Question about Mitsubishi WS-55809 55" Rear Projection Television
55809 convergence Ok, so, I was having convergence problems with my 55809, and would concede to kick the side of it to bump the convergence back into alignment. Now the TV won't turn on period. The green power light comes on, but after a few seconds it goes out. I've been hitting the net hard on info, and it all seems to come down to a convergence problem with a couple of fuses and maybe some chips. Having said that, I looked up parts for repairing my TV and found a kit at tvrepairkits.com that will fix the convergence. My question is, will this fix my TV not turning on, and is that site reputable? Also, when I hold input and menu at the same time, I get 2 blinks, a pause, then 2 blinks. Thanks.
Slinteriors
  • 8617 Answers
SOURCE: I turn on the TV and after about a second it turns back off
22 error is the code for short protect which could be the two STK392-110 Convergence ICs as thats the number one component to short out . It could also be leaking coolant check the boards for any sign of a sticky residulr that would indicate that the CRTs are leaaking coolant on the boards.
Posted on Apr 27, 2009
SD Tech
  • 14553 Answers
SOURCE: Flashing green light when i hit power botton.
2 blinks and 2 blinks is the error code for short protection---usually in this set the most common cause is a bad convergence chip that has shorted; it takes out one or two pico fuses in the set's power supply---the set detects no voltage to the convergence chips and shuts down.
Almost any good tech can do this repair in your home in about a hour or less--shops charge 300-400 for this kind of repair--look in your area and find someone who has done this brand before--I do lots of them here for 200-250 depending on model---This is the slow time of year for TV repair shops so look around--if someone says it "has to go to the shop" keep looking.
I have detailed start to finish instructions (verify the model number to me) for doing this repair; If you have the skill to do it yourself--you can buy the chip on Ebay A WS-55809 model uses a single STK-393-110 chip---about 14 dollars on Ebay plus shipping----let me know if you want the instructions and if you have questions reply to this post here.
etower.766@netzero.net
I do this here for free so if it helps you take a moment and give me a vote here.
SD TECH
Posted on Sep 03, 2009
rylee_smith
  • 8619 Answers
SOURCE: My HD 1080 WS-55809 won't turn on - little green
Hi
Thanks for using FixYa. Error code 2-2 means short protect which is either caused by bad convergence ICs and/or 2 Pico fuses (F9A05 and F9A04). You’ll need to open the back of the unit and replace the parts that have gone bad to resolve this issue.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 21, 2010
SD Tech
  • 14553 Answers
SOURCE: Dear SD Tech, My WS-55859 suddenly stopped turning
I have the address. 2,2 is short protection. 98% chance one of the two pico fuses pictured is blown.
Model indicated uses a single convergence chip; it and the fuses are on the middle board.
See attached photos of fuses (circled ones are suspects) and another of the chip.
A very helpful rating will result in instructions sent.
SD TECH
note the fuses marked
Posted on Oct 07, 2010
Testimonial: "Quickly Responded and very helpful."
welcomejee
  • 10594 Answers
SOURCE: Mitsubishi model Wt-46807 Power shuts
hi,
Error code 2-2 indicates "Short Protect Circuit" problem in tv.
Need to check pico fuses in power supply as one or two got blown due to bad convergence chips.
Below is an exploded view of tv chassis, power supply and convergence area has been marked to give you better idea to look for pico fuses.
Unplug tv from wall socket before to repair/check any thing inside tv.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Posted on Oct 16, 2010
I have a mitsubishi WS-55809 -- it's about 10-11 years old. Just recetly lines have started to appear at the top/bottom of screen which fade, but eventually creep back. We've never had any problems with...
Yes,this problems is common on DLP tvs.Ur tv is developing a problems known as a convergence problems.The tv convergence board the 2 STK convergence ICS and some or all it resistors it dead.These parts,must be replaced to solved convergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 09, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Ws 55809 color
So you are still haveing the convergence issue with your tv, the convergence ic chips need to be replaced to correct this problem you can't adjust it as the components are failing.
Aug 19, 2008 | Mitsubishi WS-55809 55" Rear Projection...
HD 1080 Series (WD-55809) - Color convergence issue
I don't know of illustrated instructions but I can provide you with the service manual for your TV. It does have illustrations of disassembly and components as well as schematics. Your set very likely needs new convergence IC chips. This is a common problem with all projection TVs. The repair is not expensive ($60-75 in parts)  but does involve unsoldering and removing the old chips and soldering in new ones. Some times there are some fuses that need to be replaced as well. If you want the manual provide me with an email address.
Dec 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi ws-55809 distorted picture
Sounds like you are having a convergence error.
What you could do is either replace the TV or have some wires/circuits/boards replaced.
Shop around for prices.
If you're lucky you'll find someone willing to do a free estimate, as replacing anything on these will set you back a few hundred...at least.
Hopefully, in your case, the problem can be solved by tightening a screw or two.
Jul 15, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Picture problem
start checking caps w esr meter probally leakey cap or solder conn.
Apr 21, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Convergence problems
If you know how to solider you can fix this yourself with no new parts.
The convergence chip is becoming desoldered from the board. If you check hometheaterspot.com's Mits forum they have very detailed info on how to fix this.
Dec 16, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809
1)Check for coolant leak from CRT onto signal board
2)Possible convergence problem ..................T.
Oct 26, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Convergence problem, then no power...
Hi! Truman001;
Check all the peco fuses on the deflection /power pcb.
Please let me know what you find.
Thanks!!
Toprol
Oct 15, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS55809 "red" converge problem
Proper description is convergence IC ...part # STK392-570...
there are two in model # WS 55809...replace both.......T.
Jul 30, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
74 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
