Question about Microwave Ovens
Samsung a3l wep 250 - Microwave Ovens
Magic chef microwave how to preheat 250 f
No problem--a lot of Google searches lead here.
Jun 16, 2012 | Magic Chef Microwave Ovens
Tip
Noisy Magnetron Test for GE, other Samsung-made Microwave Ovens (shuts off after...
If your GE or other Samsung-made microwave oven (usually having FCC number prefix "A3L") shuts down after a few seconds of running, then you must reset the clock and reprogram it, it's almost always a "noisy" magnetron.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched, but it's most often a failing magnetron.
I have created a test procedure to help confirm this diagnosis.
NOISY MAGNETRON TEST
(c) 2009 and posted by William E. Miller prototech@usa.net.
I the poster am the copyright holder on this and hereby grant permission to this site keep this on the FixYa Web site.
First, PLEASE do not be fooled into thinking that procedures such as this constitute a "fix". This kind of action should only be regarded as another test method to prove that you have a noisy magnetron which must be replaced.
1. Unplug the microwave or turn off its breaker.
2. Open the door, then detach the control panel as shown in the video here and swing it down, but without disconnecting the wires. If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
3. Plug the microwave back in.
4. Make sure neither you nor anyone else reaches in behind the control panel. There will exposed high-voltage connections.
5. Put a few cups worth of water in a microwave-safe container and place it inside the microwave.
6. Shut the door.
7. Run the microwave for about 1 minute or so on full power. (Time Cook > 1 > 0> 0 > Start, e.g.)
8. If it does not fail, try it several more times.
9. When the water boils, change the water and try again.
NOTE: If your model does not have a door handle, you will need to unplug the oven and reattach the control panel to be able to open the door.
If it still does not fail, I would recommend that you put it all back together and keep using it until it fails more consistently, then repeat this test.
If it keeps failing while the board is in the down position, you either have a very leaky magnetron or possibly another problem.
So you can then get a non-conductive plastic bag and insert a flat piece of aluminum foil into the bag and close it.
Then (with the power off) tape it over the circuit board as best you can, covering it as much as you can, making sure it does not get snagged or punctured.
Then try the oven again. Do not leave this test shield in place as a "fix". It is not safe.
While a microwave should never be left running unattended under any circumstances (as your owner's manual will tell you) it's even more important when one is exhibiting a failure or any odd behavior. So play it safe and stay with it while it's running!
If you or someone you know want to replace the magnetron yourself, you will need to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find links to helpful exploded view diagrams and part ordering help here. I recommend that you bookmark that link to your favorites.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then GE will cover the part cost, but not the cost to visit you or the labor charge to do the work.
G.E. will send you the magnetron to do it yourself. Call them at 888-239-6832.
If it is not within the magnetron warranty, you can replace the magnetron yourself by ordering it form the link above, or at least save about $75-90 by pulling the oven down from the wall and taking it to the shop yourself.
on Jan 26, 2010 | Microwave Ovens
I have a Samsung household microwave oven model # SMH8165ST that when plugged in will beep a few times then blink "SE". None of the buttons will work.
Try calling Samsung....
Purchased samsung SMH8165ST in Oct 2009. have had the SE code problem for a few month now. Resetting worked at first. Then the light started flasing on & off along with the beeping...would not reset. Out of frustration I called Samsung. I was told they are aware of the problem & would repair in the "epidemic warranty". Repair man just left. It took him about 15 minutes to change out the keypad. No charge!!
Aug 30, 2011 | Samsung SMH8165STE Microwave Oven
My microwave stopped working just went dead. I have changed the fuses (20A) 250 volt and that didnt work. What should I try next. Thanks, Sam :)
We have a Samsung SMH9187ST that just shuts off. no power at all. this is the 2nd time it happened, this time my husband was home to witness. First time I somehow got it to start working again , this time no luck. it was manufactured Dec 2009
Apr 13, 2011 | Samsung SMH9187ST Microwave Oven
SMH915W Samsang Microwave Oven How much does it cost
Thank you for using FixYa. The cost is approximately$250- $300. But its reviews are not very good so please beware.
Mar 16, 2011 | Samsung SMH7178STD Microwave Oven
Microwave will not come on, just dead. any suggestions? We cannot find our manual
There is a ceramic fuse inside (automotive style fuse) which may blow in the event of
a power surge or failing magnetron. These are available at most radio shack or
appliance parts store for a couple of dollars. Make sure to unplug unit before removing
cover and be very careful around the capacitors as they can retain a high voltage
similar to an electric fence. The fuse will be ceramic with metal ends , replace with
equal value amps and volts (stamped on metal bands at each end) for example
5A 250 V is read as 5 amps at 250 volts. These are slow blow fuses and cannot be
replaced with just automotive fuses . Hope this proves helpful
Feb 27, 2011 | Microwave Ovens
Where was the space maker made in?
You can find that information on the tag inside the cooking cavity on an over the counter model or on the back of a counter top model.
That said, most GE's have been made by either Samsung or L.G. (formerly Goldstar) for the last many years, and while they are both South Korean companies, some or all of them may be from China.
If the FCC ID number starts with A3L, it was made by Samsung. If it's BEJ, it was made by L.G.
Aug 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have samsung microwave model MW830WA 120V 60HZ 800W IT IS DATED 2001. The fuse has been blown off last week. I want to know where the location of the fuse and what fuse to buy. Thank you, Phil
I know on my samsung it's right on top when you take off the outer cover. I also have an emerson and it's on the right side behind the control panel There is a white plastic cover over the fuse that just snaps apart.. I buy my fuses at radio shack. I know mine takes a 20 amp 250 volt.
Aug 12, 2010 | Samsung MW4699S Microwave Oven
Difference in KW
.25Kw or 250 watts of cooking power.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 01, 2008 | Samsung MW5592W Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
