The spots for auto focus points will not adjust to any other place except the far right spot so when I try to use the auto focus it only locks on the right side, if I try to use the center spot it is out of focus. can yo tell me what I can do to fix this. I have tried to use the top dial to move it, it only look like it will select the center spot but when I try to use it, it is still in the same place. Thanks for any help you can give me. Kevin
after cleaning the sensor (with a bulb air cleaner) the high-speed setting no longer works correctly...
(More)
after cleaning the sensor (with a bulb air cleaner) the high-speed setting no longer works correctly (running water no longer looks "frozen")...any ideas?
Same thing, all images are extremely over-exposed. When using flash, however, exposure is (more or...
(More)
Same thing, all images are extremely over-exposed. When using flash, however, exposure is (more or less) OK, so I figure the flash metering does not rely on the same mechanism. Anyone got a clue on how to get to the AE sensor? The location pepeik posted (thanks for that!) does not exactly suggest a way of getting there.
after a hit of my camera 30d every thing is working perfect but thr light meter has the same problem...
(More)
after a hit of my camera 30d every thing is working perfect but thr light meter has the same problem , i will like to know were is exactly located the light sensor to beable to see if it is dislocated or loose, , any one knows were is located or what is the number of the part to locate it on the canon 30d diagram
thanks
