Question about Nakajima Office Equipment & Supplies
Turn off call forward
Regular underlining key does not work unless you hold down the ribbon some while typing
  • Lucy Lang Jul 25, 2013
    The correction tape is not stealing the image. It seems that the ribbon is too high. If very genial pressure is put on the ribbon while underlining, it works. This is a rather new and not heavily used
    Ps. It is model number. AE- 710
  • Nakajima Master
  • 3,594 Answers
You didn't give a model # so i'm guessing the ribbon is to high or the correction tape is stealing the impression. Be sure the ribbon is fully latched down and therre isn't a fold in the ribbon.
DickyO
Posted on Jul 24, 2013
  • 3594 Answers
SOURCE: Lexmark Wheelwriter 3 Typewriter Problem
The solinoid that drives the print hammer has a plastic cap on it and it is probably broken.
The part is available 10.00 - 15.00
Posted on Oct 25, 2007
JayBlair
  • 328 Answers
SOURCE: Wheelwriter 6 - Was typing and it just stopped
Solenoid pad is worn out. Look below left of the printwheel down inside the carriage and you should see a little white or opaque rubber pad. It needs to be replaced. You have to take it to a shop for proper repair. I have in the past, replaced it by digging the old one out with tweezers and hook. Then fish the new one in there.
Posted on Sep 07, 2009
Testimonial: "I appreciate the information. Unable to locate solenoid, it must really be small. I guess the next stop is a repair shop."
  • 3594 Answers
SOURCE: I have an IBM Selectric II. It types but does
The tab tensioner on the R. side is probably broken, not a bad job but you have to know how.
DickyO
Posted on Sep 14, 2009
  • 14 Answers
SOURCE: Nakajima AE 800 will not underline words with new ribbon
We have had new cassettes that are faulty. The quickest way to test is to change a cassette from a machine that is ok onto the faulty one. If the problem goes away then the cassette that was on the machine is faulty.
Posted on Oct 26, 2009
  • 3594 Answers
SOURCE: some of my keys are typing spanish
You are probably in KBII mode.
DickyO
Posted on Apr 05, 2011
How do I reset the AE-800 to forward the ribbon? A repairman showed me once but I have lost the "cheat sheet"
While holding the code key down press the period key then release. If this does not work turn off typewriter. Insert a sheet of paper in the t/w in the wide position. Turn on t/w while holding down the MR and #1 key. The t/w will start printing on it own. Allow it to print out 7 lines and then turn the t/w off. That should reset the typewriter.
Oct 05, 2016 | Nakajima AE-800 Typewriter
Keyboard want work
If your machine is not printing properly:
1.Examine the ribbon cartridge to make sure it has not run out of Ribbon. If your ribbon appears silver or gray, install a new cartridge.
2. Ensure the black lever in the center of the carriage is pressed to the rear, towards the paper. If not press it to the rear to lock the Daisy Wheel into place.
3. With the typewriter turned off, press and hold down the "CODE" Key, the "SHIFT" Key, and the "TAB" Key.
4.Restore power with all three Keys depressed.
5.When the machine sounds a beep tone, release all three keys.
6.The carrier will move to the left indicating that the memory has been cleared and the machine has been reset.
7.Try typing.
If the problem continues, your unit will need servicing. You can locate a Brother Authorized Service Center in your area:
http://www.brother-usa.com/service/default.aspx
May 08, 2013 | Brother EM-530 Typewriter
Wants to know how to underline name, title etc using my pc
Not much information here, but I assume you are using a word processor such as Microsoft Word or similar. To underline text you simply select the text with your mouse by pointing top the start of the text then holding down the left mouse button and moving the mouse pointer to the end of the text. The selected text should be white on a black background. Then you can press "ctrl-u" - hold down the 'ctrl' key in the bottom left of the keyboard whilst pressing the 'u' key.
This approach work in most applications on Windows that support underlining.
Mar 09, 2013 | Computers & Internet
Can't type: hello folks... my Dell 630m won't let me type or click unless I am holding the shift key. When I turn it on the machine makes a beeping noise (sometimes one beep, sometimes 20 ) before Ubuntu...
Sounds like a bad keyboard.
There is not so much that could be done to repair a keyboard. Disassemble the laptop, check the ribbon cable connecting the keyboard to the motherboard. If the ribbon cable is loose, tighten it. If it is tight, replace the keyboard with a new one.
Sep 20, 2010 | Dell Inspiron 630M Notebook
How do you underline
There are 3 ways to underline. Backspace and use the underscore key 2 left of the backspace, presscode and the U or I keys. If you are doing these things and underline isn't printing be sure the ribbon is fully latched down.
DickyO
Aug 23, 2010 | Lexmark Wheelwriter 1500 Typewriter
How do i turn off the underlining and also capital letters which automatically come up when typing
There are captions on the top row and on the face of some keys that work while holding the code key down the ones you are looking for are CAPS and XXX.
DickyO
Oct 27, 2009 | Swintec Office Equipment & Supplies
My keyboard wont type anything, the mouse works, but when i try to type it wont do anything, the buttons do work because when i open word to try to type if i click f the file drops down and when i click v...
Somehow the left ALT key is stuck in a pressed position. Usually when you press left ALT and the letter underlined in a menu, it deploys that menu. In the File menu, the F is underlined and in the View menu it is the V that is underlined, hence the behavior.
Hope it helps.
Oct 07, 2009 | Toshiba Tecra M4-S435 Tablet PC
Wheelwriter 6 - Was typing and it just stopped printing. The keys repsond, the printwheel responds but doesn't move forward to make contact with the paper. The ribbons advances, the correction ribbon...
Sep 07, 2009 | IBM Wheelwriter 30 Typewriter
Letters & numbers not printing correctly
The most common reason for this is something interfering with the printwheel. Turn off machine. Take out the ribbon, then pull back on the black lever to the right of the printhammer. This will tilt the printwheel towards you. Look to see if there is anything caught in the printwheel. Also check to see if the corr tape is installed properly. Corr. tape and ribbon should both be between the two metal fingers and the metal cardholder. Push the black lever forward and look to make sure the two metal fingers are not bent into the printwheel. If they are, simply push them forward and bend them so they don't. Re-install the ribbon, making sure it goes on the other side of the fingers. Turn machine back on and test machine. If it still doesn't work, you will need a trained technition to determine the problem.
Sep 18, 2008 | Brother GX-6750 Typewriter
The correctional tape isn't popping up to white-out the errors. Instead the actual ink is typing where it should be correcting making the letters bold. I tried tightening the correctional ribbon and the...
Hello. I had a similar problem, and Upstatoes helped me. Mine started with striker stuck forward, and then went to working for a few days, but sticking forward again And it was caused by the spring not being in the right place. But the correction tape housing is pushed up and pulled down by the white, adjustable piece on the right side, that has the screw holding it into the adjustment place. If you take off the ink ribbon, push the carriage to middle, and turn on the typewriter, there will be a switch at the top left of the keyboard, on the underside, you will need to flick with your finger, one time, as the carriage moves to the left. This is the reference switch, and you will be tricking the typewriter into thinking it is now in the left side start position. After this, you can see the white adjuster piece on the right side of the carriage, and, as you type a letter, also see if it is holding down the correction tape housing. Then when you hit the erase key, see if the cam on the inside (looking through the small holes in the correction tape housing) turns and pushes up this housing? It may be the tab in the white adjuster is not inside the grove of this cam. Either way, at that point, you may be able to see if something else is not as it should be? My problem was the long side of the spring was not underneth the white adjuster. (I had been putting it under the housing, and it was not helping ot push everything up like it should be.) Aparently this cam with the white adjuster tab in the groove holds everything down, easily, as you type, but has to have the spring help to push up when you use the earse key.
Aug 15, 2008 | Brother ML-100 Typewriter
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
