Question about Biostar M7VIG-400 (M7VIG 400-COMBO4) Motherboard
CPU freezes on boot up
Energize computer. CD/DVD drive light comes on, then goes off. Biostar logo comes on screen Floppy disc unit light comes on, stays on Biostar logo freezes on screen. Boot up incomplete.
    Brigadier General:
  • Biostar Master
  • 3,400 Answers
Try reset CMOS.or re-wiring the electrical wires,make sure they are seated tight.
Posted on Jul 24, 2013
3 Suggested Answers
  • 40 Answers
SOURCE: windows xp won't load on new biostar motherboard, please help
go to biostar web sight and download sata driver. You may need to run disk that came with motherboard first. Driver may be located on the disk. if not get it from biostar.
Posted on Jun 21, 2009
  • 38 Answers
SOURCE: biostar gf7100 mp - wont boot with ext usb drive attached
Hi, What you have to do is shut down the machine, pull the CMOS battery(CR2032) out and out and put your jumper on pins 1-2 from 2-3. Wait 30 seconds and put the battery back in. After installing the battery, put your jumper back to pins 2-3 from 1-2. This should work.
Posted on Jul 08, 2009
Acer is going straight to a black screen after the acer logo in startup....it just shows a tiny blinking line. It goes no farther. I need help fast
Apparently your Acer cannot find the operating system. As soon as the Acer logo comes up, there should appear in one of the bottom corners "F" & a number should appear. Immediately start pressing that F number (top row of keyboard). This should take you to a boot screen. Scroll down to boot sequence. Hit enter. Make sure boot-up sequence is CD or floppy drive first, second should be HDD, then escape. Restart computer. Should then boot off CD drive. I am assuming you have an operating system (XP, windows, etc.). Let me know if this doesn't work.
Apr 07, 2013 | Acer Aspire 5734Z4386 Notebook
I have a mcp6pb m2+ mother bord will boot up nextime it will not
If this is a desktop computer this could a problem with the PSU it might not be sending enough amps to your computer for it to boot up and enought to run the fan
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty
computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical or fan lead can cause you problems
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
hope this helps
Sep 21, 2012 | Biostar MCP6PB M2+ Motherboard
Cannot update from XP Home SP1 to SP2 or SP3
start out with a xp home disc that has sp3 already Intragated on the disc - windows xp home SP3
Sep 03, 2009 | Gigabyte GA-K8VM800M Motherboard
Windows xp won't load on new biostar motherboard, please help
Jun 21, 2009 | Biostar K8M800-M7A Motherboard
Biostar motherboard or processor dead?
have you also tried different video cards? or the onboard built into your motherboard?
Jun 11, 2008 | Biostar P4M80-M4 Motherboard
Windows loads on every other boot.
Let's try running a memory test program. http://memtest.org/
Scroll down till you see the three screen shots. Just under them pick you're choice of bootable media to test you're memory.
Download - Pre-Compiled Bootable ISO (.zip)
or
Download - Pre-Compiled package for Floppy (DOS - Win)
Luck!
Mike
May 15, 2008 | Biostar GEFORCE 6100-M9 Motherboard
Computer Won't Boot (Anything?)
ok sounds like a bad power supply , i would get a new one
Jan 21, 2008 | Computers & Internet
Occasional BOOT hang
Try using the event viewer and see if it comes up with anything
How To Use the Event Viewer Applet
http://www.bleepingcomputer.com/forums/topic40108.html
Jan 02, 2008 | ASUS P4S800D-X Motherboard
Biostar M7VIG-400 (M7VIG 400-COMBO4) Motherboard Logo
99 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
