Question about Whirlpool Dryers
Do i need to hook up the water supply to use this dryer
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
Only to make a coffee while it is drying
Posted on Jul 24, 2013
Can I use my whirlpool DRYER without hooking up water ,I am unable to hook up water to the dryer
Your dryer does not have a water hookup therefore the dryer does not need to have water connected to it
Nov 27, 2017 | Whirlpool Dryers
Aquarius 1200 washer/dryer WD62. Why isn't it washing/rinsing clothes properly?
If your washer /dryer is correctly connected to hot and cold water supplies, replacing the fill valve would be a good place to start.
Mar 26, 2016 | Hotpoint Washing Machines
Do you need to do anything special when setting up a tumble dryer like hook up to water supply or anything
Dryers usually need either 240 volt electricity or gas for the heat & a vent to the outdoors.
Gary
Sep 09, 2011 | Dryers
I just got an LG TROMM DIE2512W dryer. I have a power supply cord with three cables (green, black and white) good for 120v.15amp. The green cable is my ground. I connected the black cable from the power...
If you have a red wire then the dryer is a 240v dryer and needs a 240v 30 amp circuit...
Here is the manual for your dryer and it shows the hook up you need on page 17...or part 5 of the manual...
Click here
heatman101
Jul 31, 2011 | LG DLE2512W Electric Dryer
What hose do i hook up to the sink in order to start the wash cycle the black or grey or both?
If the washer has 2 seperate hoses, then you need to connect both hoses, if only 1 hose, then hook up tp the cold water supply.
Pl;ease leave feedback.
Thanks.
Nov 15, 2009 | Malber WD1000 Front Load Washer/Dryer
Dries very slow lint is clean have to run and run to dry
make sure the outlet tubes are also clean, also rinse off the lint screen with hot water, softener will clog it and not allow propper air flow, the water wil bead up on the screen if this is true, just keep rinsing till water flows freely
Nov 09, 2009 | Whirlpool LER4634J Electric Dryer
No water
water supply hooked up?could be water valve.
Jan 19, 2009 | GE 15" Laundry Pedestal for Horizontal...
Water comes into machine when on dryer clothes tak forever to dry
This machine drys by intermittently spraying a mist of cold water into the warm, moisture laden air traveling in the tube at the back right side of the machine. The cooling of that air stream causes moisture to condense and join the added water, which is periodically pumped out the drain. It takes a long time, and the clothes are not as "dry" as you may be use to with a conventional dryer. Never try to dry more than a half tub of laundry. These machines are great if you have small amounts of laundry to do, have limited space, and / or do not have 240 volts, (or a gas supply) and cannot do an outside vent. Don't plan on doing more than two loads per day. (one in AM, one in PM) Please don't bother rating, as anything but a Fix-Ya will lower my score. Thanks.
Jan 17, 2009 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Neptune dryer
there is no transformer in the dryer, i am guessing you have a 110 v motor and when you hooked the plug wrong, you could have supplied the motor with 220 v that's why you can smell something burnt.
the heater is 220 volts. regular dryer has dual voltage supply. 110 v and 220 volts.
tnx 4 using fixya,
drcool
Sep 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Open Questions:
Dryers Logo
35 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
