Question about Yamaha Waverunner Xl 800 / Xlt 1200 Jet Ski Pwc Cover
Wont start battery fuse good
Wrere do i go next fuse good battary has 13 volts . lights on dash will not even come on
  • 22,095 Answers
Corrodes wire and connections somewhere ,but where is the million dollar question here ,and without a play i couldnt even hazard a idea
Posted on Jul 24, 2013
Why wont my 2010 dodge caliber start... no light on dash no power period.. is itjist the battery
It could be the battery it should have 14.5 volts. Or the connection. Clean all battery points
Jul 15, 2015 | Dodge Cars & Trucks
98 chevy prizm completely dead. Need to check fuse but don't know which one
You have to start at the battery. Is it fully charged? It should show at least 12.6 volts to verify a good battery. If it is less than 12 volts, it will not start the engine anyway, so it must be tested and recharged if good, or replaced if bad. Next the positive and negative cables at both ends of them must be clean and tight. By now you should be able to have headlights and other accessories. And the key turned to on should light up all the warning lights and gauges on the dash, and when turned to "start", the engine should be cranking over and then run.
If the car is completely dead, start at the battery. If you still suspect fuses, next check all the maxi fuses- the power distributors right after the battery. Only one of them would cause whole differing circuits to not have power.
Dec 09, 2014 | 1998 Chevrolet Prizm
Battery light comes on and off and computer says service charging system and battery not charging sometimes when I first start the engine its fine but after awhile battery light comes on and battery not...
what you need to do is check the altenator for voltage it should be between 13 and 15 volts this is easily done with a standard volt meter check it at the altenator witch is located right on top of the engine on the back of the altenator there is a thick red wire that is where you want to put the positive and just put the black wire of the volt meter on the case of the altenator and check the reading it sounds like the altenator is bad there is also a fuse you should check your owners manual for location of the fuse also have your battary checked this should help ant questions just ask me
Jan 23, 2014 | Cars & Trucks
71 c10 not staying charged... new battery alternator fuses good and new voltage regulator
Maybe it wasn't running long enough to charge up the battery?
Stop trying to jump it, when you are having problems with it dying, take the battery off and have it charged. And/or buy a $20 voltmeter to see what the battery shows. If it says less than 12 volts, it is discharged, and needs charging. A good battery that is not run down should have at least 12.5 volts. A new battery that is charged should have very close to 13 volts, maybe 12.8 volts.
When you have the truck running, check the alternator for charging. You put the voltmeter right on the battery and check it again. This time, with truck running, battery should show at least 13.5 volts. That shows the alternator is working. A good alternator will put out about 13 or 14 volts-the regulator will keep it from going any higher to prevent problems, like a melting battery or electrical parts burning out.
I would say get the charging system working right, then address the problem of dying at stop lights. That could be a carburetor problem, if the alternator is working.
Aug 15, 2013 | Chevrolet Cars & Trucks
Two weeks ago, when I went to Acura deller for oil change, they sugested me change the battery, since I never got a problem for start, so i did not change the battary. But next day I can not start my car,...
First make sure the terminal and posts are clean and greased.
Then make sure the alternator belt is tight.
The type of battery makes no difference as long as it fits.
What matters is whether or not the alternator is putting out 13.5 volts or higher, in order to keep the battery at 12.5 volts. Put a voltmeter on the battery and rev the engine.
Apr 22, 2010 | 2003 Acura 3.2TL
87 toyota camry new battery wont keep charge, alternator checks okay, in dash bulb for charge and brake and lights stays illuminated?
Generally if charge light is on, alternator has a bad diode in it. This lets the charged battery lose its power by flowing in the reverse direction. It sounds as the alt., is either not connected right or is swtill bad
Jan 18, 2010 | 1995 Toyota Camry
Battery tested no good, replaced it, next day battery wont start car, noticed blown fuse at postive terminal, replaced it, jump started car, working fine ...... Question, will that fuse prevent battery...
the fuse must be 'intact' for electrical system to operate properly.batteries are rated in months as far as longevity is concerned,36 mo. 60 mo. etc. if you have or have access to a volt meter,battery voltage should be 12 volts with engine off,13 to 15 volts w/ engine running indicates alternator is working.
Oct 17, 2009 | 2001 Hyundai Sonata
Alterator is only doing 13 volt and battery light on. battery was hooked up backward and blew the megafzse too. that was changed and started generating, but battery light is on and alterator is only...
look in line fuse follow wire from alt.to bat. and see if there is an inline fuse if not also you can check fusable links they sometimes wont break completly
Aug 15, 2009 | 2002 Mercury Sable
2001 Buick Lesaber No Elect power
Have you tried monitoring the voltage across the battery with a meter while trying to start? You can buy a digital multimeter for <$20 US at electronic stores (such as Radio Shack in the US) or even auto parts stores. If you have a Harbor Freight tool outlet near you, they are even a lot cheaper and you will be glad to have one when situations such as yours occur.
You gave the battery voltage as '.13' VDC so you may already have a meter but I don't think you wanted to write that you have 13 hundredths of a volt, did you?
The nominal voltage of a charged battery is 12.6 volts and normally falls ~ 2 volts when the starter is running.
Fuses: the can have a break in the element that is close to invisible so use a meter to measure each one of the higher amperage fuses for continuity on the Ohms or diode scale to make sure.
Some change in the way batteries are made have made them behave strangely; I have had several batteries that will not charge even with 20+ volts across them. They draw only milliamperes and that is not charging. I suspect they build sulfates more readily than in past designs.
Oct 12, 2008 | 2001 Buick LeSabre
Yamaha Waverunner Xl 800 / Xlt 1200 Jet Ski Pwc Cover Logo
217 people viewed this question
Top Yamaha Boating Experts
Phil Walker
Phil Walker
Colin Stickland
Colin Stickland
Mike
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
