Question about Proscan PS20105 TV
Coaxial input only
After replacing my old DVD player, I discovered my Proscan PS20105 tv wouldn't accept input except via coaxial cable despite having S-video and other inputs in back. My original remote stopped functioning a while back, too. Is there any way I can get S-video input without the remote? Or, if I need a remote, is there a good substitute for the original one? Thanks!
  • xjakex Jan 10, 2008
    I also have the same problem with other inputs, audio & video rca jacks from dvd player. Can't get them to work, but a remote control should not make a difference.
  • lbmiko Aug 17, 2008
    yep cant seem to get any of the other inputs recognized
    help!
I had the same problem... lost the remote. I was able to buy a replacement cheap at http://replacementremotes.com/
Here's the page that describes it:
http://www.replacementremotes.com/store/productdetailp.cfm?productid=780&categoryid=110
But they say they no longer carry it. Sorry. They also say these universal models will work with it:
MODEL: CRK83C1
PN: 221114
Can Use the generic RR62A, Proscan, RCA,GE, Proscan, PN: 221114, Model: CRK83C1, 221112, 240895, CRK83A1, 221114
Posted on Nov 13, 2007
  • Proscan Master
  • 12,061 Answers
Ok sorry but ya DO need the remote.. :( However ya may be able to use one of those "Learning Remotes" or "Universal" remotes that could be the answer to what ya need...,
Posted on Aug 30, 2007
SOURCE:
Problems with Philips vhs recorder/dvd player
You only need coaxial cable to pick up TV stations broadcast via an aerial. If your TV has sockets to connect via HDMI or SCART, then any players can be connected via them. So if the adapter box picks up TV signals, you connect the main aerial cable to that and it should have a coaxial out socket, that should be connected to the aerial in of your TV. If you are recording to an analogue video from the adapter box, then that will need to be connected via a scart socket or other connection.
Nov 24, 2017 | Philips Dvd Player Vhs Video Tape Player...
How do you hook recorder up to tv and dvr cable box
Simple. Connect the composite output from the VCR to the composite input on the back of the Presidian. Then connect the coaxial output from the back of the DVR to the coaxial input on the back of the Presidian. Then connect the coaxial output from Presidian to the coaxial input on the back of the TV. Turn everything on and enjoy! :-)
Jan 05, 2011 | Dual Presidian DVD Recorder
Have an RCA F27636BC TV. Can u hook a DVD player
How to hookup TV
If you have a TV with only a single coax input and you want to hook up components like DVD players and VCRs, here's how to do it.
What you need to connect your DVD player or game players to a TV that only has a VHF/UHF 75-ohm F-connector ("coax antenna input").
1.) RF Modulator with Stereo Audio Inputs.
2.) 6 foot long coaxial cable with male "F" connectors. This cable goes from the modulator to the TV. The modulator also has a coaxial input to plug in your antenna or your VCR.
3.) 6 foot long Video and Audio Cables with "RCA" plugs. The cables connect the yellow, red and white outputs from your DVD or game player to the yellow, red and white inputs of the modulator.
Works with X-Box, PlayStation, Nintendo or other devices that output audio/video via the RCA plugs and you want to connect them to your coaxial only TV.
Nov 24, 2009 | RCA F27636BC 27" TV
I'm simply looking for the most efficient way to hook up my HD-TV with HDMI inputs to both my cable box (with HDMI inputs) and my DVD player/recorder so that I can record from the TV I watch.  ...
The way you have it hooked up right now will not work unless you have a coaxial out on your cable box going to the dvd recorder. Even then, picture quality will be severely degraded. The best way to do it is to leave your cable box hooked up to your TV via HDMI and connect your dvd recorder to your cable box via component video if your dvd recorder has a component video input. If it doesn't, then just use the composite video input. That way your picture quality will be better and you will still be able to record with the TV off.
Jan 02, 2009 | Insignia 37" LCD Flat-Panel HDTV
Video channel
Dear Gonedeep2,
Are you saying the DVD/VCR player does not have a coaxial socket?
Does your TV have RCA sockets to match the DVD/VCR player.
(ie. red and white for audio and yellow for video signals).
Aug 12, 2008 | Samsung DVD-V4600 DVD Player/VCR
How do I hook up a dvd player recorder to my tv, so I can record? thank you DEE
Hi dbird30,
You will notice that your DVD player has two types of cables, one that is three cables in one with yellow, red and white colors; and other that is bigger and cylindrical, we call this a coaxial cable. To record from the TV you must unplugg the TV's cable and plugg it into your DVD player, plugg it where it says 'cable' or 'input'. Now you must connect the coaxial cable it came with your DVD player and plugg it into the DVD player where it says 'to TV' or 'output' and connect the other side of the coaxial cable to the TV. At the end you should see that the cable that was plugged into your TV is now plugged into your player, and the player is now connected through another coaxial cable to the TV.
Jul 12, 2008 | Televison & Video
Hd tv to vcr
What model and manufacturer DVD/VCR combo are you using. if it has a HDMI port, you should buy a HDMI cable to your combo player than to your HDTV (most don't have this High Definition port.) 6f3606c.jpg
 otherwise, it probably contains a composite port, connect the red to the red (Left) white to white (mono) and yellow to yellow (Video) than connect the wires to the matching port on your HDTV) then switch the input to AV or Composite. 9701d83.jpgb5e3eb0.jpg
If this fails, you need a coaxial cable.85dec5e.jpgconnect a coaxial cable to your player then to the coaxial port on your tv. change the input to "either Coaxial, Cable 3 or any input that sets it to coaxial input.
Mar 24, 2008 | Sanyo DVW-6100 DVD Player/VCR
Video input not recognized for LD and DVD
By coaxial, do you mean the composite (yellow)? Either way you have to use the same style no matter what the cable. I mean, if you have s-video's IN to the reciever then you need S-videos OUT to the TV. ....Component IN to the reciever? then Component OUT to the TV. And so on. You cant have composite cords going into the reciever and use a component cord out to the TV (with the exception of a few models).
Sep 10, 2007 | Pioneer VSX-D912 Receiver
Having trouble hooking up my DVD player
Try looking on your tv's menu for "input" or "input select". This should allow you to switch to your front AV inputs. If that doesn't work hook into the coaxial cable in the back of the set (the one for your cable or satellite input. Plug the cable from the output or to tv side of your reciever into the input of the dvd player and run another lenghth of coaxial cable from the output of the dvd player to the coaxial input where your satellite or cable was plugged into the back of your set. When you want to watch a DVD just turn on the DVD player and the picture should come up. When you turn it off your satellite or cable should come right back.
Feb 20, 2007 | Durabrand DWT1905 TV
Televison & Video Logo
354 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
