Question about Dishwashers
Winterhalter error 17 - Dishwashers
Winterhalter machine code error 24 and 26
its a drain issue. something is plugged or pump isn't working.
Feb 23, 2017 | Washing Machines
What does error code 35 mean on the winterhalter dishwasher
Error 15 = on the GS502/515 is a Main Water Stop Valve Blocked or Closed
Apr 28, 2015 | Dishwashers
Winterhalter error codes 23
Call customer support
Jul 07, 2014 | Dishwashers
Winterhalter gs502 and getting error 11
Klix-on on motor has failed. (This is often due to overheat) Clear dust and dirt from around motor to restore cooling may be the answer. .
www.cearcommercial.co.uk/.../winterhalter/winterhalter-wps-reminder-er...
May 21, 2014 | Dishwashers
WHAT DOES ERROR CODE 6 MEAN
I'm thinking the drain is plugged. Good Luck.
Nov 24, 2013 | Washing Machines
Winterhalter gs 302 error Code 15
haw can i chainge a float switch on a winterhalter gs302 ?
please any one can hellp
Mar 17, 2013 | Dishwashers
Error code 23 on winterhalter gs 502
hi i a have a problem with dish washer it shows error 23 .and the ,model is GS 502,GS 515 .So how can i rectify the problem .thanks in advance.
Dec 28, 2012 | Dishwashers
Winterhalter gs502 dishwasher-error code 15?What's mean fault code 15?
The float switch/level sensor in the rinse boiler has not activated. This could be a faulty solenoid not letting the water in(assuming the isolating valve is turned on), or a faulty float switch/level sensor. This would result in water overflowing through the rinse arms and the overflow in the rear of the wash tank.
Mar 18, 2011 | Dishwashers
DISHWASHER INSTRUCTION MANUALS
please contat winterhalter regional office or headquorter on
info@winterhalter.biz
Nov 14, 2007 | Washing Machines
Dishwashers Logo
75 people viewed this question
Top Dishwashers Experts
