Why did my mini travel mouse w/ retractable cord suddenly stopped functioning? It does nothing when plugged into my laptop. Its acting like the batteries are dead, however, I know it DOES NOT use batteries!
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
Try these three steps:
1. If your Laptop has more than one USB Slot, you might want to try that second USB slot and have the mouse connected to it.
2. Try the mouse on a different PC or a Laptop. See if it works on there. Sometimes it takes about 10 seconds for a PC to identify the new device thats just connected to it. So you might want to wait a bit and see if the mouse is accepted on the new PC your going to try it on or .... not.
3. If none of the above worked. Go back to your Laptop, then go to your Control Panel>System>Device Manager> double click Mice and other pointing devices>Check and see if your mouse is on there, if it is there, see if it is disabled or not. If it is disabled, just right click on it there and enable it. If its not there move to the next step.
4. Now its time to check the USB Slots, find any other device that you can get hold of, like a desktop USB keyboard, or a different mouse from anywhere just to test your Laptop hardware. See if it'll work! If they did, well!! You know what you have to do next!!. lol
Posted on Jul 25, 2013
SOURCE: GE Wireless mouse 97990 Rev 4 stopped working
From the Jasco website, some other options to try: Batteries: Tracking can be affected by low or dead batteries. Try replacing the batteries with a fresh set and test the tracking. Although you can use rechargeable batteries, alkaline batteries have been found to have the longest battery life. Interference with other electrical products: Other electrical devices may interfere with the radio signal that the mouse uses to communicate with the receiver. Try placing the receiver in a different location, away from the monitor, zip drives, and other electrical devices. Also, try rotating the receiver so it is on its side (or back). Range of the receiver: GE cordless pointing devices can transmit a signal up to 2 meters (appr 6 ft). Make sure the receiver and mouse are within the 2 meters of each other.
Posted on Jun 01, 2007
SOURCE: logitech 3200 cordless mouse and keyboard not working
reset red buttons on both mouse and receiver. Worked great.
Posted on Dec 17, 2007
SOURCE: wireless mouse not functioning
Being a guy, I started years ago rapping things a couple of times to get them to work - until I destroyed an expensive digital camera!
To my surprise however, I gave my MSK1056 a few gentle taps and, voila, it works.
Thanks
Posted on Jul 17, 2009
SOURCE: Retractable Cord won't lock
When fully extended (you have to hold the cord in place since it won't lock), slide the rectractable device down the cord until it is butted up against the USB connector. You can use the mouse with no problems like this. When you are done, slide the retractor back to the middle of the cord and the ends will wind back in. It's not a perfect solution but at least makes the mouse usable.
Posted on Sep 08, 2009
N_Flames
  • 6 Answers
SOURCE: my cord on my razer copperhead mouse is broken
Gaming mice are not cheap,sell for $30 - 130. The cord on my RAZER DIAMONDBACK mouse went bad, I opened the mouse & repaired the broken wires.You have to unplug cord from inside mouse,the connection plug has very small barbs,so you have to pry the socket open a bit to unplug it.Once the cord is out cut the rubber part on the cord that connects to mouse that reinforces the cord.Cut it off on both side,pull out the remaining bits of wire.You have to enlarge the hole in the rubber grommet to reinsert the cord threw it,a heated wire the size of the cord works well to enlarge the hole.Run cord thew grommet splice wires,solder wires if you have a soldering iron makes the best repair,splice wires offset from each other,so they are not all sliced at same location.Use a good tape to isulate the spliced area on each wire,about 1/2 of tape per splice,Scotch Super 33+ Premium Vinyl Electrical Tape. Once you have taped each wire, tape all the wires together, for better isulation.Reinslall wire harness & test mouse.
Posted on Sep 13, 2009
How to change batteries to mini optical mouse
There are no batteries. It's a wired USB mouse.
Apr 26, 2014 | iHome Optical Mini Travel Mouse W...
I bout retractable travel mouse and doesn't seem to work on my labtop
It may have a manufacturing defect. Have you tried it on another computer? If it works on another computer, see whether it works when connected to a different USB port on the laptop. If it does, then you may have a bad or damaged USB port on the laptop. If it works on another computer but still does not work on the laptop when connected through an alternate port, then see whether some other device will work when attached to the laptop's USB port. If neither the mouse nor the other device work when connected to a USB port, then you have a problem with the USB controller. If an alternate device does work when connected to the USB ports of the laptop, and if the mouse works when connected to another computer but does not work when connected to the laptop, then you have a software problem, and probably need to change the mouse driver in a control panel or setting in the operating system of your laptop.
Oct 27, 2013 | Maxell Optical Travel Mouse With...
HP retractable mouse in Acer notebook stopped working.
maybe your mouse has gone bad, i've had that happen before
Feb 15, 2012 | Acer Aspire One D255E13438 Netbook
I have the power cord plugged in all time when using it because battery no good. I then plug in the mouse and things are fine. If i pull the power cord too far or wrong way it comes unplugged from laptop...
Well, if you have a faulty battery and the your power source is lost, the USB obviously won't work either. Sometimes when there's a sudden loss of power, the computer's devices won't function properly. A hiccup in the programming will mess them up. I would suggest getting a new battery. I hope this helps.
Apr 10, 2011 | Computers & Internet
My Targus optical mini-mouse with retractable cord just stopped working.There is no light underneath. Does it have a battery? Or is it just bust?
are your mouse is bluetooth or cable?
if its bluetooth, its definitely need a battery. if its cable then your mouse probably already damaged because there is no light from your mouse.
hope this useful, regard riyan
Mar 29, 2011 | Computers & Internet
I need a wiring diagram for a Targus PAUMO1
Not worth it!
One wrong wire could burn out multiple USB ports on your computer (or any computer the device is plugged into).
It would be best to get a new or used mouse.
Apr 24, 2010 | Targus Ultra Mini Optical Mouse With...
M trying to fix my retractable mouse. do you have any diagram showing how the insides of the retractable mechanism looks like. much thanks!
Optical mouse from inside: http://www.gadgetrivia.com/photos/o/56422-best_optical_mouse.jpg (this isn't a retractable mouse, but the inside looks exactly the same, only the cord this different which doesn't matter in this situation).
Here are instructions for optical mouse repair: http://www.thenetguruz.com/hardware/diy-optical-mouse-repair/
But if your mouse doesn't work first plug the mouse in the USB slot and check the laser beam under the mouse - if there is no light, the mouse is dead, and you should return it to the seller for replacement. (Such a thin cable of the mouse is very vulnerable and might break easily. More over I find many negative reviews about this rectractable mouse - so if your seller offers to replace it - ask for a different model or test it with your laptop right in the shop before bringing it home.)
2) Here is a solution that already worked for another user, but was very complicated: http://forums.toshiba.com/t5/Keyboards-Touchpads/USB-mouse-not-recognized-drivers-can-t-be-installed/m-p/23526
3) Or alternatively download and install a free driver updater software, e.g. http://www.innovative-sol.com/drivermax/index.htm - let it scan and update all your missing drivers - it may fix USB general problems if this causes also the mouse problems.
Apr 10, 2010 | Generic Memory Mini Retractable USB...
Am trying to fix my retractable mouse. do you have any diagram showing how the insides of the retractable mechanism looks like.thanks!
No pix or diagram, but you'll see a coil spring that provides the retracting function, plus one very small ball bearing that provides the holding function. The ball bearing sits on a dimple in the case and "lodges" itself in a groove in the top plate, so that whenever you rotate the case all the way around once, the ball bearing falls into the dimple and locks the two pieces together until you yank the cord. The cord just wraps around the case and there is enough friction between the cord and the case that as you pull/slide the cord, it winds the spring.
What happens most of the time is that the case/plate slips apart and the tension comes off, and/or the ball bearing drops out.
I took the plate off the case (a small phillips screw), rewound the spring a couple of turns, rewrapped the cable, very carefully put the ball bearing in the groove, and put the screw back in. It was difficult, and you should do it with tacky paper on your work surface because I dropped the ball bearing quite a few times.
Earlier in this column, someone said send it back in for warranty. almost worth it to do that, because the small pieces can be frustrating to deal with.
Apr 05, 2010 | Generic Memory Mini Retractable USB...
Stopped working
Hey,
Goto device manager by right-clicking My Computer-> properties-> hardware-> device manager.
There in mice and other pointing devices category, select your mouse, uninstall it and refresh the page.
It should automatically detect your mouse.
Thanks
Apr 15, 2009 | Toshiba Black/Red USB Laser Mini...
Won't work with PC
Hi alot of people have problems working out the wireless devices. You need to plug in the USB reciever load windows till desktop appears, hold down the reciever button until it flashs then quickly turn over mouse and press connect button in. and you should see the reciever flicker, and it should start working. if it dont try swapping the batterys as they dont last long... Hope this helps John
Feb 26, 2007 | IOGear 800 dpi USB Optical Mini Mouse...
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
