Question about Vehicle Parts & Accessories
Mercedes window windows wont open or close
Take it to a repair shop or dealer.
We don't know why & you provided
no vehicle or info on what has been done
You need a problem YOU can't resolve to
ask a question
Posted on Jul 25, 2013
Mercedes slk 230 hardtop does not open
I owned an SL 500 with the same issue. The auxiliary battery went out ( during warranty )
Mar 11, 2014 | 1998-2004 MERCEDES SLK230 SLK 230 CARBON...
On a Mercedes CLK 200 Kompressor (2006) the rear left window does not respond and does not go up and down. It stayed open and cannot be moved up. Any information in how to solve the problem? Regards!
Your main control in drivers door is worn out run a hot wire from battery to left window in main control this might close the window this happen to me on a 89 mustang
Sep 09, 2011 | Mercedes-Benz CLK Cars & Trucks
In my 03 mercedes e320 wagon the sunroof opens only half way when auto open is used. Is this normal?
No. Push the open switch until glass is fully open....continue to hold switch for 5 seconds to allow motor to memorize open position...ditto closing.
This also applies to your side windows. Any time battery disconnected or voltage drops below 10.5 volts all convenience memories need resetting like this.
Hold window switch down fully for 5 seconds after glass has gone fully down. .....release switch
Repeat for other windows. Switch must be in second detent position when doing this.
NEVER boost charge this vehicles battery in the car unless GROUND connector disconnected from battery...serious electrical damage can occur if this is not done.
Jan 13, 2011 | Mercedes-Benz E320 Cars & Trucks
Drivers electric window switch broken . The window is open can i close it any other way it is a 1999 ml 430 t reg cheers
No, that is the master switch that control all the other doors and locks. try putting the key in the drivers dr and hold it back in the lock possition for about ten seconds and if the window dose not close then you need to replace the master switch.
Dec 22, 2009 | 1999 Mercedes-Benz M-Class
After a dead battery, the electric windows on my 1998 Mercedes SL500 do not clear or lock upon door opening and closing.
Lower all windows,enter car shut all doors +boot.Raise and lower all a few times,Raise all should reset.
Oct 31, 2009 | 1998 Mercedes-Benz SL-Class
Mercedes a class passenger window wont go up or
mercedes a160 passenger window will not close
Oct 25, 2009 | Mercedes-Benz E320 Cars & Trucks
Merceces 2001 window overshoot when closing
Have a mechanic look at the window track guides as well as the window motor.
Sep 04, 2009 | 2001 Mercedes-Benz C-Class
Electric window wont close properly
sorry gears on window regulator worm.
Feb 26, 2009 | 1992 Mercedes-Benz E-Class
Sticky windows
Have taken car into a dealer and have been advised that if battery has gone flat, the sensors will need resetting, to do this, disconnect freshly charged or replaced battery for two to three minutes, reconnect, turn key to position two and operate window. Hold button down and wait for click (window open), close window and hold button in close position until you hear the click. This should reset the sensors to open and close positions. Juddering maybe caused by build up of grime in slider, squirt some silicone based lubricant into window slider/guide, this should help. If none of this helps, it could mean that the motors need replacing.
Oct 22, 2008 | 2000 Mercedes-Benz CLK
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
