Question about Yamaha RX-Z11 11.2 Channels Receiver
THERE IS ONLY ONE OUTPUT JACK FOR THE CENTER CHANNEL AND MY EXTERNAL AMP IS A TWO CHANNEL AMP
2 Suggested Answers
  • 1054 Answers
SOURCE: HOW DO I USE A EXTERNAL AMP LIKE A YAMAHA M-85 FOR MY CENTER CHANNEL ON MY RX-Z11 AV AMP
You should have preamp output jacks on the back of the receiver. Hook that up to your external amp input.
Posted on Jul 24, 2013
Jul 24, 2013 | Yamaha RX-Z11 11.2 Channels Receiver
No sound
There can be any number of reasons for this problem - solve it diagnostically by starting with something that you know is working and work through systematically to the other end.
  1. Test a microphone on a separate amp to make sure it works okay. Check amp and speakers working. Check that all output cables from mixer to amp are working by testing separately.
  2. Plug microphone into a channel on mixer. Also plug in headphones and turn headphone volume control up.
  3. Make sure input sensitivity knob is turned up a bit (say half way) and main output faders (yellow) are up.
  4. Check that channel is turned on (little button just above the channel fader- needs to be pressed down)
  5. press pfl (pre-fade listen) button (next to button to switch channel on)- do you get any sound on main output or headphones or any indicator lights on mixer to show signal is getting that far (eitehr the individual channel metering lights or the main ones in the central section)?
  6. turn off pfl - make sure channel fader (slider) is up - normal position is ) - about 3/4 of way up. Check lights again on individual channel and main output section - any signs?
  7. Is the sub mix button for the channel pressed down - in which case you will need to bring sub mix (red) output faders up as well as main faders.
  8. If you have got signs of signal on the individual channel but not main see if the channel has been routed somewhere odd (like a subgroup of channels).
  9. Plug a working amp and speakers into one of the auxiliary outputs and use the relevant auxiliary send knob (on each channel just above the faders and pfl switches) to pan some signal to that auxiliary out - do you get anything? There is also a headphone socket for listening to the auxiliary channels (with a selector switch /knob to determine which one - make sure it is in the right position) try listening to the auxiliary output with headphones - anything? If yes the problem lies in the main output section.
  10. Check that there is not a jack plug in the insert socket (to route signal through an external effects unit) without a matching return jack being plugged in - if appropriate is relevant effects unit switched on and correctly set up - if unsure remove the insert plug to take it out of the system.
  11. Make sure any mute buttons are not switched in on main outputs.
You can download a full user manual here http://www.allen-heath.com/gl/gl2400
Feb 22, 2011 | Allen & Heath Allen and Heath GL2400-32...
@I got a bose acoustmass 7 it has three inputs left right center,and three outputs left right center dont have paper work I need like a diagram or instructions on hooking it up please help.
you need to run the left speaker output from the amp to the left speaker input on the Bose, the right speaker output on the amp to the right speaker input on the Bose, the center channel output on the amp(assuming it has one), to the center channel input on the Bose...then the right output on the Bose , to the right Speaker..the Left output on the Bose to the left speaker...and finally the center channel output on the Bose to the center speaker
Jan 07, 2011 | Bose Acoustimass 5 III System
How do you hook up a external amp to a yamaha HTR-5790 av receiver? Do you have to change any settings?
Elaborate a bit on what you're trying to do if this doesn't work for you.
This unit has Pre Outs near the center of the rear panel for all audio channels which will allow you to use external amplification for any speakers you wish to use and the receiver will still control the volume.
See #12 on page 10 of the manual. Try retrevo.com
Just run RCA cable(s) from the desired Pre-Out jack to the input(s) on the external amp with its speaker(s) attached. Set the external amp's volume (if it has one) to very high, then leave it alone. Run through the Yamaha's speaker location and volume settings to level-match the external speakers to the rest.
If you want to simultaneously use the Yamaha-attached speakers for the same channels as the external amp you'll have to match the like channel volumes to each other using a volume control on your external amp, then level-match them as a unit to the other channels.
Dec 23, 2010 | Yamaha Audio Players & Recorders
No stereo signal out from yamaha p 2500 s
It's unclear what type of connectors are on the end of the cables(s) coming from your computer.
This amp only works with mono 1/4" TRS and XLR connectors, not standard RCA connectors.
Did you try the Right one in the Left Channel to see if the Left Channel worked?
Refer to the following manual and read up on the connectors (page 7) and the use of the Stereo/Parallel/Bridge Switch (page 8). When it is NOT in Stereo Mode the unit only uses the Right Channel controls and input.
http://img3.musiciansfriend.com/dbase/pdf/man/m_480824.pdf
STEREO/PARALLEL/BRIDGE switch
Use this switch to select the operating mode.
• STEREO mode
Channels A and B operate independently (as with a conventional
stereo amplifier). The Channel A input goes to the Channel
A output jacks, and the Channel B input goes to the
Channel B output jacks.
• PARALLEL mode
The Channel A input signal is output through both the Channel
A and Channel B output jacks. The Channel B input jacks do
not function. Channel A and B volumes can be independently
adjusted.
• BRIDGE mode
The Channel A input signal is output from the BRIDGE output
jacks. To adjust the volume, you must use the Channel A volume
control knob.
Apr 03, 2009 | Yamaha P-2500 Amplifier
Using Behringer PMP3000 to power monitors??
Using the mon out and the proper balanced cable follow the instrcutions found in the manual section 61.
Here is a link to the manual.
http://www.behringer.com/EN/downloads/pdf/PMP1000_P0566_M_EN.pdf
Oct 04, 2008 | Behringer Pmp3000 16 Channel Audio Mixer
Center channel drops once unit warms up
You don't have an external amlifuer, do you? You could hook the pre-amp out for the center channel to an external amp and connect the speaker to the amp. That way you could determine if it is the center channel output or the internal amp. Either way you probably need to get it serviced.
Best Regards,
-James
Aug 28, 2008 | Yamaha RX-V659 Receiver
Center channel speaker
Is the amp already used for L R? If so, you either need another amp for center, or set your Sony for stereo mix down. I have mixed the center channel into my main LR in the past and found there were terrible phase cancellations, so I suggest you switch to Stereo, or use a separate amp.
Regards
Peet
Jan 13, 2008 | AudioSource Amp Four 2-Channel Amplifier
How to turn on Kenwood KM-Z1 amp with SL16 input
Have you plugged the amp into the AV9000. Check if the outlet you are using is switched or unswitched. Changing the outlet will most likely do the trick.
Jan 12, 2008 | Audio Players & Recorders
LCD HDTV digital audio output jack
The orange jack is a DIGITAL audio out and cannot be hooked to anything other than a digital input. You want to use the White/Red jacks at the bottom.
Sep 12, 2007 | Digital Audio 5-OUTPUT COMPONENT VIDEO...
Yamaha RX-Z11 11.2 Channels Receiver Logo
15 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
