Question about Vehicle Parts & Accessories
Cobra car alarm
Globe 3800 on locking with the fob 2 buzzers then 3 buzzers why,and alarm goes off after some time
jyackle5
  • 8197 Answers
SOURCE: pairing new alarm fob to cobra 777
Turn ignition key on and off around 5 times or till you here the alarm then hit the left and right button on fob till you here the alarm again then it is set. if you have 2 remotes you need to do them both at the same time.
Posted on Apr 07, 2009
  • 37 Answers
SOURCE: Alarm in a 2004 Ford Escape
Not a complete solution but something to try .Using the key lock and unlock the vehicle from the drivers door .Some models in UK have an arm switch on the lock barrel in the door which sticks.
HTH
Posted on Nov 14, 2009
  • 242 Answers
SOURCE: we have a cobra alarm on our car and its causing a
take red lead of battery then hold down the remote while you re attach the red lead and that should reset it
Posted on Dec 29, 2009
dancandoit
  • 436 Answers
SOURCE: I have a Mitsubishi FTO with a cobra car alarm
hold down both buttons on the remote till they stop flashing, then press left then press right, this will recode the remote to the alarm. if this dont work try new batteries, if not then find an engineer.
Posted on Jan 03, 2010
  • 139 Answers
SOURCE: alarm worked fine then 3clicks from the "brain"
Your system is in valet mode. Depending on the brand and model, the procedure to turn off valet mode will differ. It can be as simple as flipping the switch or pressing a button. Or require a more complex set of steps that may involve the ignition switch and a combination of presses of the valet switch.
Posted on May 09, 2011
How to reset my cobra alarm without a fob after push button in cab was activated. I have code.
Go to the cobra site, trouble shooting. Never have put an alarm in. But have tore out hundreds of them. Anytime I get a No start or problems like yours. I look under the dash for after market alarms and remote starts. I would tell you up front, That system has to go. 99.5% of the time, when I take them out and fix the wiring. The cars starts and has no problems. The best alarm systems last 5 to 7 years. Cheap ones, your lucky to get a year out of them. Like I said, when I see them, they have to go before I do anything else.
Jul 28, 2016 | Ford Cars & Trucks
I have an 05 Outlander with a post manufacture cobra car alarm. Both of my fobs have stopped working - at same time! Immobiliser still works but cannot put alarm on. I am having to lock the car with the...
When both stop working in the same time, you should not look at the fobs, but to the receiver or the logic in the alarm system in the first place. Like if two key don't fit in the lock, anymore, the keys did not change, but the lock.
But perhaps you should ask a tech to solve this problem. To diagnose this one is a bit difficult not being on the car myself.
Jan 14, 2015 | Cars & Trucks
Ive got a 2000 st24 and having problems with my key fob and alarm, key fob now not working changed batteries no difference, alarm goes off all the time, sometimes u can play a tune with the alarm ie...
I would look into getting a new key fob and having it programmed to the vehicle. If not tben use the key and lock unlock the door to deactivate the security
Nov 08, 2014 | Cars & Trucks
I just had to have battery replaced in 08 cobalt, now keyless entry will not work, had batteries replaced in both fobs, neither is working. Cant arm the alarm at all, have to manual unlock doors, and...
key in ignition 2 number 2 then press the fob. till doors lock. 2 to 3 times then unlock with fob. turn back key lock car. then un lock. then do the same with the other fob.
Feb 22, 2014 | Cars & Trucks
Key fob wont re set on my ssan yan rexton
I recently changed the battery on my key fob for my ssanyong rexton. I then did the following for the key fob to make it work. 1. Enter vehicle and close all doors.
2. Put seatbelt on (or clip it into the buckle) to shut the warning buzzer off.
3. Put key in ignition, turn to run position but don't start it.
4. Press and hold both buttons on key fob until red light on fob stays on. Then let go of both buttons. Then pressed the alarm button then the panic button, somthing like that. To be fair the button sequence after the red light came on is a bit vague. The alarm was blaring so i was happy when it just stopped.
May 23, 2012 | SsangYong Rexton Cars & Trucks
How do you turn off the HWS alarm on a makita bmr100
A beep tone will activate when selecting the HWS buzzer
alarm.
The alarm beep will become shoter and shoter every
15 seconds for one minute followed by one minute silence
before repeating the cycle.
The HWS alarm will sound for one hour until turning off by
pressing the Power button. Press the Power button whilst
the alarm is activated will cancel the alarm for 24 hours.
1. The HWS buzzer alarm can be set either radio is on or
off.
2. Press and release the HWS buzzer alarm button
, the symbol will flash.
3. During the symbol flashes, long pressing the
button for more than 2 seconds followed by a beep
and display Hour digit will flash.
4. Rotate Tuning Control to select required alarm hour,
then press time set button again. The minute
digit will then flash.
5. Rotate Tuning Control to select required alarm minute,
the press time set button again to complete HWS
buzzer alarm setting.
6. Press and hold down buzzer alarm button for
more than 2 seconds followed by a beep to switch on
or off the HWS buzzer alarm.
Display will appear when buzzer alarm has
been set.
May 25, 2011 | Car Audio & Video
Pairing new alarm fob to cobra 777
Apr 07, 2009 | Vehicle Parts & Accessories
Key fob will not undo cetral locking or disable car alarm changed battery in key fob still having no luck any idea who can re code key fob to central locking and alarm?
If you don't have one that works for the vehicle now, you'll have to take it to your local dealer to have it programmed to the vehicle. Some will charge for this, some will do it at no charge.
If you do have a remote that is programmed and working for the vehicle, then the following steps will allow you to program another remote:
4. Press and hold the unlock button on the working key fob and hold for 4 seconds, then also press the panic button.
5. Release both buttons and you should hear a single chime to indicate it is in program mode. You have 30 seconds after the chime to program any additional remotes you want to program.
6. Press and release both the unlock and lock buttons simultaneously on the remote you are programming. You should hear another single chime.
7. Within 4 seconds after hearing the chime, press either lock or unlock button on remote that you are programming.
Oct 16, 2008 | 2001 Chrysler PT Cruiser
Cobra 7928 car alarm
hold both buttons down until led goes out. let go. led will stay on.
press large button twice.
actually
May 05, 2008 | Car Audio & Video
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
