Question about McCulloch FHH18A Electric Pressure Washer
Soap dipencer problem - McCulloch FHH18A Electric Pressure Washer
    New Friend:
  • 3 Answers
Posted on Jul 24, 2013
Where do i put fabric conditioner in my washing whirlpool fl5085
If the fabric softener is disappearing then it is likely the siphon is missing. This is required to meter the fabric softener into the wash at the precise time. Check the diagram in attached service manual and look for parts 718 for comparison with your message. You may have to replace the unit if parts are missing. There should also be a solenoid that triggers the flow of the fabric.
see page 4 after downloading manual form this link. http://www.hobbielektronika.hu/forum/getfile.php?id=222604
Sep 21, 2014 | Washing Machines
Won't dispense soap. Changed batteries twice,
Sometime the viscosity of the soap could be the culprit. If you had changed to a thicker soap sometimes those pumps can't handle it. Try a less viscous soap and lets see what happens. Good Luck PAL
Jul 26, 2010 | NRS iTouchless Stainless Steel Automatic...
We have an Emerson hands-free soap dispenser that won't work. We've installed brand new batteries and it still won't dispense soap. The red light comes on to indicate it' s working but no soap will come...
We have 5 Emerson hands-free soap dispensers that don't work. Tried new batteries, light comes on, but no soap comes out. How can we get our money back?
May 20, 2010 | Vacuums
My grohe soap dispenser won't pump out any soap.
If the soap dispenser is not pumping the soap then the soap is to thick. You need to then the soap down some so it will pump.
Apr 01, 2010 | Grohe Satin Nickel Soap Dispenser...
Water is pouring out of the soap dispenser onto the floor. how to resolve this problem?
sounds like the dipencer hose came loose.
Unplug & remove screws along top of washer in back.Lift up & remove. You should be able to access issue from there
Mar 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The soap dispenser on my price pfister kitchen faucet won't pump soap. It pumps, but no soap comes out.
Two things spell trouble for these poorly engineered units:water and thick soap...
Inside these pumps is a metal ball for
the check valve. any water in your soap
will corrode this ball, causing the pump
to lose it's prime...
Using soap thats too thick (like Dawn)
will cause the soap to harden around the moving parts and impede the pumping
action. Try a thinner soap, such as inexpensive pink hand soap.DO NOT
ADD WATER! (See above)
Hope this helps.
Dec 30, 2009 | Price Pfister Marielle Kitchen Faucet with...
Water will not dipence from door
Most of the time when this happens it is because the water line to the dispenser is frozen. Most refrigerators have a plastic tank or a large coil of plastic line located behind the food drawers and shelves in the refrigerator side. Try to locate yours and heat it up with a hair dryer to defrost it. There is two other things it could be but they are way more rare........The first is the water valve in back of the fridge, but if you hear a noise when you press the water lever on the door then it is not the water valve. The second thing is the button that the water lever presses when you want water. It is located behind the dispenser cover, but they rarely go bad. I would bet on a frozen water line.
Sep 15, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Kitchen sink soap dispenser won't pump
soap may be too thick or pump tube may not be touching soap in dispencer. try pumping same soap from cup
Mar 08, 2009 | Plumbing
NO FABRIC SOFTNER
The fabris dipencer hose was clug need to remove hose , clean w/ stick not so tight rinse w/ water then assemble .
Jan 09, 2008 | Kenmore 43142 Front Load Washer
McCulloch FHH18A Electric Pressure Washer Logo
113 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
