Question about Vacuums
Overheating VAX Mach Air
I have cleaned the filters and emptied the canisters, but the motor is overloading and over-heating. There seems to be a blockage somewhere inside the motor casing at the base of the vacuum - how do I check or clear this?
SOURCE: Bissell Healthy Home
I had the same issue after using it daily for over a year. I checked everything and found no clog. I brought it to a vacuum cleaner repair center and they found a clog in the motor. It cost me $25 and was well worth it. I love this vacuum
Posted on Mar 01, 2008
chrispurs1
  • 372 Answers
SOURCE: Dyson DC07 Original won't pick up at base
Lie machine on its side pull back handle as if vacuuming & switch on (KEEP YOUR FINGERS & ANY LOOSE CLOTHING CLEAR OF BRUSH ROLLER)
Brush should spin if it doesnt ensure clutch control knob on side of machine is in drive position if it isnt rotate knob by hand to drive brush should now spin.
If it doesnt & your machine has A clutch either clutch will need replacing or belts will need replacing.
Manuals are available to replace belts & remove the clutch from this site http://dysonmanuals.llc.nu/index.htm
Posted on May 18, 2008
chrispurs1
  • 372 Answers
SOURCE: Loss of suction, loud blowing noise
Hi.
Try cleaning out the vortex this will sort out poor suction.
Posted on Oct 16, 2008
VacuumRepair
  • 438 Answers
SOURCE: Model 116 Kenmore vacuum cleaner. 20+ years old,
Greetings,
I believe that this is probably a Kenmore Canister vacuum cleaner, but I can't be positive. The model number 116 is just the first part, and all Sears vacuum cleaners start with model 116. There is a . after the 116 that will identify the vacuum. If you'd like me to be more model specific, or if this is an upright vacuum, please just request a clarification and I can take pictures even for you.
If this is a canister style vacuum, then you'll need to remove the foot pedal that rewinds the cord reel. There are 2 or 3 (depending on which model you have) hidden screws underneath of this pedal. You may simply pry off the pedal using a flat head screw driver. Also when you have the bag door open, you may just pull forward while it's open, and this will remove the bag door housing. There should be two screws in the front of the motor housing that need to be removed as well.
My guess from the age of the vacuum that's probably the motor that's gone. If this is the case, you probably can still get a motor if you'd like to just replace the motor inside, rather then buying a new vacuum. Typical Sears Kenmore canister motors sell for 79-120 dollars.
Again, I'd be happy to try and help you further, I will just need the entire model number after the 116. to know which vacuum you have.
If this was helpful, please click the 4 thumbs up icons in the top of the page. Thank you,
Chris J.
Posted on Mar 21, 2010
SOURCE: My VAX Vacuum has lost ALL suction power. I've
vax power pet 1 filter keeps getting clogged up so dirt not going into cylinder
Posted on Apr 23, 2010
How do I change the belt on my vax Mach air u91-ma-b
goto this link and on the page i think your manual and hoe todo it is the forth one down.... How do change the belt on my vax Mach air u91 ma Google Search
Dec 12, 2016 | Vax Vacuums
Vax troubleshooting
it must be missing a diverter somewhere..most have a diverter just inside the tank...
Jan 08, 2014 | Vacuums
I have a vax mach air u91-ma-b where's the drive
click on the link below and you can dowload the manual witch will give you instructions how to change the belt
http://support.vax.co.uk/power-2-upright
Mar 20, 2013 | Vacuums
Roller brush not working on vax air mach 6
Hi I have a vax mach air light.the brushes wont turn but the green light is on. I have checked eveything .The little button on side tube no blocks .Checked all filters.
Jul 07, 2012 | VAX Appliances Vax X3 Bagless Upright...
I have a Vax turbo force 2000w hoover and it doesnt pick up theres hardly any suction and then it cuts out. Any ideas what the problem could be?
Yep,
Your filters are clogged. As a result the motor is straining and overheating, then a thermal cutout operates.
Clean the filters in the top of the vax and if you are ussing a cloth bag empty and wash ot. If a paper bag, replace it.
All should be well
Jun 29, 2011 | Hoover Vacuums
My vax hoover performance 2200 keeps overheating and cutting out after only 10 minutes
mine too.. I got local place to do a deep clean (sic) of all the filters but its made little difference. Hardly does a room before cutting out and then you have to wait an hour for it to cool down. am veryy disapointed
Jul 04, 2010 | VAX Appliances 2000 Canister Vacuum
How do you use vax 2000 to shampoo carpets. do not have a manual
Set up is complicated unless you are patient.
Remove the paper dust bag from the bottom of the canister and then filter ring. Then put in the recovery bucket of which 4 litres of warm water should be added and a capful of floor cleaning solution.
Then remove the pump wire on top of the Vax motor where the blue filter circle is (keep the filter in, do not remove it!).
If the 2000 has a separate pump notch on the rim of the Vax motor head on the outside then you should plug the black cord in that has a washer screw type metal connector. Push, twist and lock in. Then the black cord which eventually leads to a clear pipe with the older clip on wash handle that has to be clipped to the main hose handle has to have the black and see through cord clipped to the main hose and eventually down the extension pipes until you get to the floor head. If you have the older style T shaped floor head the cord should slip into the floor head easily. Then either squeezing the trigger to release the cleaning solution in, switch the Vax on and hit the secondary pump button. This will pump the cleaning solution and water into the carpet. To stop the pump you can either lock the wash trigger to stop the liquid or squeeze the trigger to make sure no other liquid comes out. Generally you can see the foamy carpet solution flowing through the see through rubber hose and eventuallly through the floor head.
To **** up the rest of the carpet solution, stop the pump button and the Vax can be used to **** out all the dirty solution/water in the carpet. Its a big and tedious task generally!
See an alternative manual for the Vax 1000 which is an older model but similar to the 2000. It is free and in pdf downloadable form:
http://www.vax.co.uk/downloads/pdf/VaxGuideNo8a.pdf
Jun 15, 2009 | VAX Appliances 2000 Canister Vacuum
Vax 2400 performance pet overheating
Unfortunately there is no permanent solution.It is a terrible vacuum cleaner and im getting rid of mine today. I have been maintaining it for 6 months cleaning filters , swapping filters, swapping carbon brushes all to no avail.Dump it. it would'nt **** the air out of a balloon.
Jan 29, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
No suction on carpet
make sure the brush is spinning and also make sure u there is not a clog right behind the canister when you detach it from the vacuum itself
Jan 18, 2008 | VAX Appliances Vax X5 Bagless Upright...
Vacuums Logo
102 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
