Question about LG Flatron L1952TX Monitor
Sleep mode how to get sleep mode off monitor
    Brigadier General:
  • LG Master
  • 3,400 Answers
ANSWERD
Posted on Jul 24, 2013
How do i change sleep mode
Sleep Timer Mode
The Sleep Timer mode is an energy-saving feature that enables you to set a time for the monitor to
power on and off at the same time every day. This also extends the life of the backlight bulbs in the
monitor. The Sleep Timer has five settings:
? Set Current Time
? Set Sleep Time
? Set On Time
? Timer: On/Off
? Sleep Now
To set the timer:
1. Press the Menu button on the monitor front panel to display the OSD Menu.
2. Scroll down and highlight Management.
3. Press the OK button to select Management.
4. Scroll down and highlight and select Sleep Timer > Set Current Time.
NOTE: You must set the current local time before you reset the time for Sleep Time or On Time. Note that the time is displayed in a 24-hour clock format. For example, 1:15 p.m. is displayed as 13 hours 15 minutes. A power failure or loss of power to the monitor will cause the timer to reset to 00:00. If this occurs, you will need to reset the sleep timer mode.
5. Press the OK button once to enter the adjustment mode for hours.
6. Press the - (Minus) or + (Plus) button to adjust the hour.
7. Press the OK button again to enter the time for minutes.
8. Press the - (Minus) or + (Plus) button to adjust the minutes.
9. Press the OK button to lock in the time chosen.
10. After setting the current time, the highlight automatically skips to Set Sleep Time. Repeat steps 6 through 9 to set Sleep Time.
11. If you do not want to set Sleep Time, press the OK button twice, then select Save and Return to exit the menu.
12. After setting Sleep Time, the highlight automatically skips to Set On Time. Repeat steps 6 through 9 to set On Time.
13. Set the Timer mode to On to activate the Sleep Timer settings.
14. When you are finished, select Save and Return to exit the menu.
The fifth selection, Sleep Now, turns the monitor backlights off immediately and stays in sleep mode
until the next On Time activates or a monitor button is pressed.
May 27, 2014 | HP Pavilion 22bw Black 21.5" LED Monitor...
I have my acer p205h 20 inch monitor hooked up to my tobshiba laptop and it works great except it will not go into sleep mode when laptop goes into sleep mode the monitor goes to there is not signal check...
Unfortunately, this is a standard problem, as when your laptop goes into sleep mode, it shuts off power to the secondary monitor, without giving it the signal to go into sleep mode. You could try digging around your settings, but most likely you'll just need to turn off the monitor when you're not using it.
Mar 01, 2011 | Acer P205H Widescreen LCD Monitor
When the CPU switch on, the system running upto 10 minutes. after that the monitor screen automatically off.
Here is artical I found on how to disable sleep mode on a monitor, this would be for VISTA or 7, if you are using XP it's a bit different. ____________________________________________________________ How to Disable Sleep Mode on a Monitor
Your computer monitor or laptop screen will enter sleep mode after your computer remains idle for a set period of time. You can disable sleep mode if you prefer the screen to remain illuminated. You merely need to change a setting in the Windows Power Management properties box.
Difficulty: Moderately Easy Instructions
  1. Click "Start" and "Control Panel".
  2. Click "System and Security" and "Power Options". This will bring up a new dialog box.
  3. Click the menus to the right of "Turn off the Display" and set them both to "Never". This will disable sleep mode.
Read more: How to Disable Sleep Mode on a Monitor ' eHow.com http://www.ehow.com/how_6953659_disable-sleep-mode-monitor.html#ixzz1CiGFFyLk
Feb 01, 2011 | Acer AL1916W 19" LCD Monitor
Are screen savers good for TFT monitors
unless the monitors are being turned on and off frequently the sleep mode idea is alot more efficient
Mar 30, 2010 | Dell E197FP LCD Monitor
Monitor going right to sleep mode on start up
Sounds like a bad graphics card. Try using monitor wit another computer and see if the problem still exists. This rules out the display.
Jul 25, 2009 | HP w1907 LCD Monitor
Does samsung monitor save power in sleep mode?Or will it just displays black all over the monitor?
yes, all monitors work directly with the cpu, the cpu sends message to the monitor, so if the system is in sleep mode, automatically the monitor stops work excepts the cpu comes up again then the monitor wakes, in a nutshell, a monitor is connected to power while in sleep mode but has no signal to function
Jul 16, 2009 | Smart Modular SV3170A
HP1965 Monitor in sleep mode
hi there,
just remove the battery, this should solve your problem :)
hope this helps
May 06, 2009 | Computers & Internet
Monitor willnot come out of sleep mode
turn off everything and restart computer in safe mode,do this by holding down f8 as you reboot,then go in your setting and remove time limit on sleep mode.
Apr 10, 2009 | HP w1907 LCD Monitor
My monitor is in sleep mode and I cannot get it out if it.
Sleep Sleep is a mode that the computer enters after being inactive for a set amount of time. Commonly, this mode will turn off a device or set it into a stand-by
Engergy star No data is lost when computer components enter a low-power mode, ... keyboard would get the computer out of this mode. Also see: Power Definitions, Sleep
This should wake your computer, Good Luck/Please dont for get to Vote.Thank you.
Dec 15, 2007 | HP Pavilion F1703 17" LCD Monitor
Won't come out of sleep mode
Is this monitor connector to PC? is yes most probably the problem is the system is not sending signal to tell your monitor to wake up...
Aug 30, 2007 | Sharp 17" Monitor
Computers & Internet Logo
54 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
