Panasonic KX-FAT410 Toner Cartridge reset
Panasonic KX-FAT410 Toner Cartridge rest
5 Suggested Answers
SOURCE: Keep Adding Toner to Panasonic KX-FL511
Does this also fix the "change drum" message even after the drum is replaced?
Posted on Apr 02, 2008
rylee_smith
  • 8619 Answers
SOURCE: I have an hp kx-fl511 fax machine. Has new toner
Hi!
Try to reset advanced features to their default settings
RESET=NO [±]
To reset the advanced features:
1. Press {MENU}.
2. Press {#}, then {8}{0}.
3. Press {A} or {B} repeatedly to select “YES”.
4. Press {SET}.
5. Press {SET} again.
6. Press {MENU}.
Thanks
Rylee
Posted on Mar 18, 2009
greg_margo
  • 1959 Answers
SOURCE: panasonic kx-fl511 has blank vertical lines on fax when printing.
It's important to gently move the toner cartridge from side to side to distribute the toner evenly through the cartridge. This could be causing your blank lines. Also, clean the Corona wire when installing a new toner cartridge. Best of luck.
Greg
Posted on Jun 10, 2009
greg_margo
  • 1959 Answers
SOURCE: Panasonic KX-FL521 Fax Laser Copier, New Toner
This is usually an indication that the toner cartridge wasn't shaken from side to side to distribute the toner evenly.  If this was done, the cause is probably a dirty drum.  Remove the toner cartridge and clean the drum. Either of these two solutions should solve your problem.  Best of luck.
Greg
Posted on Jul 09, 2009
Printer wants toner cartridge replaced, though not empty
unfortunately the drum within the cartridge has reached end of life so changing to a new drum cartridge would resolve this issue.
Mar 25, 2010 | Panasonic KX-FLB801 All-In-One Laser...
I have a KX FL511 fax machine. I just replaced the toner but it is still making faded out vertical lines on the sheet. on left side, middle, and mid right part. I have cleaned glass and roller with rubbing...
There are two things to try. First, did you shake the toner cartridge back and forth prior to installing? This evenly distributes the toner throughout the cartridge. A lot of people skip this step or just give it a perfunctory shake. The other thing to check is although you cleaned the drum/roller assembly, did you clean the Corona wire? This is important because a dirty wire will interfere with proper disbursement of toner as well. The wire should have a TAB that rests on the side. Run the TAB back and forth a few times to ensure the wire is clean and return the TAB to is resting spot.
These 2 steps should fix your problem. If they don't you either have a bad toner cartridge (check the date) or a bad drum. Best of luck to you.
Oct 27, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Greg
Jul 09, 2009 | Panasonic Office Equipment & Supplies
Panasonic kx-fl511 has blank vertical lines on fax when printing.
Greg
Jun 10, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX-CL400 Replace WTC
The problem is that the cartridge is not clean, the toner is still on the inside near the sensor area. If you get a pipe cleaner or a peice of tissue on some wire you can wipe the area. Failing that give it a good wash, let it dry and it will work. I'v done this a few times now
Apr 08, 2009 | Panasonic KX-CL400 Laser Printer
Hi!
RESET=NO [±]
1. Press {MENU}.
4. Press {SET}.
6. Press {MENU}.
Thanks
Rylee
Mar 18, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Black lines going across the pages
1 check the toner cartridge see it has toner rings on it
2 open - remove toner check the bottom for a thin glass strip clean
Jun 12, 2008 | Panasonic KX-FL541 Plain Paper Laser Fax
50 people viewed this question
jasbo
jasbo
