Question about LG LMN125HVT Air Conditioner
What does code CH24 mean - LG LMN125HVT Air Conditioner
What does the trouble code 70 h95 mean
What does the trouble code 70 h95 mean - Fixya
www.fixya.com/support/t25932829-trouble_code_70_h95_mean
28 mins ago - what does the trouble code 70 h95 mean - Bowflex Treadmills question.
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - Please refer to the following table if your LifeSpan treadmill is displaying an error code. If after trying the suggested solutions your treadmill is .
Oct 30, 2015 | Bowflex Exercise & Fitness
Engine codes for a 1998 plymouth voyager
okay, 1998 voyager these are not obd2 codes, these are genric codes, you used ignition to get these .
these codes are for older models that use codes like these 12 35.
the newwer obd 2 use codes like po 013. i will try to see what i can find, also the engine size is important.
okay here we go, the first code is 12, this code means the battery was dead or dissconnected.
the next code 35. this code means loss of prime, code # 11
means internal transmission failure.
the code 55 means gear ratio error.
these codes would tell me that you have transmission problems. this may mean internal trans failure and a rebuild or replacement transmission is needed or shift pack needs replacing. anyhow i would have a shop check this out, these van are known for transmission problems. hope this is helpful good day
Feb 03, 2013 | Plymouth Voyager Cars & Trucks
Lg p930 unlock
if it's asking for a PUK code, you have to speak to your operator
Aug 16, 2012 | LG Cell Phones
Code error
If the Nokia 7210 says Code error means you entered the wrong code,It's Network Unlock code or security Unlock code?Network unlock code means you can have only 5 Unlocking tries ,if you missed means it get hard locked ,so cannot unlock using the unlock code,get the correct Unlock code from the site
Unlock-free.com/nokia/nokia-7210.html and Unlock from Network lock,You need to unlock from security or password lock means get the master reset code for Nokia 7210 at here and reset it.You can also try default code 12345 or 1234 or 0000 if not works means get the master reset code and reset it.
Dec 12, 2011 | Nokia 7210
What does CH 24 mean on ArtCool mini-split?
Ch24 means your unit has a low or high pressure fault,check gas charge and if filters are clean see if helps
Aug 31, 2011 | LG Art Cool LA121CNP wall/window Air...
I recently purchased lg dehumidifier. it worked for a while then stopped working it displays the following ch24
For whatever reason, LOG does not list any information on Error Codes. To find out what CH24 indicates, contact LG's Support Representative at (800) 243-0000.
In the meantime, turn the unit OFF & unplug it for 15 minutes. Then plug it back in and turn it ON. During that 15 minute timeout, the electronics may have reset themselves and reverted back to the original factory settings. From there, you can set them as you like.
Hope this helps you and thanks for choosing FixYa.
Jul 27, 2011 | LG LHD65EBL Dehumidifier
My phone is asking for an input np code
It's asking for NP Code means Network provider code,that means Unlock code,If the Mobile locked to other Network means you trying to insert other Network Sim means it asks for Unlock code or NP Code,Unfreeze Code,subsidy code,Special code,NCK code,MEP Code etc...It depends upon the Brand of Mobile..so specify the Mobile Brand ,model,network,country it locked now,IMEI number and get the Unlock code at
Unlocking4u.com and Unlock it...
Jun 04, 2011 | Cell Phones
System 3 in-door with system 4 out door inverter. all in door unit show error code CH24 pls help
CH 24-Splits and Multi Splits = High or low pressure trip. Low at 1 bar High at 35 bar check pressures. Multi V = High pressure trip.
Nov 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Lg split system ch 05 error outside fan not working
Solution # 1, Check Condensor Fan Motor Capacitor 4uf or MFD
# 2, Check Motor Windings
# 3, Check Relay OR Defination Contactor
# 4, Check Connection Terminals
hope will help u 2 solve this
GOOD LUCK
Jan 26, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Control pad is inoperable - message reads ch24 - what can I do
E-mail the manufacture for specs and codes! Thank-you-very-much!
Aug 26, 2008 | LG Heating & Cooling
LG LMN125HVT Air Conditioner Logo
14 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
