Question about Refrigerators
Samsung rs21 fridge temp keeps flashing
Hi, I have a Samsung rs21 side by side fridge freezer and the freezer is working great with no problems. The fridge however works for two weeks then the display flashes 6 and the first time this happened we used an hair dryer to melt the ice and it worked again for a further two weeks and now it's gone again with the same issues. I have defrosted the fan and coils slowly with an hair dryer and on powering up the fridge with the front twin cooling section out but the fan plugged in the fan doesn't spin at all. Would this be a fan issue or a problem with the thermostats? Any help would be great and also is it a easy fix? Many thanks Wayne
    Sergeant:
  • 308 Answers
It's a defrost sensors issue. You need to replace the evaporator assembly it will come with all the sensors you need.
Posted on Jul 26, 2013
  • 56 Answers
SOURCE: GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
Posted on May 30, 2009
beamerguy740
  • 65 Answers
SOURCE: rs21 samsung twin cooling
These usually have one compressor and an evaporator on each side with a fan. check the fans first then the defrost timer, heater and limit thermostat.
Posted on Sep 14, 2009
  • 258 Answers
SOURCE: Refrigerator not cooling-Freezer Coils Freeze Up & Don't Defrost
check the fan assembly theres not enough air flow going over the coils
Posted on Feb 11, 2010
walesarumi
  • 6993 Answers
SOURCE: I have a Samsung RS267LBSH, which is a
When the fridge side is getting too cold or icing up, this is because the control of the compressor has gone bad in some way...
There a few different things that could cause the unit to lose control over the temperature of the fridge side.
If your refrigerator has a damper door that opens and closes to allow cold air to move to the fridge side the damper linkage or the damper motor may have broken or gone bad.
The coils in your fridge may have frozen over and now the air does not move at all so then the ice builds up and can freeze parts of the fridge side.
The thermostat has gone bad and so now the compressor runs continually. This will not be noticed readily on the freezer side but will show up quickly on the fridge side.
Many newer model refrigerators use an electronic sensor or thermistor to read the temperature and supply the info for the circuit board and often a digital readout.
So, here is how I would go about troubleshooting this problem.
Check the coils for ice, defrost the coils with a heat gun or hairdryer, then check for the reason why they iced over. Defrost control or defrost timer bad? Evaporator fan bad?
Check the damper door to see if it is stuck in the open position. If it is then check the motor and the linkage.
Check to see if the refrigeration unit will shut down if the thermostat or digital setting is turned up to a higher temperature. If it continues to run then find the cause and fix it. It may be a bad thermostat, sensor, or control board.
Sometimes with a change is weather to a cooler climate this will be enough to also affect the inside temperatures. Make sure that a bit of adjustment in the thermostat or setting of the temperature will not solve your problem very simply.
I hope the above helps.
Good luck.
Posted on Jul 18, 2011
richroth
  • 9472 Answers
SOURCE: Fridge section not cooling enough but freezer OK
Is the fan blowing in the freezer section? Also, check to see if you have airflow thru the damper (vent) in the frig section.
Posted on Mar 31, 2012
Samsung Fridge/freezer problems
The BBC has an open complaint on these machines and you may be elligible for extended work on this
Feb 20, 2014 | Samsung RS2630SH Side by Side Refrigerator
My samsung will run fine for about 4 hours and then will get too cold. if i unplug it and then plug it back in it will then work fine for another 4 hours. please advise thank you
samsung fridge freezer srs2028 srs 2029 problems
if you a have samsung model
SRS 2026 2027 2028 OR 2029 , then you probaly need to fit the rs21 repair kit - as the srs models are the earlier version of rs21 - and suffers from the same isssues .
there is an extra component you will need as well as rs21 kit - if you look under most of the videos there is a ebay link which takes you to ebay shop where you can pruchase samsung spares
check this video out on youtube
Feb 14, 2011 | Samsung RB2155 Bottom Freezer Refrigerator
Rs21 samsung twin cooling
Sep 14, 2009 | Refrigerators
Samsung side by side fridge/ freezer model number RS21NGRS . Fridge side is not cooling . The fan was making a noise and has now stopped but the temp light is flashing how do i sort this problem thans.
Hi, there is a known fault with the Samsung RS21 units. If you unit is less than 5 years in luck, it is covered by the Extended warranty they have put in place. Apparantly this was featured on BBC watchdog!. i've had the same problem and had it fixed free of charge by Samung. Either raise a service request on the Samsung uk web site, www.samung.com/uk or call the customer services on 0845 7267864 and explain you description. the noise is an ice build up which stops the internal fan pushing cold air around the fridge. the bootom of the fridge , in the drawers is cold?
Aug 12, 2009 | Refrigerators
Samsung RS21DGRS side by side fridge freezer. Fridge not working became noisey then stopped working. It is 2 years old and two week out of warranty.
common issue on these uk Samsung fridge freezers , symptoms
fridge noisy stops when door opened
water doesn't work
colder at the bottom of the fridge
ice build up around the left vent on the lower fridge panel
check out the you tube video and the Chanel the video belongs to - very helpful stuff regarding uk Samsung fridge freezer problems
this videos show how to dismantle Samsung rs21
May 29, 2008 | Samsung Office Equipment & Supplies
Samsung american fridge sn 188742bp100124K
The freezer temperature ok.
The fridge keeps freezing
Dec 06, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
RS21 DCNS FRIDGE COOLING FAULT
There is a fan behind the plastic. This distributes the cold air throughout the fridge. What happens is this fan stops turning due to freezing up. A temp solution is to unplug the samsung for 6-12 hours to allow the ice to melt from around the fan. This is a known design fault. It is easy to dismantle the plastic cover and defrost the frozen fan with a hair dryer, this way the fridge will only be off for about an hour
Aug 14, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
730 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
