Question about Troy-Bilt Genuine Troybilt Roto Tiller Junior Ii Rev Belt 50134
Initial settings ?
Tec. 631918 carb on tec. mod. hs4055580k engine ser. no.2058b
When I give the engine No, all things come back negative but engine is a Tecumesh H35-45430M Ser., 7320B
If you go to a small equipment dealer & give them
the info, you will have your answer & be at the bagel
shop, in a matter of 10 minutes
Your approach is wrong
Go where the info is
There will be a replacement or used carb
if you go to a lawn mower shop, etc
Why not just clean yours & look for a repair kit?
Try Norfolk Power Equipment site
I was on that & others last week, for a 21 year old
RedMax Blower I have
Nov 25, 2014 | Garden
Can you guide me where can I find the right part number for Relay overload starter for my Whirlpool Gold Side-by-side fridge.Mod: GD5YHEXLS01 Ser: SP2325250 MFR DATE:06-03 I am not 100% sure if I rea
Go to sears parts direct web site and put in the model number. Found the page with unit parts our the page that list the compressor. It will have the newest part number
Feb 03, 2013 | Refrigerators
I am having a hard time getting my carburetor adjusted for my Troy Bilt 2 cycle tiller
First you need to repair the fuel inlet properly. You likely have an air leak the way it is now. You can get a replacement inlet elbow at your local parts shop. Tecumpseh and briggs are a bit different but look very similar so be sure what you have before you go. grab hold of the brass with channel locks or vice grips and pull straight out to remove the old one. Put a dab of oil on the new one, align the way you want it to face and press in firmly. Do not twist or it will break again.
Once the inlet is repaired properly then you can adjust the carb. The low speed jet is the one closest to the motor. The initial settings are 1 and a half turns out for both low and high.
Sep 19, 2012 | Troy-Bilt Garden
I have a Samsung SER-6540 II register. An error occurred that locked it up. I am not sure what the clerk did. I unplugged and turned the key to "P" and held down "Cash" key to clear. Now the register reads...
Ok. that's good. You have performed an initial reset that does not lose any data. You must log back on after an initial reset. <div>Find the button marked clerk, clk#, cashier, cash# or similar. This is your log on button. Now type a clerk code (default is 1) then press the cashier button.</div> <div><br /></div> <div>-------------------------------------------------------------------------</div> <div><br /></div> <div>If anyone needs a Samsung SER-6500II or SER-6540II manual, c-tech has them here:</div> <div><br /></div> <div><a href="http://the-checkout-tech.com/manuals/cashregisters/Samsung2.php">http://the-checkout-tech.com/manuals/cashregisters/Samsung2.php</a></div>
Aug 27, 2010 | Casio Parts Cash Register PC Desktop
I have a Whirlpool dryer...Mod nu# WED5800SQ0,
Sounds like your capacitor has stopped functioning. Most dryers have capacitors ranging from 8 to 10 ohms which store energy and give the drum the initial energy boost to start it turning. Unplug the machine and take off the side that contains the motor. in there you will find a small cylindrical object with two connections, thats your capacitor, replace it
May 24, 2010 | Whirlpool Dryers
Ser.A1822837 Mod.106.9507683 Would like to know
total cubic feet is 18 cubic ft according to serial number
Sep 08, 2009 | Refrigerators
Snow Blower engine runs very rough
YES THE CARBURETOR CAN BE OVERHAULED
THE REPAIR KIT PART # IS 31840 , THE BOWL IS REMOVED BY REMOVING THE BRASS NUT ON THE BOTTOM WITH A 7/16" WRENCH.YOU MAY NEED TO REMOVE THE WELCH PLUGS FOR A GOOD CLEANING. NEW PLUGS COME WITH KIT. YOU CAN SOAK CARB. IN CLEANER SHOULD BE NO LONGER THAN 15 MINUTES. ALWAYS USE NEW GASKETS. ADJUSTMENTS TO BE DONE WHEN ENGINE IS WARMED UP.
Jan 26, 2009 | Garden
Troy-Bilt Genuine Troybilt Roto Tiller Junior Ii Rev Belt 50134 Logo
41 people viewed this question
Top Troy-Bilt Heavy Machinery Experts
Mike
lnbn1975
itsman
Are you a Troy-Bilt Heavy Machinery Expert? Answer questions, earn points and help others
