Question about Blaupunkt Alicante CD32 CD Player
Blaupunkt Helsinki RTM 127 key card does not insert
Hi, I have a Blaupunkt Helsinki RTM 127. The radio worked perfectly Before with the keycard inserted. i took the keycard out once, and now it is a problem to insert the key card again, because anytime i try to insert the key card, it comes out again. it shows no error on the radio's screen. it only indicates to insert the key card and the radio goes off after some time. Please help me out on how to insert the key card again. Thanks
5 Suggested Answers
  • 4869 Answers
SOURCE: Fiat punto Blaupunkt radio code
Your code is 5122
Posted on Sep 06, 2009
  • 4869 Answers
SOURCE: Hi I need a Radio code for a Blaupunkt Travel
Try code 8427
Posted on Mar 03, 2010
Testimonial: "Thank You for your help worked first time , nice to see the Radio burst in to life , thanks again ."
  • 4869 Answers
SOURCE: Hi Looking for a radio code for a Ford Mondeo.
Try code 9 1 3 8
Posted on Jun 13, 2010
caroldon
  • 17130 Answers
SOURCE: Problem for Blaupunkt Bermuda MP36 Car CD Player.
The fault was explained earlier, please check your MP3 format. play a normal cd to see if it detects, if so try with another recognised MP3. if not clean your head after opening the set. try again or it is possible that your optical is faulty or the RF signal processor IC is defective. Check this out. Good day
Posted on Jul 13, 2010
Can I replace the standard car radio /cd in 2008 Multipla with a Blaupunkt Helsinki 220 BT without modifying the wiring connector
There are companies that specialize in adapters and kits that will allow installation of aftermarket car stereo equipment without cutting wires, connectors or filling voids in the dashboard.See some choices linked below:
Metra Electronics Car Audio
Find what fits your car Crutchfield
Car Stereo Installation Dash Kits at Sonic Electronix
Aug 27, 2015 | Blaupunkt Car Audio & Video
I have recently had to have a new keycard done for my 55 plate Renault Megane as the central locking on my keycard stopped working and I couldn't access the vehicle, now I have two keycards that both
change batteries if this is not the fault. twist key slightly while trying to lock/unlock if key works transponder terminals have broken off the board
Oct 06, 2014 | 2005 Renault Megane 1.4
My Blaupunkt car radio produces noise to both left speakers
hi, you might have a wrong speaker wiring system, try to check for loose wires and fit them perfectly, hope this helps, have a nice day
Feb 09, 2010 | Car Audio & Video
Hi, I just bought a blaupunkt Sydney RCM 126. After connecting the unit to my car, the display says ''wrong KC''. It has been working ok with the previous owner. Obviously after being disconnected for a...
Wrong KC means wrong keycard (smartcard)
This radio requires a Keycard (Smartcard) in order to operate.
See explanation here
http://www.bluespot.co.uk/keycard.asp
Nov 10, 2009 | Car Audio & Video
Cannot get back in my 53 plate laguna with key card, changed battery red light showing on card, what can i do next, also tried emergency key but doesnt appear to work.
unles you have a spare keycard your options are very limited, either way it will be needing main dealer attention as they are the only ones who can program key cards or order you a new keycard with emergency key
Sep 01, 2009 | 2003 Renault 181
KeyCard Types
There are several popular type of keycards in use and include the mechanical holecard, bar code, magnetic stripe, smart card (embedded with a read/write electronic microchip), and RFID proximity cards. The keycard is used by presenting it to a card reader; swiping or inserting of mag stripe cards, or in the case of RFID cards, merely being brought into close proximity to a sensor.
Aug 27, 2008 | DG Gold / Brass 98 Biometric Keyless...
How to remove a blaupunkt santa cruz mp36
I'm afraid its a little bit late for corsamad11 but I've just spent hours finding that too much messing about taking a Blaupunkt Santa Crux MP36 in and out of your dashboard will almost render this great quality radio almost useless. Not being securely fixed in the dasboard.
The radio is held inside the mounting bracket by a metal strip each side which are supposed to spring closed to secure the unit. When the two keys are inserted each side of the radio they are supposed to push out these metal strips and at the same time hook onto each side of the radio behind two little lugs. This may work a few times but thats about all. The metal strips don't spring closed and the removing keys don't hook on the unit to pull it out.
Fiddle about with the keys inserted in each slot and at the same time try to push the unit further inside the dash. When this is achieved the mounting bracket lugs can be straightened out and the bracket can be removed with a narrow screwdriver as installed.
Just a very poor and flimsy design on a much loved radio.
May 31, 2008 | Blaupunkt Santa Cruz MP36 CD Player
Blaupunkt Alicante CD32 CD Player Logo
70 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
