How to fix an error 00001-002 ir4570
How to solve the problem for the 0000-002 error on canon ir4570 machine?? machinery already in reset but no change. please problem are described in detail what I need to do to resolve the issue. thx
spinal
  • 287 Answers
SOURCE: E000003-0000
Hello 1999.We can reset the code together. And for many errors the copier can be reset,and then recover, then move on like normal. However the code you have (E000003-0000) means that an extremely temperature sensitive area of the machine misbehaved.And the copier gets really anal about monitoring this temp so the code may return as soon as the copier runs a diagnostic, but I can assure you we can reset the code so lets give a whirl and hope for the best.Ok, on your operator control panel, next to the nine key pad,is a button that says "additional functions".Locate it and we will perform a 3 step function that will allow you to enter "service mode" which will let you clear the code. Press "additional function", release it and then immediately press the 2 and 8 buttons simultaneously, release them and then press additional functions again. As I said this is a 3 step process that should be done in a smooth but timely fashion. If done properly this will summon a new screen that will show you a few "blocks" and the top block will say COPIER. Press it and a new screen will appearwhich will have several blocks across the top of the screen. One will say FUNCTION and you need to press it. Again a new screen. Look at the menu in the body of the screen and you will see CLEAR. Press clear. New screen again and look for ERR. Press ERR. After you have touched ERR notice the "OK" button in the lower right corner of the screen. Touch "ok". Now unplug the copier and wait a few seconds.Now plug that baby back in. The copier will attempt to return to a ready condition by "warming up". This is where the copier may notice a problem with the temp. Then make a copy. This will force the copier to run a brief diagnostic(which you wont see). If the copy successfully exits the copier then you should be ok. But the fact that the code occurred at all Means that at a minimum the copier had previously seen a problem and so the code may return. Hopefully, we just saved you the expense of a service call and all remains well. I hope I have helped you and I will keep my fingers crossed hoping it was merely a momentary problem. Good luck and take care. SPINAL
Posted on Jan 20, 2008
acost
  • 11 Answers
SOURCE: cANON IR4570 e000805-0000 AND e000110-001
on ir5570 error ,,E000110-001,,is polygon motor
Posted on Apr 06, 2010
  • 23 Answers
SOURCE: I have a ir4570 canon
the fixing assy is faulty and would need to be replaced and the error reset
Posted on Nov 01, 2010
SOURCE: I HAVE A CANON IR
error code 00001-002
Posted on Jan 06, 2011
  • 122 Answers
SOURCE: hi guru, my canon ir4570
code 110 is for laser polygon motor you should replace the unit. for problem 007- check fixing film if it is ok then open the unit and take out fuser film apply mixture of some white grease and fuser oil(silicon oil) and put back the film and unit.hope this helps you.
Posted on Feb 02, 2011
Why error code E000000-0001
it is the encode on the fixing unit / fuse unit change the fixing film and then reset the error code by entering service mode then clear it
Oct 12, 2015 | Canon ImageRunner 4570 | IR4570 |
How do i solve an error e000-0000 canon ir 2002n please
Description
The main thermistor reading does not reach 40C 14 sec after the fixing heater goes ON (fixing low temperature error)
Remedy
1) Wiring Is the connection of the connector (CN8) on the power supply PCB and the connector (J103) on the DC controller PCB and the wiring to the fixing assembly normal? NO : Correct the connection and wiring. 2) Fixing assembly Try replacing the fixing assembly. Is the fault corrected? YES : End. 3) Power supply PCB, DC controller PCB Try repacking the power supply PCB. Is the fault corrected? YES : End. NO : Replace the DC controller PCB. 4) Error With the power switch ON, clear E000 through E004; then, turn off and then on the power switch.
Aug 05, 2015 | Canon Office Equipment & Supplies
My Canon ImageRunner have this error code E000007-0000, what does it mean?
the rotation of the fixing film is faulty,you have to feplace it,or replace the main thermistor,if fix. film is okay.but first, reset it in service modeCOPIER<FUNCTION<CLEAR <ERR
Feb 07, 2015 | Canon ImageRunner 4570 | IR4570 |
How to fix the Canon Image Class Printer 4750 error code e001-0000
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
for more details : www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
Jan 04, 2015 | Canon Office Equipment & Supplies
How do i solve an error e000-0000 canon ir 2202 please
Dear
Its related to the fixing temp. do the error clear on service mode. then check the fixing film assy. heater circuit contact points for corrosion. Replace it.
Thanks.
Dec 12, 2014 | Canon Office Equipment & Supplies
I have ir4570 error code e00007
It is my pleasure to guide you.
Your Canon iR 4570 All in One Printer Manual iR4570
User's Guide can be downloaded at http://download.canon.it/manuali_operatore/files/iR4570_USR_ENG.pdf
Look at Chapter 3 Troubleshooting
List of Error Messages ..3-6
List of Error Codes without Messages. . 3-6
You will find the list of error codes.
Also, http://servisfc.blogspot.com/2010/12/detecting-error-e007-for.html
gives the following;
QUOTE
Detecting Error E007 at canon copier iR2270, iR2870, iR3570, iR4570, iR3530.
As part of its protective mechanism, the machine checks for the following error conditions.
Error Code: E007
Detail: 0000
Sympton: The fixing film rotates in an abnormal way.
Description: The reading of the main thermistor is in excess of 100 deg C with the fixing motor in a locked state and in addition, the machine fails to detect the marker signal for 6 second.
UNQUOTE
Good luck and please post back that you are successful, giving thumbs up, or that I can be more helpful.
Jun 09, 2011 | Office Equipment & Supplies
CANON IR4570 e000805-0000 AND e000110-001
Apr 05, 2010 | Canon ImageRunner 4570 | IR4570 |
Error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Jan 16, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
CANON IR 3300 HAS ERROR CODE: E000002-0000
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
Dec 02, 2009 | Canon (6981A002AA) for imagerunner 2200,...
63 people viewed this question
jasbo
jasbo
