Question about BenQ Office Equipment & Supplies
Why comes up a recall code on my BenQ MW519 DLP Projector?
It comes up a recall code on my projector screen, is there something wrong so they recall bad model??
Benimur
  • 6966 Answers
SOURCE: CONNECT CABLE TO MY PROJECTOR
Depending on the specific model of your Mitsubishi DLP, you can have either S video, RCA, VGA or a few other choices of INput connection.
Depending on your cable provider and hookup, you can either have a plain cable with F connector or a cable box normally with RCA connectors and a remote control.
If you have a simple cable connection that attaches direct to a TV (no remote, no box), you would need a TV Tuner to be able to receive the different channels whose output would be a composite video signal into the yellow RCA jack. You would need an RCA to RCA cable to in turn connect it to your Yellow RCA Video INput of the projector. In the absence of a tuner, an old VCR with such a feature would also serve the purpose. In some instances either units may also have an S video connection.
If you have a cable box with with remote, then there is no need for a tuner or VCR since its output would already match the projector's input.
Either way you would need a separate audio amplifier/speaker  for the sound.
Hope this be of some help/idea. Pls post back how things turns up or should you need additional information.
Good luck and kind regards.
Posted on Oct 23, 2007
SOURCE: Resetting the lightbulb in my benq projector
press and hold exit button for 3 seconds or more and OSD will pop up, then follow instructions
Posted on Mar 15, 2008
Marrie
  • 563 Answers
SOURCE: Benq MP610 password
Hi andygwizz
Enter the following code to unlock the Projector :
9001
Posted on Jun 03, 2008
  • 13 Answers
SOURCE: Projector displays reverse image also has grayish purple color
Use the remote to go into the menu and change the screen position. There are 4 to choose from, flip left, flip right, flip upside down left, flip upside down right. It may be tricky to navigae the menu backward though.
Posted on Jan 28, 2009
  • 6 Answers
SOURCE: HD 70 DLP Projector problem
Hi, My name is Doug Stanko.
I had the same issue and fixed the problem.
All you have to do is take a few screws out..... and blow out the inside VERY well with pressurized air. I have a compressor... and I set the regulator to 50 psi. But the KEY IS TO have the covers off so you can get between the circuit cards and blow them out. They were incredibly dusty. Even after I blew through the side vents.
I agree with all of you that say it is overheating. You are right. There was so much dust on the fan blades them selves... I'm suprised they were still spinning at all.
And like most of you... first I bought the $300 dollar bulb... put it in and 10 minutes later it was doing the same thing flashing through the colors. So trust me.
There are 4 screws on the back. Take these out.
There are 2 small nuts on the back around the VGA input. Take these out.
There are about 5 screws on the underside (think one was on the bulb changeout portion). These have long copper colored bars that go all the way from top to bottom.
All these have to be removed. Then you can take it apart. AND I PROMISE YOU WILL SEE TONS OF DUST ALL OVER.
Make sure you blow out the parts between the circiut boards AND the fan unit.
Put it back together... and remember to make sure that little latch on the bulb change cover makes the click sound ( it is a switch that must close or the unit will not power back up )..... and it will work great again.
No need for a huge fan next to it. Although I will admit that is an excellent idea.
I did this 3 weeks ago and have been watching it with no issues.
If you do not feel comfortable taking the screws out yourself..... I would take it to your local TV repair store and just ask them to take the covers off and blow out all the dust... and give it back to you. No troubleshooting... no repairs... no replacements... just blow it out.
I was an electronic technician in the US Navy for 10 years... Now I work at a nuclear power plant in Illinois. BUT I PROMISE with a good phillips head screw driver and a small crescent wrench you can do this yourself.
Good luck and you are welcome. I know how frustrating this issue is. But this is the fix.
Doug
Posted on May 13, 2009
Hi, I lost password for benq mp720p projector. coded number : 22504-14770-7161-9374
From the manual:
To enter the password recall procedure:
Press and hold Right (arrow)
for 5 seconds. The projector will display a coded number on the screen. Seek help from the local BenQ service center to decode the number. You may be required to provide proof of purchase documentation to verify that you are an authorized
user of the projector.
Nov 12, 2016 | BenQ Office Equipment & Supplies
BENQ W1060 projector POWER lamp flashing but not working. What's wrong?
When you replace the lamp you have to reset the hours menu on the lamp. It is found in the menu under settings.
Aug 19, 2014 | BenQ W1060 - Dlp Projector
Hi. i lost my password of my Projector Benq MP610, with code 22504-15078-7347-9687. i'm looking ford to your help.
If you forget the password: You will be asked to enter the four digit password every time you turn on the projector. If you enter the wrong password, the password error message displays. You can retry by turning off the projector (by pressing Power and start again, or if you did not record the password in this manual, and you absolutely do not remember it, you can use the password recall procedure. To enter the password recall procedure: Press and hold Right for 5 seconds. The projector will display a coded number on the screen. Seek help from the local BenQ service center to decode the number. You may be required to provide proof of purchase documentation to verify that you are an authorized user of the projector. To change the password: 1. Open the on-screen menu and go to Setting->Change Password 2. Press Left or Right (button). A "Password Change" message displays. 3. Enter the old password. i.If the password is correct, you can go on to enter new password.
IMPORTANT: Write your selected password down here in this manual so that it is available to you should you ever forget it. Password: __ __ __ __
ii.If the password is incorrect, a "Password Error" message displays. Press Up to try again or press Down to cancel. 4. Check the new password. i.Pressing Auto completes the procedure. ii.Press Up to try again. iii.Press Down to cancel the set-up and return to the on-screen menu.
Mar 10, 2011 | BenQ MP610 Multimedia Projector
Hi, i can't go through with my Benq MP610 because of password porblem. Please i need your help.
turning off the projector (by pressing Power) and start again, or if you did not record the
recall procedure.
Press and hold Right4 for 5 seconds. The projector will display a coded number on the
How can i reset a password for benq mp620p projector
Hi,I have a Benq mp610 projector that I have forgotten the password for so need the code to unlock it. The recovery code for it is 21182 13770 6789 8385
Jan 14, 2011 | BenQ MP620p DLP Projector
I have a BenQ Projector MP610. I lost my password and now i cannot use my projector. I get the code: 22504 13898 6789 8507. Please help...Please email me the decoded password... vmonacillo@yahoo.com
If you forget the password: You will be asked to enter the four digit password every time you turn on the projector. If you enter the wrong password, the password error message displays. You can retry by turning off the projector (by pressing Power) and start again, or if you did not record the password in this manual, and you absolutely do not remember it, you can use the password recall procedure. To enter the password recall procedure: Press and hold Right4 for 5 seconds. The projector will display a coded number on the screen. Seek help from the local BenQ service center to decode the number. You may be required to provide proof of purchase documentation to verify that you are an authorized user of the projector. To change the password: 1. Open the on-screen menu and go to Setting > Change Password. 2. Press Left 3 or Right4. A “Password Change” message displays. 3. Enter the old password. i. If the password is correct, you can go on to enter new password. IMPORTANT: Write your selected password down here in this manual so that it is available to you should you ever forget it. Password: __ __ __ __ Keep this manual in a safe place. ii. If the password is incorrect, a “Password Error” message displays. Press Up 5 to try again or press Down 6 to cancel. Password Setup Enter Password Press Auto to Confirm Press 5 or 6 to change number Press 3 or 4to move 0 0 0 0 Password Setup Do you want to use 0 0 0 0 as your password? Yes Auto No 5 Cancel
Feb 17, 2010 | BenQ MP610 Multimedia Projector
Projector shuts down ca 20 sec from start.
sounds like you may have the wrong bulb and it is being overpowered.
Dec 15, 2009 | BenQ PE8720 DLP Projector
I've fogeten my password for my benq projector
you may try all "0000" first and then let me know if that worked. Good luck. Jay
Jan 31, 2008 | BenQ PB7220 XGA DLP Projector Multimedia...
DLP projector BenQ MP710p
Actually you can turn the projector on and then tilt it in all directions and see if picture shadowing changes. I have experience with this issue on DLP TV'S. IT sounds like a light tunnel problem if you can see partial picture behind shadow. It is fixable but very tedious. But can be done. Do you have a picture of the problem that you could send over? Thanks Jay
Jan 03, 2008 | BenQ PB7220 XGA DLP Projector Multimedia...
32 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
