Question about Honda Gc160laqha 160cc Gc160 Series OHC 4.6 HP Engine With Straigh
97fordf150 cranks no spark
This was replace crank sensor/ cam senor / right coil pack /wire 2 crank senor good cond but its warp with a alum color wire that is wrap in aluim foil paper that look fryed
    New Friend:
  • 3 Answers
Can't get the soap to come out
Posted on Jul 24, 2013
I have a 2005 dodge neon that will crank but wont start. I have replaced the cam shaft sensor, crank sensor and the coil pack. Iam also not getting spark to the coil pack. Any suggestions?
Primary voltage to several systems, including the ignition coil, dark green wire with orange tracer. That voltage comes from asd relay. There is a fuse for asd relay. To check for voltage the engine has to cranking. The control side of asd relay, the computer has to ground it before it will energize. Did you check wiring circuits for cam and crank sensor connectors before replacing sensors? Are there any applicable trouble codes?
Are you ok with testing wiring circuits?
Feb 16, 2017 | 2005 Dodge Neon
97 oldsmobile achieva wont fire changed coil pack spark plugs cam sensor still wont start
Make sure battery has a full charge and battery connections all good.
If it cranks good but won't start, have a helper crank it while you visually check for spark at the spark plugs. If spark everywhere, use a gage and check proper fuel pressure and fuel injector pulse.
If you having a problem with more than one system, I want to check for rpm signal, that usually comes from the crank sensor. Not sure why you replaced cam sensor? I always want to check sensor wiring circuits before replacing anything. Don't replace anything unless your testing points in that direction.
Nov 04, 2016 | Oldsmobile Cars & Trucks
What could cause a1991 suzuki samurai to have no fire from a new coil?
no spark from coil directly?
is the cam turning, is the dizzy rotor spinning. ????
check all fuses first. Ig-coil, FI and dome.
then using diagnostic jumper wire or fuse, (as approp)
crank engine look for code 41 o 42.!!!
USA cars , answers only
our cars are all EFI that year.
no engine swaps to Suzuki G16A/B sidekick or tracker engines.!
1: engine cranks
2: no spark
3: The ECu makes spark
the CMP sensor in the DIzzy , (never fails if rotor turns, does rotor turn, if not cam belt igored and now snapped.)
the cam turns. the CMP fires. the ECU takes this CMP signal
and fires the ignitor next to coil and the coil charges, and release and BAM spark.
that is it.
the ECU will tell you when the CMP dies or the Ignitor fails
why not ask it.
1: key on
2: diagnostic jumper in place (flashes 12s for ok)
3: crank engine,for 5sec, not 1 ,not 2.
3: release key not off.
4: see code 41, or 42, BINGO !@!!!!
Aug 15, 2014 | 1991 Suzuki Samurai
87 oldsmobile toronado not getting any spark
ECM requires both crank sensor signal and cam sensor signal to fire the coils. Check for spark at the plugs first. Check the plug wires, then the coils. Only if you have no spark at any coil would I suspect the ignition module, and even then only if you have a good crank and cam signal. Do you have any codes stored in the ECM? They could help pinpoint the problem.
May 10, 2014 | 1987 Oldsmobile Toronado
It cranks but it won't start. I got a new battery, cam position senor and crank position sensor. took out the ignition control was told that was still good.
Check for spark at the plug wires to spark plugs, no spark on anything, then suspect a fouled job replacing the cam position sensor.
Oct 03, 2011 | 2006 Chevrolet Silverado 1500 2WD
Got a 2001 Chevy blazer 4.3L cranks but does not start. got 62 psi at the fuel rail, replaced plugs and wires, got good spark at coil, replacing car and rotor! if the cam sensor or crank senor are bad...
Crank sensor is primarily for the spark and the cam sensor is for fuel management, crank/cam correlation for misfire purposes I would also change the wires.
Jul 12, 2017 | 2001 Chevrolet Blazer
1995 ford explorer doesn't start, crank & cam sensors replaced
Does you fuel pump delivers fuel. Is it there a spark.
Dec 29, 2009 | 1995 Ford Explorer
2003 chev malibu wont start due to lack of spark from the coil pack, checked the voltage from the ignition and its ok, changed cam sensor, changed the crank sensor, tested the coil pack and the processor...
That car has 2 crank sensors , did you replace both? One is at the front crank pulley and the other is behind and low on the engine block, above oil pan. Be sure the ICM (ign control module has a good ground, (black wire) it grounds at a bracket where the trans bolts to the engine approx at the 2 o'clock position.
Nov 19, 2009 | 2003 Chevrolet Malibu
2002 Jeep Grand Cherokee Lardo misfiring
You say you changed the cam sensor. A1391 code is a crank sensor on the top of the trans. bell housing.
Feb 22, 2009 | 2002 Jeep Grand Cherokee
Honda Gc160laqha 160cc Gc160 Series OHC 4.6 HP Engine With Straigh Logo
32 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
