Question about Kitchen Ranges
Jennair 1d11 error code - Kitchen Ranges
F-7 error code on jennaire oven
I think that is a problem with the control assembly.
Try first unplugging power cord for ten minutes , and see if this clears the error message.
Nov 01, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jennair oven 8114 p472-60 or p458-60 f9 error code
The F9 error code for this model number Jenn-air range indicates a door lock issue. The control sees it as locked, unlocked, or both at the same time.
The technical manual instructs us to check the wiring to and from the door lock mechanism and if no issues are found replace the motorized door lock.
Mar 24, 2014 | Kitchen Ranges
Had error code 9d22, on my jennair double wall oven, took out the lock module on the lower oven, fixed it and put it back. I believe it should work but the original error code is stopping it. How do I...
9d22 means that the oven door is still locked. Obviously you didn't repair the lock module since the control board thinks it is still locked!
Feb 02, 2011 | Jenn-Air Ovens
Jennair gas range model jgr8850adw, has an error code of f1 during oven cleaning cycle, help?
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information.
Oct 30, 2009 | Jenn-Air...
Oven over heats and gives a 1D11 fault
I have a similar unit with a similar problem, and found the Maytag troubleshooting manual online. Code 1d11 means the the unit reached 600 degrees (not supposed to get that hot). Basically, it had a runaway temperature. The computer does not know why it happened, so it just tells you that it happened by showing code 1d11. But you can tell what went wrong by your description of the problem: the broiler element was turned on without any command from you. Which means the swithc/relay in the electronic control unit is bad. I am guessing it was fried when you ran the oven through the self-cleaning phase (should not get fried with this little of heat--it was defective to begin with). Mine just went bad after 4 years of use. You can get an electronic control unit for this unit for around $170 at Sears online parts store. Notice that Maytag has replaced the old part number for this electronic control unit with a new one, which probably means they had a design flaw and have fixed it.
Oct 23, 2008 | Jenn-Air JES9800BAS Electric Kitchen Range
F1-1 error on Jenn-Air Range
if it is the stove that is in the picture the fault codes are in the door under the oven door.
Jun 01, 2007 | Jenn-Air JGS8750 Gas Kitchen Range
Kitchen Ranges Logo
23 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
