Question about Konica Minolta Bizhub C253 Copier
What is a CFA03 Error on a Konica Milolta C-250 Printer
4 Suggested Answers
Kevin Hayes
  • 167 Answers
SOURCE: Bizhub 250 how to add/delete names
To download your Manual:
help.bt.konicaminolta.ca
Posted on Jun 09, 2008
  • 44 Answers
SOURCE: bizhub 250. error c2152
Check and make sure there are no jams by the fuser ie: bits of paper in the paper path.
Posted on Nov 29, 2009
hamzaskilltd
  • 316 Answers
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Posted on Aug 07, 2010
P 5 error in konica milolta c450
Sir/Mam
Clean them located under the transfer belt when it is removed. after which you need to accurate the sensor cover protectors manually the clean the sensor with a try cloth no static electricity or you will cause the sensor to be destroyed.. recommended a tech do this unless you known what you are doing.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 01, 2014 | Konica Minolta Office Equipment & Supplies
C-FE07 error on a Konica-Milolta C250
The machine displays an abort code CFXXXX on the control panel as it becomes unable to process tasks properly trough its software control.When the sistem program is aborted,check the electrical componenet,unit,option and connection to the specific type of the abort condition.
CFE07 - ASIC 10 timeout number of DMA under operation and transfer completion line=0:DMA_D.Relevant electrical componenets MFP control board.Try to reset:
Turn OFF the copier.
Press and keep pressed the Utility key and turn ON.
Keep pressed the Utility key while the Trouble reset message displayed.
Release the Utility key and touch the message and turn OFF the copier.
Wait 1 minutes and turn ON.
Apr 18, 2013 | Konica Minolta Office Equipment & Supplies
Konica Minolta bizhub 250 code 0204
The code is an error code, it means your copier bizhub 250 is having some problem in the LCT.large capacity tray the last tray.its not opening or may be malfunctioned.
Oct 12, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Bizhub 250. error c2152
Sep 22, 2009 | Konica Minolta bizhub C250 All-In-One...
Error c2557 konica minolta 250/NEC IT2530
Reset it, start it with the right door open, go to service mode, clear the counters for drum and developer and go to functions menu. Close the right door and start immediately the F8 function. It should work.
Jul 31, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Displaying mualfunction detected (bizhub 250)
i will like to know how to reset the page count and service my konica myself, also my konica bizhub 250 is showing C-0204
Feb 22, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta bizhub 250 malfunction error 3452
Try shutting dow the unit totally, even try unplugging it from the wall for 15 minutes.
If the error code does not go away, then a technician is needed
Jun 12, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica 7030 F-34-1 code
try to change the thermistor, if u confirm both the heater lamps is working.
the fuser unit from 7022 is not compatible with the 7020 machine.
May 29, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
May 20, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta Bizhub C253 Copier Logo
276 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
