Question about Radio Shack Pro-2052 Scanner
Nothing but static
Static on channels
No noise static nothing
does it light up the front panel? If not did you accidently touch something that created an overload that may have caused the reverse polarity diode to blow?
Mar 01, 2014 | Radio Shack Powered ON TRC-444 40- Channel...
Tv picking up channels except its all static, colorless, and loud static noise..
If the set was purchased in the USA it has the USA format which is NTSC--unless the signal is NTSC picture will be in black and white and no sound.
If the signal format there is PAL OR SECAM you will need a converter that takes that and outputs NTSC for the set to work properly there.
May 16, 2012 | Panasonic Viera TX-32LX70 32 in. LCD TV
Static
My friend, we are all volunteers and we (the people who answer quesitons) work from our homes. Collectively, we are pretty good at what we do ... the pay ... is nothing. The incentive ... to help other people solve their troubles.
So,. now that I have a question to answer, I will say your telephone is capable of transmitting on one of several channels. You will have to dig through the menus or the owners manual for specific instruction on how to change the channel to one less prone to what ever the static source is in your home.
Things that cause static: microwave ovens, computers, flourescent lights, motors, cell telephones, garage door openers, CB (and other frequency) two way radios. Sometimes you can reduct static by reversing the plug in the outlet (the power cord I'm speaking of). Sometimes you can reduce static by moving the base station to another location.
I hope I have shed some light on your problem.
Thank you for your interest in FixYa.com.
Feb 12, 2010 | Avaya 2410 Corded Phone
I am having major static on both hand sets. I have reported to the phone company. This has just started to happen in the last 2 weeks. I have nothing new electronically. My land phone plugged in is not...
It is possible one of your neighbors purchased a similar phone and you are on the same channel.
Check your instructions and see if you change the channel.
I hope this helps.
Jul 17, 2009 | Uniden DECT 6.0 Cordless Telephone...
Static on all cable channels
The tuner is questionable The problem lies inside the isolation box. Ask a repairman to open this isolation box and resolder the small board. There are two small resistors that need resoldered. This also has the rf connector on it. And you may have him resolder the tuner if this does not fix it. Have him inspect any and all grounds on the main board as well. Good Luck
May 31, 2009 | Toshiba CF32F50 TV
Please explain the working of this code
It's a Java http server (webserver) that serves random "prices" if they match a search string.
Well here is an explaination:
private static String[] symbols = {"DELL", "INTC", "MSFT", "ORCL", "SUNW"};
These are search strings
private static Random rnd = new Random();
This generates a random number
private static Charset cs = Charset.forName("UTF-8");
This is the charset that the http server uses
ServerSocketChannel server = ServerSocketChannel.open();
Create a new server
server.socket().bind(new InetSocketAddress(8055));
Bind the http server to port 8055
The rest is handling the request and processing it
But here:
if(Arrays.binarySearch(symbols, symbol) >= 0)
response = "Price is " + (1000 + rnd.nextInt(9000)) / 100.0;
else
response = "Price not available";
channel.write(cs.encode("HTTP/1.0 200 OK "));
channel.write(cs.encode("Content-type: text/plain "));
channel.write(cs.encode(response));
channel.close();
It sees if the string input matchs: DELL INTC MSFT ORCL SUNW.
(private static String[] symbols = {"DELL", "INTC", "MSFT", "ORCL", "SUNW"};)
If so, it gives a price based on a random number.
response = "Price is " + (1000 + rnd.nextInt(9000)) / 100.0;)
Or else
It says "price not available"
then it gives a html header to end the error message.
Hope I helped you :)
Gook luck
Nov 26, 2008 | Computers & Internet
I get static after someone else talks
One of the main causes of static can be a bad battery. If you are using rechargeable batteries you need to replace them every 14-18 months. If you are using alkaline batteries, they have been known not to fully power the radio once your cross the 10 hour mark. Your radio would then be operating in somewhat of a brown out. This would lead to static.
Another cause of static is simply being nearly out of range of the other radio(s).
The burst of white noise at the end of Rx on some radios can be rather annoying. On the basic talkabout radios there is nothing which can be done to solve the problem, other than replacing the radio.
Jul 26, 2008 | Motorola Talkabout T5700 AA (22 Channels)...
Speaker problems
You've probably tried this, but when you do the channel test you can turn the volume up or down on whichever speaker is currently being tested (the static). Maybe your speakers have been adjusted somehow.
Jun 08, 2008 | RCA RT2300 System
Radio Shack Pro-2052 Scanner Logo
41 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
