Xerox 8750 with error code 94,700.00:1441
When Printer is warming up i get this error code and the machine turns off.
  • 2072 Answers
SOURCE: xerox 390 error code 1
> Support & Drivers > WorkCentre 390 Laser All-in-One Support > Search Results > How To Clear a Fuser Error Message Solution: Perform a RAM Clear bttn_print.gifMake Printable bttn_email.gifEmail this page elem_1_spacer.gif Performing a RAM Clear will restore all of the WorkCentre's settings to the factory defaults. It will also clear all faxes in memory, Speed Dials, One-Touch Buttons, Group Speed Dials, your System ID, and any other stored information.
NOTE: If you are able to print, it is a good idea to print out your Phone Book before performing the RAM Clear, to assist you in reprogramming your Speed Dials and One-Touch Buttons. It is also recommended to print out your System Data List to assist you in reprogramming your system settings. If you are not sure how to print your Phone Book or System Data List, refer to Related Items at the bottom of this page.
To perform a RAM Clear:
  1. Press the [Menu] button on the Control Panel.
  2. Press the [#] key, then press 1934.
  3. NOTE: These buttons should be pressed quickly. If not successful, try varying the speed you are pressing the buttons.
  4. When this step is successful, the bottom right-hand corner of the LCD Display will read 'TECH'.
  5. NOTE: If you are unable to access Tech Mode, please refer to Related Items at the bottom of this page.
  6. Press the [Menu] button to start navigating the menu.
  7. Press the [Up] or [Down] arrow button until the LCD Display reads 'Memory Clear', then press [Select] button.
  8. The LCD Display will read 'US and Canada'.
  9. Press the [Start] button to clear memory.
Posted on Jan 19, 2008
  • 2072 Answers
SOURCE: xerox printer error code (04,025.46)
This is a print head position issue.
TRY FIRST (Solutions without parts):
1. Check that the wipe mechanism has homed. 2. Check the printhead position and verify that it has initialized properly / manually home the printhead and power cycle the printers power and check for the error to return. If not then the error was most likely due to non-process function (something out of sequence).
Part likely to be the cause:
GEARBOX AND MOTOR,PROCESS DRIVE - PL 4.0, Item 14.
Posted on Jan 21, 2008
  • 2072 Answers
SOURCE: Xerox 8550 Error message 19,003.48:121016
19,003.48 Scale and offset voltage error too large. Something is wrong with the Electronics Module or Wave Amplifier.
that is pretty straight forward. More then likely the elsctronics module has failed. Wave amplifier is pretty unlikely.
If you do not have a maintenance agreement or under warranty, that is a very expensive module to replace.
Check @ 1-800-835-6100 to see if you are under warranty or have coverage.
Posted on Apr 22, 2008
pdouglasss
  • 125 Answers
SOURCE: XEROX 8550 7,010.43 error code
Hi guitargurl:
Your printhead is stuck in the tiltposition,or is not able to tilt forward to the print position, due to another problem with a motor
7,010.43:
The printhead is stuck in the tilted position, or is not able to tilt forward to
the print position, due to problems.
7,011.44: This is a soft fault, and will not halt the printer.
7,012.45: The drum transfix home sensor is still in a not homed position, after the
return home motion has been completed.
7,014.47: The printhead is not locked in the head tilt restraint spring.
7,015.43: The head tilt restraint spring is out of place.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Reboot the printer.
2. Did this correct the problem?
Complete. Go to Step 2.
2 1. Do the printhead lock arms rotate correctly? Go to Step 3. Repair/replace
the lock arms.
3 1. Has ink spilled ink around the printhead that
prevents the printhead from moving to its
center position? You should be able to
manually push the printhead right to left.
Clean the
printhead area.
Go to Step 4.
4 1. Does the X-axis motor drive the printhead to
it’s center position (so it can tilt forward)?
Go to step 5. Troubleshoot
the X-axis
drive.
5 1. Check the process gearbox for obstructions
or damaged.
2. Ensure the gears are correctly aligned and
homed.
3. Verify the process shaft and drive module
shaft are at their home positions.
4. Did this correct the problem?
Complete. Go to Step 6.
6 1. Has ink spilled on the head tilt gear on its
drive train (near left side of the printhead).
Clean the
gears.
Go to Step 7.
7 1. Use service diagnostics to run the Head
Maintenance Wiper Clutch
test.
2. Did the test fail?
Replace the
wiper drive
clutch.
Go to Step 8.
8 1. Ensure the wiper is properly aligned.
2. Use service diagnostics to run the Wiper
Drive
Test.
3. Did the test fail?
Replace the exit
module
assembly.
Go to Step 9.
9 1. Use service diagnostics to run the Load
Maintenance Clutch
test.
Inspect the
maintenance
drive system,
replace any
defective parts.
Posted on Jan 09, 2009
  • 49 Answers
SOURCE: Xerox Phaser 8550 printer error 09,037,45:23780
This means the Yellow ink sticks are jammed in the machine, open up the top of the machine and check if the sticks can slide freely up and down and remove any broken sticks.
Niallbt
Posted on Mar 31, 2009
Xerox Phaser 8550 error code 07,01043:90804
This fault occurs due to the printhead being stuck in the tilted position. There are many reasons why this fault will occur, too many to mention.
More often than not, your problem will require the printhead and process gear to be re-aligned in order to get a reboot but sometimes it is possible to get a reboot by doing the following;
Turn the printer off, wait ten seconds then turn it back on again. Wait for the printer to start warming up to about 5 or 10 percent. At this point, switch the machine off again by the machine switch NOT your wall/plug switch. Wait ten seconds and switch on again. Now let it run through its normal cycle. The success rate for this method is small, possibly only 1 in 30 machines will recover.
The reason this will sometimes work is that, when you turn the machine off from the warm up, it powers down using its proper head parking routine, you will notice, it takes a while to shut down. If the original fault was due to say a power cut or someone pulling the plug out it is possible for the printer to find its home position and boot ok.
Unfortunately, a lot of the time, the reason for the fault is printer related and such, this method does not work. But it is always worth a try.
Hope this helps.
Jan 19, 2011 | Xerox Office Equipment & Supplies
Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Apr 15, 2009 | Xerox Phaser 8500/DN Printer
Niallbt
Mar 31, 2009 | Xerox Phaser 8550DP Printer
Error code in Phaser 8550 window. ?:07,010.43:1362
The exact explanation per xerox is " The Printhead is stuck in the tilted position, and is not able to tile forward to the print position, due to problems.
This is usually caused by broken printhead restraints, of the machine got shut off in the middle of warming up, and the printhead is stuck to the cap wipe assembly.
Regardless the machines covers will have to be taken off to go any further.
Mar 15, 2009 | Xerox Phaser 8550DX Laser Printer
Xerox tektronics phaser 850- media jam
The preheat entry sensor assembly probably has broken sensor arms, and will need replaced.
Jun 13, 2008 | Xerox Phaser 850 Printer
Xerox 8500 Error 07,101.43:20955
That has to do with the process drive gear box. May be mis timed or a gear broken.
Apr 11, 2008 | Xerox Phaser 8500/DN Printer
Wont Warm Up
If it is a 8200 or older, 860,850 etc there are 2 halogen lamps in the drum heater. One or both of those are blown out.
Phaser or Xerox will only sell you a heater assembly.But you can go to any hardware store and pick up 150 watt 120/130 voe halogen short lamps and replace them.
What you want to do is look into the fan openings on the printer when you turn it on, and see if you see lamps glowing.
If you do not, that is the problem, It is very common.
Nov 27, 2007 | Xerox 8200/DP Thermal Printer
102 people viewed this question
k24674
jasbo
jasbo
