Question about Olympus ? Tough 3000 / Stylus Tough 3000 Digital Camera
SD card is stuck!
I have a STYLUS TOUGH-3000 digital camera. A few days ago it was working fine, I took pictures all weekend. Yesterday I tried to connect my camera to my computer and it was unresponsive with the USB connector cord. I unplugged it and then the camera would not turn on. Additionally, the SD memory card will not eject. I push down on it and it pops up but then I try to pull it out and it seems to be stuck. I am more concerned that I can not access the photos on the SD card than the actual functionality of the camera. What can I do to resolve this problem? If I send it in for repair will this problem be solved? I look forward to your feedback and hope that this will be resolved asap. Thank you.
SOURCE: pictures appearing black- olympus FE 170
You checked the obvious, lens cover? (sorry had to ask) any grinding noises when you take a picture or focus\zoom?
Posted on Aug 26, 2007
  • 919 Answers
SOURCE: When i turn my digital
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the card full message and the card can be used again.
Posted on Dec 22, 2008
fathitkf
  • 1871 Answers
SOURCE: USB cord (for Olympus Stylus 790) not recognized on computer
Hello :
The problem is not with the cord . But it's with the computer .
I'll give a solution assuming that you are using [ Windows XP ] as an Operating system . This can also go with [ Win 7 or Win Vista ] .
1: Go to start
2: Go to all programs
3: Go to accessories .
4: Go to system tools .
5: Click on [ restore ]
Now you will see many restoring points . Try to remember which point or time the ( Olympus Stylus ) was working fine .
6: You need to restore your system to that point or time .
7: The system will restore itself to the point you chose and will reboot .
8:After rebooting plug in your Camera USB cable to try if that worked or not . It should work . If not , then the problem is with the Camera . For that you need to reset the Camera and try again .
If that didn't help , then there must be a hardware failure with the camera and it needs to be serviced .
Please don't forget to rate !
good luck .
Posted on Apr 08, 2010
welcomejee
  • 10594 Answers
SOURCE: I just purchased an Olympus
Olympus Stylus Tough 3000 prints date on image if you connect it directly with printer to get print out of pictures. Printer must have PictBridge mark to receive picture data directly from camera. Usually this type of printer calls photo printer.
Olympus Stylus Tough 3000 does not show time/ date stamp in picture files either in camera playback or transferred in computer. It only prints date info while printing photos through photo printer.
Connect camera with printer and select Custom Print in setup/ print mode, you will see Date option (with/without) to get photo printout with desired info.
Above info also available in user manual, check page-54 fro more details. Click HERE to download related user manual free copy.
Hope these info will help you.
Thanks.
Posted on Oct 30, 2010
  • 304 Answers
SOURCE: Whenever I turn on my
Hi, when ever I've seen that message it means the camera wasn't properly sealed when it was taken underwater. There isn't a way to fix that unfortunately you'll have to get a new camera and in the future make sure everything is sealed up tight before taking it in water.
Posted on Jul 03, 2011
My camera doesn't see SD 16GB anymore. Worked fine until a few days ago. SD works fine on PC
Try inspecting the memory card slot, eventually with a magnifying glass. Sometimes just a little bit of dust, a small paper or other debris, can block data transfer. Be sure al contacts on the card, but also in the camera are clean and shining. Never use sharp tools in or around a camera. Don't scratch the contact points.
And to make sure you can put pictures on a memory card, there must be space. If possible try to format the card in the camera. Just to make sure the camera sees the correct file system on the memory card.
Dec 15, 2013 | Panasonic Lumix DMC-FZ28 Digital Camera
Olympus stylus tough 3000 digital camera my screen is white
Sound like a CCD sensoir problem, this job will need solve in the repait shop.
Jun 17, 2012 | Olympus ? Tough 3000 / Stylus Tough 3000...
IPICS ON SD CARD DO NOT SHOW ON PLAYBACK OLYMPUS 8010
Many cameras will only display pictures taken by that camera (or at least the same model). Also, if a picture has been edited in any way (opening a pic in a photo editor and saving it without making any changes counts as editing) then the camera will not display it.
Feb 21, 2012 | Olympus Stylus Stylus Tough 8010 / mju...
My olympus stylus tough 6020 keeps telling me card error and will not do anything else. can i fix this ?
Here is what I found on my Stylus 6020. I have the same problem. In the card reader, there are about 9 fine wire contacts sticking up that brush against the SD card when inserted. By shinning light into the empty SD slot, I found two contacts in the middle are either pushed all the way down or have broken off thus causing a card read error. Only 7 or the nine contacts are touching the SD Card. I do not have a solution for this problem other than warranty. This camera is fairly new and has incurred no damage.
May 19, 2011 | Olympus Stylus Tough 6020 / mju Tough6020...
I have a new Olympus Stylus Tough-3000. Half of my vacation pictures have disappeared. When viewing the pictures there is a frame called "Picture Error" . I had viewed the pictures...
You can use a card reader to try to download them to your computer. You could also take the card to a store like Walmart and use one of their picture making machines.
Feb 27, 2011 | Olympus ? Tough 3000 / Stylus Tough 3000...
I cannot get the xd-picture card into my olympus stylus tough -3000
If I'm right in your photo doesnt go xd card, it uses sd memory card?!
Jan 25, 2011 | Olympus Cameras
Sandisk micro SD "card error"
The five pics are being stored on the camera's internal memory. The card you used was formatted and used in your phone. It's a miracle it worked at all. You need to get a new card, format it in your new camera have fun.
Dec 28, 2009 | Olympus FE-46 Digital Camera
Open Questions:
See all Olympus ? Tough 3000 / Stylus Tough 3000 Digital Questions
Olympus ? Tough 3000 / Stylus Tough 3000 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
