing machine shop
Sep 18, 2013 | White Sewing Speedylock 1600 Mechanical...
Singer Stylist 11 Serger problems with right need skipping stitches how can I solve the problem
Jan 04, 2013 | Sewing Machines
My needle broke on my serger and i replaced it and now wont make stitch. please help
some times when you break a needle in a sewing machine or
serger it can cause the machine to jump time, it would be a good
idea to have the machine checked for a timing problem or to see
if when the needle broke it caused a problem with another part in
the serger.
Nov 12, 2012 | Sewing Machines
My Juki MO-655 serger will sew a few inches then the needle thread becomes disengaged in the stitch process. The machine will sew a few inches more then stops making stitches. I have cleaned the thre
Make sure you are threading the machine correctly. Make sure you are using serger thread that isn't old. Make sure you are undoing all the threads when it breaks and thread it from the beginning.
Make sure you have the right needles in their respective places. My Juki MO has two different size needles.
Sep 02, 2012 | Juki MO-655 Mechanical Sewing Machine
Serger won't chain off a stitch. Stitches won't chain and hold to fabric. Added new needle, rethreaded whole machine. Stitches won't connect to fabric or make a chain.
is it possible that the needles are in backwards?
it's very possible that the machine is out of time & would have to be taken to a sewing machine repair shop to be retimed
Apr 02, 2012 | Sewing Machines
Which needle do I take out to do a rolled needle
left one, rolled hem is usually a narrow seam so you remove the left needle, change the needle plate or flick a switch that changes the position of the thread finger under the foot and tighten up the looper tensions. You want the top looper thread to go around to underneath and the bottom looper thread to disappear against the needle stitching. You also need to close up the stitching density, by decreasing the stitch length.
Mar 02, 2011 | Baby Lock Eclipse Serger
Problems threading my janome serger
One critical hint:
You must thread the loopers BEFORE the needles, otherwise it won't stitch. Begin with upper looper, lower looper, right needle then left needle.
Jan 16, 2010 | Sewing Machines
Sewing Machines Logo
103 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
