Question about Radio Shack Pro-2052 Scanner
Static stays stact on channels
What band do I set toget the best
we are talking about cb radio here aren't we ? there is no best band on a cb, just static and skip all day long. But find a local channel and introduce yourself and stay on that channel .If you are asking about side band then usually its channel 38 lower side.
Feb 12, 2015 | Radio Communications
Sanyo Dp19649 screen wont stay on, just sound. when i look close with a flashlight i can see the static from static channel it on. what i do?
Back-light inverter fault. Contact any service technician. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 28, 2014 | JVC LT-32X576 32 in. LCD Television
2004 Hyundai is running hot. Where is the therm a stact located
the thermostat is hiding under the top rad hose housing,
Jul 06, 2010 | 2004 Hyundai Elantra
Behringer xenyx 802 static in left output
if its only on left channel you have to change the ic output from that channel.
Jul 08, 2009 | Audio Players & Recorders
When changing channels sporatic static,
Please feed again cable channels in TV by selecting Auto Search / channel preset in TV Menu.
This will update channel data stored in TV memory.
Mar 18, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Weird message on the tv
Just letting the TV run for about ten minutes while it "thinks" seems to be the best answer. The more I tried to do, the longer it took. But just letting it stay on and sit for a bit it eventually switched over to static, and from the static I was able to get back to the channell with cable.
Dec 24, 2008 | Sanyo Vizon LCD-15A2 Television
Please explain the working of this code
It's a Java http server (webserver) that serves random "prices" if they match a search string.
Well here is an explaination:
private static String[] symbols = {"DELL", "INTC", "MSFT", "ORCL", "SUNW"};
These are search strings
private static Random rnd = new Random();
This generates a random number
private static Charset cs = Charset.forName("UTF-8");
This is the charset that the http server uses
ServerSocketChannel server = ServerSocketChannel.open();
Create a new server
server.socket().bind(new InetSocketAddress(8055));
Bind the http server to port 8055
The rest is handling the request and processing it
But here:
if(Arrays.binarySearch(symbols, symbol) >= 0)
response = "Price is " + (1000 + rnd.nextInt(9000)) / 100.0;
else
response = "Price not available";
channel.write(cs.encode("HTTP/1.0 200 OK "));
channel.write(cs.encode("Content-type: text/plain "));
channel.write(cs.encode(response));
channel.close();
It sees if the string input matchs: DELL INTC MSFT ORCL SUNW.
(private static String[] symbols = {"DELL", "INTC", "MSFT", "ORCL", "SUNW"};)
If so, it gives a price based on a random number.
response = "Price is " + (1000 + rnd.nextInt(9000)) / 100.0;)
Or else
It says "price not available"
then it gives a html header to end the error message.
Hope I helped you :)
Gook luck
Nov 26, 2008 | Computers & Internet
Vcr recording
if there is a cable box hooked up to this vcr, the vcr needs to stay on channel 3 to record.the output of the vcr either hooks up to the tv from the coax out , or from one of the other possible outputs such as rca cables [red, white, yellow] to one of the tv's aux/video/line in or source inputs.
wg
Feb 05, 2008 | Televison & Video
Radio Shack Pro-2052 Scanner Logo
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
