Question about Home Security
How do I open my turn safe if I forgot my combination? It's been a while since I've used it and I cannot remember the code and I do not know how to get into the safe.
    New Friend:
  • 61 Answers
Dynamite or a blast strip.
Posted on Jul 30, 2013
I forgot yo open a security box. Please let me know how.
1 You will need to find out the combination. The first thing to do is to move the entire dial that is in the lock to the right. This will let you know that all the wheels are disengaged. 3. You will need a stethoscope. Each time you turn the dial, you reach the point of the combination number you can hear a click here. You should make notes considering the numbers you can read on the dial each time you hear two clicks. This will help you know the length of the combination. You must use a stethoscope to listen carefully and precisely where the clicks sound. 4. Repeat the process. Then repeat the process considering the number of clicks you hear in the process, repeat several times to make sure you're right about the number of click. This information should be represented in a chart in order to know the numbers of the combination to open safe. You have to start testing the clicks generated by the box when the dial is turned, the dial should be at zero.
5. Combine data to open safe. With the data obtained when listening to the clicks generated by the dial, you should start making combinations and test them in the safe until you get the perfect combination that will help you open the safe. Example if when turning the dial you could hear 3 times two clicks, ie the combination of the safe must have 3 numbers. Consider the exact numbers you could see on the dial when you heard the clicks. Then you must have something like this in your notes (2, 65, 34). Start combining them and try in the safe until you find the right combination, start making patterns and discard. Then those copied in your notes will be the secret code numbers that will open safe. It is very important that you have been very careful when listening to the clicks and that this process has been done several times to be sure that these numbers are correct. Now you can make patterns, considering the numbers that you raise in the example, such as: 2.34,65); (34,265); (65,2,34) and so on until finding the correct one. That is why you need to write down all possible combinations and tosa trials. Remember the success of, without opening your safe, without a locksmith, and also considering that you do not have the possibility to call a manufacturer. Be: • Listen carefully to the sounds of the clicks you hear in the safe. • Avoid other sounds that may distort your ability to listen carefully • Record exact numbers where you clicked • Be patient and test your combinations. You must have on hand the instructions of the manufacturer of the safe, if you do not have it, look on the web since surely the manufacturer has a page where you can find this information. You could also call the manufacturer and prior identification will give you the key to your safe. Otherwise and if you've tried all the possible combinations and you just can not do it, call a locksmith. You no longer have a bad life and recover your valuable items, open safe can generate waste of time but if you strive you will stay with great satisfaction.
Aug 13, 2017 | Cell Phones
Says code error
How To: Open A Locked Sentry Safe If You Forgot ...
? 5:21
https://www.youtube.com/watch?v=Mr8QrvVAtuI
Jul 15, 2014 - Uploaded by TipsNNTricks
I show you How To Open A Locked Sentry Safe If You ForgotThe Combination Or Loss Your Digital Code Or Lossed Your Key. The Sentry Safe ...
' Sentry® Safe ' Lost Your Combination
https://www.sentrysafe.com/.../Lost_Your_Combination
Sentry GroupCombo Recovery. What you'll need: Model Number; Safe Serial Number; Notarized Statement of Ownership. Step 1. Safe Info. Step 2. Notary Form. Step 3
opening a electronic safe forgotten the lock code ready to ...
www.instructables.com/.../OPENING-A-ELECTRONIC-SAF...
InstructablesJul 6, 2009 - I HAVE A SAFE GAURD COMPANIES SAFE I HAVE FORGOTTEN THE LOCK CODE TO OPEN IT. THEIR IS NO ALTERNATIVE OF KEY ...
How to Crack a Safe (with Pictures) - wikiHow
Jan 10, 2016 | Home Security
I have a supra touch pad key lock but the code accidently got changed and no one can remember it how do we open it now
Well there are may ways,,, I cant really post them here as this is public and a lot of BAD people use the net too.
I once forgot my combination but I used this basically it will generate every possible combination for you, a 5 digit sequence will take about 20 minutes to go through..
Also I remember once a friend left for vacation. While he was out a clever Thief used battery acid to melt away the plastic coating and then used a chisel and hammer or something abound that thereof to break the rest open.
and as another friend told me, When all else fails a Huge Hammer works.
Please remember these locks are Advanced and you should call a locksmith as it will be wrong of us to tell you how to bypass.
Dec 28, 2012 | Supra 001004 Push Button Lock Box Key Safe
Factory reset la gard 3715 electronic safe
Welcome to FixYa.
How to reset or change your lock combination:
  • 1. Enter "zero" six times.
  • 2. Enter your existing six (6) digit combination one time. (or 123456, factory default if you haven't changed the combination yet.
  • 3. Enter your NEW six (6) digit combination two times.
  • 4. If a mistake is made wait thirty (30) seconds and repeat steps 1 - 3.
  • 5. Test lock operation several times before closing the door.
CAUTION: When selecting a combination do not use birthday or other predictable data that could give correlation between the user and combination.
• Valid Combination Entry - Double signal after valid six (6) digit combination is entered.
• Invalid Combination Entry - Triple signal indicates the old combination is still valid.
Thank you for using FixYa.
Have a great day.
Jas247
Aug 01, 2011 | Office Equipment & Supplies
How to creeate a new combination for a sentry 1310 valueguard saf
Have a 1310 Sentry Valueguard safe and cannot remember the combination nor can i remember where i put the paper that i once wrote the combination down on....need help!
Aug 01, 2010 | Sentry FIRE-SAFE Combination Safe DS3431,...
S3517sentry safe need to reset
Press: Program 2x, enter a digit user-code (green led remains on), enter the 5 digit user pin (of your choice except 00000). After 5 digits entered, the green LED turns off.
May 11, 2009 | Sentry Fireproof Safe
Forgot the code for my sentry 3110 safe
3 Digit Combination Lock
31-10-31
  1. NOTE: If your safe DOES NOT have a key, skip Step 3.
  2. Turn the dial to zero.
  3. Insert your key and turn it until the plunger pops out.
  4. Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
  5. Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
  6. Turn the dial to the left to the last number (stop the first time on your last number).
  7. Pull the handle down; the door should open.
If this still does not open the safe, refer to the following page for additional different types of safes:
http://www.sentrysafeshop.com/kb_results.asp?ID=15
If you need to retreive your lost combination, you can get it at this link:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Jan 09, 2009 | Sentry Fireproof Safe
Home Security Logo
631 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
