Question about RCA P52937 52" Rear Projection Television
RCA TV won't change channels
Our tv won't change from channel 2. The numbers say that it is changing...but it doesn't.
  • pammylz Oct 25, 2008
    I have the same problem, except I have done the steps listed above, and It will still not change from channel 2. It says it's on 4, or 10, etc, but it shows channel 2. Is the tuner bad?
  • 398 Answers
Your set uses the 195 series chassis and you have something set wrong in your guide plus. Go into the TV's menu and do a complete set-up. Take the remote and press MENU, then "8" to enter setup, then press "1" for "begin setup now" and then press "1" for English, and so on. You must enter "set up guide plus+", then press OK on the remote to choose "setup", select "USA", enter your zip code, and then if you choose "yes" for "do you have cable?" you MUST then choose "no" for "do you have a cable box" If you choose "yes" for that choice, your tuner will lock on one channel no matter what channel you try entering. After choosing "no" for "do you have a cable box", choose "no" for "do you have a VCR?", exit the guide plus menu and then skip the rest of the steps by pressing "2", and then exit the main menu by pressing "0". Your channels will then work normally.
Posted on Aug 30, 2007
My TV says Channel Fix how do I get RCA Universal remote to change channels
There are manual controls for the channel change on the TV just look.
Sep 29, 2016 | RCA Televison & Video
My 27 inch rca truflat is stuck on channel 13 on the cable setting and 41-1 on the ant setting wont change to any other channel, can someone help me
try to preset the channels bec,it is not on the tv button memory but only on remote.go to channel settings and preset cable channels
May 23, 2016 | RCA TruFlat 27F520T 27" TV
Tv will not change channels past channel 2
Check if any microswitches on its front panel ahs been strucked. Replace all the microswitches at the same time. it won't cost more.
Mar 03, 2012 | RCA Televison & Video
What's your problem?Won't stop changing channels
there is every possibility that the channel (ch - and ch +) button on the TV is stuck. This can make the TV channels change by itself. This also applies to the remote control (if any).
Turn off the TV, use your thumb to flip through the channel (ch - and ch +) button on the TV. This will free the stuck button. Also, check the channel (ch - and ch +) buttons on the remove and make sure it is also not stuck in.
If the above doesn't solve the problem, then it means fault is from the control board inside the TV. It maybe defective or needs servicing.
The board controls the buttons on the TV and it can be found on the position of the channel (ch - and ch +) inside the TV.
Note that TV stores a lot of current. So if you want to disassemble the TV to check the board allow the current to discharge by remove the TV plug from the wall and wait for about 1 hour before attempting to disassemble the TV.
Let me know if you need more assistance...
Sep 27, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
My insignia tv shows a NO DATA BASE error on screen. How do i fix this.
Try these tips:
Connecting your Cable box through Coaxial to the TV.
1- Turn on the TV and the Cable Box, secure all the coaxial connectors.
2- Press the "TV" button to be sure you are in the TV mode.
3- You need to set the TV in a specific channel for receiving the signal from the Cable Box, usually they are channel 3 or 4. Please press in the TV's remote those channels numbers and check if you are receiving signal about the Cable Box in any of them.
4- If you do, afterwards remember to continue using the Cable Box remote to change the channels instead of the TV one.
Connecting your Cable Box through RCA to the TV
1- Turn on the TV and the Cable Box, secure all the RCA wires.
3- Press the "Input" button to go to AV1 or AV2 depending where the Cable box is connected.
4- You should be receiving signal instantaneously after you have changed the Input and keep using the Cable Box remote for changing the channels.
Jun 21, 2010 | Insignia LCDTV26 26 in. Television
RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Feb 08, 2008 | RCA RCR311B Remote Control
Can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Sep 09, 2007 | RCA F25254GY 25" TV
TV (RCA model F32705) stuck on one channel
Usually the fix for that on a RCA or GE TV is to go into the menu (the button in on the front of the TV) and find channel settings and let the TV autoprogram itself. This should fix the issue.
Apr 25, 2007 | RCA F32705 32" TV
Tv wil not change channels unless vcr is on
You must go into the menu, go to the channel setup and do a channel scan.. Your TV simply lost the channel memory. Good Luck
Aug 16, 2006 | RCA 6' Video/Optical Combo Cable -- DT6VHP
Sounds like an eeprom problem or a microprocessor problem??? Also make sure the tv didnt lose its channel memory by reprogramming the channels feature in the menu. Good Luck
Jun 23, 2006 | Sylvania 6427TE 27" TV
RCA P52937 52" Rear Projection Television Logo
310 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
