Question about Saitek X52 Pro Flight Control System Game Controler
Saitek x 52 xplane 10 profile - Saitek X52 Pro Flight Control System Game Controler
Loaded XPlane 10 on new iMac and rudder pedals no longer function?
My iMac has a CD/DVD drive, but I posted a X-Plane 10 pendrive to avoid inserting DVD #1 every session. It functions perfectly. Another point is to connect all peripherals (stick and pedals etc.) BEFORE launching X-Plane 10. Then calibrate your peripherals within XP 10.
I have no pedals set, but instead a pitch-stick with grip throttle and a Logitech joystick with twist grip to fly helicopters.
Jul 29, 2014 | Saitek Pz35 Pc Pro Flight Rudder Pedals
Whay is my Saitek X 52 flashing
Most likely a wire going thru the stick to the hat switches trigger button etc have been rubbing on the tube that makes up the base of the stick. I removed the four screws on the bottom and found the solid blue wire had completely broken. I ended up soldering back together and used some liquid insulation let it dry and put it back together and worked fine. I to just had flashing lights on the flight stick. And this is what I found
Jun 02, 2014 | Saitek X52 Flight Control System
Saitek p3000 profile editor not recognising controller in windows 8 (64bit) - help
windows 7 only support. you have to downgrade the o.s. or change the controller (its 10yrs old). bye
Nov 25, 2013 | Saitek P3000 Game Pad
I need some detailed instructions for programming the buttons on my Cyborg F.L.Y controller, with recommendations - - from someone familiar with computer gaming. i.e. a "Cyborg F.L.Y. for...
The best manual is on the support tab of the Programming Software.
If you need help in programming a specific key just let me know.
Also Saitek has som profiles now available on their page: http://www.saitek.com/uk/down/profiles.htm
Hope it helps...
Mar 22, 2011 | Saitek Cyborg X Joystick
I've downloaded the sst software and drivers for my X52 Flight Controller (NOT PRO) when I downloaded the profiles for the X52 Flight controller ALL of the profiles (pr0 format) say 'can't load file. I've...
According to the manual you can choose your profile by using the clutch function. Are the profiles that you downloaded of the same file type as the one you have been able to make from scratch?
Mar 19, 2011 | Saitek X52 Flight Control System
The official Saitek website only has the drivers for the X52 Pro and so though I only have the standard X52 (not the pro), I used the Pro driver and software. The profile editor does list the standard X52...
Saitek has drivers for the X52 on their website.
Here are some direct links.
XP 32bit: ftp://ftp.saitek.com/pub/software/full/Saitek_X52_Flight_Controller_SD6_32.exe
XP 64bit: ftp://ftp.saitek.com/pub/software/full/Saitek_X52_Flight_Controller_SD6_64.exe
If you need further help please let me know.
Hope it helps...
Sep 24, 2010 | Saitek X52 Flight Control System
Hi my name is jatt and i don't know how profile saitek cyborg pc
Hi there, go into control panel. When in control panel, click switch to classic view. Then click on game controllers and you will have settings for your game controller.
Jan 18, 2010 | Saitek Cyborg Rumble Pad Game Pad
Profiler will not start on my saitek cyborg mouse and I cant find the disk to reinstall the software
http://www.saitek.com/UK/PROD/cyborgmouse.htm
you will see a download option at the top of the webpage, select drivers and follow the instructions from there.
alternatively google: saitek cyborg mouse driver download
Oct 29, 2009 | Saitek Cyborg Mouse
Saitek X 52
Here are drivers for Vista that would work.
http://www.saitek.com/uk/down/drivers.htm
Just select if you have 64 bit or 32 bit.
Nov 20, 2007 | Video Game Consoles & Games
Saitek X52 Pro Flight Control System Game Controler Logo
49 people viewed this question
Top Saitek Computers & Internet Experts
micky dee
Ajay Virvan
Ajay Virvan
Are you a Saitek Computer and Internet Expert? Answer questions, earn points and help others
