Question about Zebra GX430t Thermal Printer
Zebra GX430t doesn't print last label
We have multiple Zebra GZ430t at multiple sites. When we submit print jobs of more the ~30 labels the last label doesn't print. The printer shows no errors, doesn't need to be reset. If the last label is resubmitted separately it prints fine, but that's a time consuming work around. The next job can be sent right away and will print without issues.
SOURCE: Print Width Issue
the issue you are having is DPI related, when data is sent to the printer and rendered it is dot for dot, so a Z4M 203dpi printer has about 800dots on the printhead where your printer has about 1200dots on the printhead. so when your software prints to dot800 thinking it is the edge of the label it is infact at 60%. there sould be an option in the software to configure around this. if not the is an option in the printer to convert DPI setting ie 150>300 or 100>200 and so on. but i don't thing you can make a 300dpi print as 203dpi
best of luck
Posted on Dec 07, 2007
SOURCE: My printer display keep showing " Warning, Ribbon in", cannot print multiple label at a time
i have the same problem , but my printer is ZEBRA S4M ZPL
my solution is:
in your barcode software: change printer settings: 1 and 2
1 . in media setting : change media type --> Thermal transfer
2. in documents options , configuration --> use printer settings
by Lin Yu Hsien
Posted on Dec 10, 2008
  • 32 Answers
SOURCE: Sent too many labels to printer - need to reset
As the previous expert has stated, with the printer paused, press the cancel key to cancel the job. One thing to note, is depending on how your software sends the print jobs, you may say print 1000 labels, but the software sends it one at a time, so basically you have 1000 print jobs in the printer. If you pause the printer, press and hold the cancel key. Hold it for about 2 mins. This should clear the buffer.
Posted on Oct 27, 2009
  • 185 Answers
SOURCE: ZEBRA Z4M PRINT QUE ERROR
I would say the printers buffer has overflowed, try looking around for a Print Buffer to hook up to the printer. The standard Flash is getting very hard to find.
Posted on Oct 29, 2009
seeker5211
  • 1089 Answers
SOURCE: LP2844 printer stops after one page with out of paper error
Did you try to reload the labels. Pull the labels out and clean the paper path
Posted on May 07, 2010
Why is the text printing on Zebra LP 2844-Z label incorrectly spaced?
Zebra printers are not really made to print PDF files, if the only option is PDF I'd recommend switching to print on a laser. Also open the PDF and see if they are correct in the original doc
Oct 06, 2015 | Zebra Office Equipment & Supplies
Zebra GX430t, print two blank label when switch on
this is because printer calibrates every time u power on, this is a default setting, and its good if u using diferent labels all the time. you can change the settings thought driver,and change (when power on - "doing nothing" dont forguet to reboot Thanks Paulo.
Apr 08, 2014 | Zebra GX430t Thermal Printer
2 partial labels being printed on 1 label
most likely to do with sensor --- label has a notch in it it in middle make sure it is clean --- do labels have a hole that align with sensor?
Look at Cleaning printer to locate sensor
http://www.zebra.com/content/dam/zebra/manuals/en-us/printer/ql-qlp-qrg-en.pdf
Mar 18, 2013 | Zebra QL420 Plus Portable Thermal Barcode...
How to cancel labels
Aaron:
When multiple tags are waiting to print, to cancel should press the CANCEL button for more than five seconds. Also cancel print job in Windows spool. Roberto Martinez Mexico padrino99@prodigy.net.mx
May 31, 2011 | Zebra Z4Mplus Label Printer
How to reset IP address on GX430T label printer
http://www.scanonline.com/pdf/PrintersZebra4/GX420t/ProductDocumentation/980612-001A_GX420tUGen.pdf Here is the manual it will tel you how to go about resetting the Ip address on this printer, If its connect to your RJ45 cable or you have a print server you will need to reset it using other means but this should set you on the path to help here, thanks please do not forget to leave a rating.
Aug 03, 2010 | Zebra GX430t Thermal Printer
May 07, 2010 | Zebra LP 2844 Thermal Printer
Eltron 2844 prints previous job over and over
Make sure the label size is correct, if the print encounters a gap before it is complete; it will re-print the same label. In MS Word make sure the page size is set to the correct size including any headers and footers and Width etc.
Sep 17, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra printer 140xilll - Too many print jobs?
It does sound like you have a memory overload when you send the 2nd print job. Each label is getting sent to the printer and filling up the memory. Make sure you are using the printer resident fonts and not a regular windows font. The windows fonts get sent down as graphics and take up memory. What zebra is saying to do is store the format of the label in the printer memory and then just send down the information that changes. For example if you were printing a UPS label the basic format of the label is the same but things such as the addresses and tracking # would change.
Jun 23, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Z6M printing issue
try adjusting the presure of the printhead
here is the site for the manual
http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
good luck
Dec 12, 2007 | Zebra Z Series Z6M Thermal Label Printer
Zebra GX430t Thermal Printer Logo
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
