Question about Kitchen Appliances - Others
Hoshizaki km452du Machine will not make ice
refritech08
  • 149 Answers
SOURCE: Hoshizaki Ice Machine Model KM-500MAF
(Quated From Hoshizaki Technical Bulletin)
An alarm code of 3 beeps
every 3 seconds means that the control board has shut
down on the 60 minute freeze cycle back up timer.
The “E” control board has a 60 minute timer that starts at
the beginning of the freeze cycle. If the float switch fails
to open and start the next harvest within 60 minutes, the
board will automatically start the harvest cycle. If this
occurs in two consecutive cycles, the control board will
shut the unit down on the manual reset, freeze cycle
back- up timer. The yellow fault LED marked “60 min.”
will illuminate. This safety is designed to help prevent a
freeze up of the evaporator.
Once you have identified the 60 minute alarm, there are
several things to check. Reset the alarm by depressing
the white reset button to the right of the fault LED’s.
This must be done with the power “ON”. Now check the
float switch to see if it is stuck in the up position. A stuck
float can occur if scale is present on the reed switch
shaft inside the housing. To check it, drain the water
reservoir, unplug the black float switch connector (K5)
from the control board and check it with an ohm meter
for a closed switch (zero ohms). If the float switch is
sticking, clean it with ice machine cleaner or replace it as
necessary.
An inlet water valve which is slowly leaking by during the
freeze cycle can cause a 60 minute alarm. If the inlet
water valve is stuck wide open, it is unlikely that any ice
will form on the evaporator. Check for a slow leak by
allowing the unit to cycle into the freeze cycle and
disconnecting the hose at the outlet of the water valve. If
water leaks by during the freeze cycle, the water valve
diaphragm is likely damaged or the small diaphragm bleed
port is clogged with scale. Clean the bleed port or replace
the diaphragm or entire water valve as necessary.
(I Recommend to get a refrigeration tech for this part).
Another possibility is a refrigeration system problem. You
should use normal refrigeration diagnosis procedures to
check for one of these problems. If the thermostatic
expansion valve is not feeding properly or the refrigerant
charge is low, the evaporator will not form ice as it should
and a long freeze cycle will occur. This could also be the
result of the hot gas valve not closing completely during
the freeze cycle or if the compressor valves are weak or
inefficient. An inefficient compressor however, will
usually show up first on the KM model through a longer
than normal harvest cycle. This is because of cooler
than normal discharge gas. Use proper refrigeration
practices to repair a refrigeration system problem.
While these are not the only reasons for a 60 minute
freeze cycle, they are the most common and should be
checked to resolve a 3 beep/yellow fault LED alarm.
Posted on Apr 26, 2008
SOURCE: Beeping Ice Machine
I have a Hoshizaki KM-250BAF that is making 3 beeps then pauses and them makes 3 beeps again. If I unplug the ice maker and plug it in it continues to make the 3 beeps. The manual does not mention anything about beeps. Can anyone help?
Posted on Aug 29, 2008
projdoc
  • 2237 Answers
SOURCE: Why is my Hoshizaki ice machine evaporator frozen
if the defrost/hot cycle doesn't work, the ice won't fall and eventually freeze everything.
Posted on Dec 03, 2009
Testimonial: "Thanks, I should have indicated that this machine is water-cooled & problem does not develop until bin is full of ice; does your solution still apply?"
  • 1253 Answers
SOURCE: hoshizaki ice machine beep 3
in the freeze cycle too long. Most common is the water valve leaking through. Second thing to check is for a stuck float switch.
Posted on Oct 28, 2010
  • 489 Answers
SOURCE: hoshizaki ice machine repair?
seems that its low on water or float switch is bad. try to clean float
Posted on Oct 09, 2015
Why did my hoshizaki ice machine stopped making ice?
bin stat is what is used to shut machine down. if it goes bad in any way, no power will go to the control board. Start there.
Aug 11, 2014 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki km - 280 mah ice maker not making enough ice
A few simple things to check is the condenser for dust. Blow it out. If their is a water filter going into the unit change it. Get some ice machine cleaner and follow directions. Do these things before calling anyone out.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 12, 2012 | Hoshizaki Freezer Commercial Ice Machines...
How to reset hoshizaki ice machine
small white button on control board. press once to stop beeping. Very small but it is labeled and very hard to see.
Feb 09, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice maker am-50bae . Made ice regularily--- filled ice bin half way...next day-- all ice melted away with no more new ice? next day shut off for 3 hours now o new ice.
make a few quick checks. If there are water filters on the system, be sure they are not restricked. Could be clogged. Next, check the bin stat. It usually is mounted in the ice bin. If it breaks or goes bad, it shuts down the machine. Start there and let me know if I can be of any further help.
May 19, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine: my hoshizaki under the counter ice machine gradual...
Check condenser coil which is the coil on back with fins, sometimes with metal.mesh filter. If dirty or clogged up clean filter, blow out with air or brush and rinse out, careful not to bend fins. Sounds like issue to me. Unless the dump valve may be leaking by
May 18, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki condensor fan motor is not working
Too long to explain sequence here. but in the harvest mode the fan will not be running. go to hoshizaki.com you will find every thing you need very helpful site . and a clean machine is a happy machine. hope that helps Tom
Jun 28, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice machine model KM-250BAF SERVICE MANUAL
km-450mwb hoshizaki problem is machine strate is ok but to long time ice making , not dropping, two beeps every three seconds what problem i don't no pleas help mi
Jul 30, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Kitchen Appliances - Others Logo
22 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
