Question about Sharp MX-2310U Color Copier, MX2310U "
Sharp mx 2310U call for services code f2-64
My Sharp Copier asking for call for services code f2-64 Even i changed BK toner still problem
007tech
  • 95 Answers
SOURCE: sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Posted on Apr 23, 2009
  • 143 Answers
SOURCE: Sharp MX-2700N - Error Code - 'Call for Service E7 - 05'
E7 is only part of the code. It could be a hard drive problem, memory problem, laser problem, or a loose connection on one of the boards.
Posted on Aug 01, 2009
  • 62 Answers
SOURCE: Sharp Copier Service Code
You had 5 jams in the fuser the hotarea on the left side of your machine.
Posted on Mar 23, 2008
  • 6 Answers
SOURCE: what is Code: H5-01 on the sharp mx 2300 copier
You need a service reset.This is a fuser problem .clr and star and hash and star fusing reset
Posted on Nov 16, 2009
  • 9 Answers
SOURCE: after installation my sharp ar-m420u
L1 MEANS U HAVE TO REMOVE THE SCANNER LOCK WHICH IS ON THE SIDE OF THE MACHINE.
F2 MEANS SOME PROBLEM WITH YR TONER CATRIDGE.CHANFE IT AND SEE
Posted on Jan 16, 2011
Error code F2-40 in Sharp mx m314n photocopier
using third party toner or drum replace toner and drum with OEM
Jun 04, 2015 | Sharp MX-M314N Copier
How do i clear error code F2-64
The news is not good. Follow the link to see what you are up against.
Error Codes Sharp MX2310U Code F2 64
Mar 04, 2015 | Sharp MX-2310U Color Copier, MX2310U "
Sim 66-10; What does The confidential data mean?
The MX-2310U offers Confidential Printing, which when used, requires users to enter a PIN code in order to print a queued document. To help protect your direct-print documents from unauthorized viewing, the MX-2310U offers encrypted PDF printing and scanning. Additionally, Secure Fax Release ensures received fax documents are held in memory until an authorized user enters a PIN code, so that compliance with healthcare regulations such as HIPAA is easier.
This data will be cleared if Sim 66-10 is enacted.
Mar 01, 2015 | Sharp MX-2310U Color Printer : 2310U
"Sim 66-10"; What does "The confidential data" mean?
How can I delete the Memory of RESENDFAX for MX-2310?
Try this while you're at it.
# * C * to enter the simulation mode.
Simulation 66-10 is the image memory clear which clears the print/scan/fax memory. DO NOT EXECUTE AND OTHER SORT OF CLEARS IN THE MENU.
Copier Collin Houston TX Copier and Imaging Expert
Feb 08, 2015 | Sharp MX-2310U Color Printer : 2310U
Toner is full but still displays insert toner bk
one of them may possible 1 did u turn toner bottle gear if it,s tight change toner bottle 2 did u check toner detector which is a micro electronic card rear of toner bottle if u have another tested card just swap it hope fully it would be fine let me know thank,s
Feb 25, 2014 | Sharp MX-2300N Color Copier
I have used Mx-2310U (copier, scan, print). It is not work now. I see error code L4-06. So. I thought out the Manual, but I don't know solution of this problem. I am very busy. Please answer as soon as...
Dirty or broken sensors in the inside back of your machine that detect movement of your mylar transfer belt. A portion of the belt swings up and down for color printing. Or your belt unit may be broken or not installed properly
Oct 24, 2013 | Sharp Mx-2310u Color Copy/print/scan
I have an error code F2-41
Your copier is starved for cyan toner. The cartridge either ran out or its' countdown chip went to zero without your copier alerting you that it was running low, sometimes that happens on those models. Change your cartridge.
Sep 28, 2010 | Sharp AR-BC320 All-In-One Led Printer
Call for service
There is a problem with the Bk Toner supply.... check the End Seal was removed on the Cart, if not that, then call a Tech.
OR
put the an old, used bk toner cartridge back in and restarted the printer. Once all the codes cleared, removed the old bk toner and put back the original bk toner u had removed.
that should fix
May 13, 2009 | Sharp MX-3501N All-In-One Printer
Sharp MX-2310U Color Copier, MX2310U " Logo
305 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
