GE TIMER PLAS. SHAFT - WE4M366 Logo
Anonymous Posted on Jul 24, 2013
Whirlpool dryer 7929 inglis
The timer doesn't move and there is no heat
dennis e younce
Level 1:
New Friend:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Jul 25, 2013
dennis e younce
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
18
Questions
Helped
2623
Points
55
Got good used timer and any other parts you might need for that model. I live in citrus co. fl. 20.00 for timer is pretty good deal. I can even diagnose and install parts if need be. element 10.00 or if its the thermal fuse 2.50. let me know what you would like to do . I don't think it is the timer.
1helpful
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 • Dryers
1helpful
I have a Whirlpool LER4634PQ1 it was working just fine then all of a sudden the dryer just keeps running the knob on the dryer doesn't move and the air isn't warm. Any suggestions on what to s
there is a cycling thermostat in line with the high limit thermostat and timer circuit,on timed dry its disabled and the timer will run no matter what,on any sensor dry setting it uses the heat of the element to heat this cycling thermostat to move the timer as the clothes get drier as the heating element heats the timer doesn't move,when the heater cycles off from the high limit thermostat then timer moves again,you need to find out if its a bad heating element,thermal fuse or possibly even a circuit breaker in the homes electrical panel tripped out on one of the 2 phases that gives you the 240 volts required to operate the dryer element,the breaker may not show its tripped,so shut it off and back on and try this first
1helpful
Dryer not heating and timer dosen't move
A dryer runs 2 halfs (one half 120, the other 120). Sounds like you are missing the 120 that operates those two. Did you change from a four prong to a three prong?
Inglis clothes dryer heats up but drum doesn't
The way to visually see if the belt has broken or not is to 1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) You'll now see the drum, if the belt is not around it its broken, and if it's visible try to lift it. If it taught, its good. IF THE BELT IS BROKEN OR LOOSE CONTINUE TO NEXT STEPS 6) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 7) once off you'll be able to easily see the motor, the belts idler pulley, and everything else.
If you need further help, Iā€™m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
We have a dryer that works but does not heat
No heat indicates a burned out heating element.Easily replaced.Cant answer on timer.
My dyer wont heat and timer wont move changed the thermal fuse and cleaned all the lint out of the blower box and put in new venting pipe
Make sure you have 240 going into the dryer. If one side of the breaker is tripped it is posible for the dryer to run because the motor runs on 120 volts ac. The heat uses 240 volts. Next check the heavy red wire coming out of the timer. Remove it from the timer and attach a lead from an ohm meter to that leg on the timer. See if you can get a reading from any other leg on that timer. Move the dil to various spots on the timer and keep checking for continuity. If you cannot get a reading from that terminal to any other terminal on the dryer then you have a bad timer.
I did a few homemade movies today and posted them on my youtube channel:
http://www.youtube.com/watch?v=hbez7kjzNic&list=UUKBjalPycKRmo4Mz9vRsydg&index=3&feature=plcp
http://www.youtube.com/watch?v=AoVmPvUG_7o&list=UUKBjalPycKRmo4Mz9vRsydg&index=2&feature=plcp
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
1helpful
3answers
I have a Whirlpool dryer, model ler5644awo.When I set the timer and press the start button, you can hear the timer running but, the drum doesn't and the heating elements don't heat.could it be the...
Hello, welcome to FixYa.
Based on your post I understand you have a Whirlpool dryer that you stated "
set the timer and press the start button, you can hear the timer running but, the drum doesn't and the heating elements don't heat", correct ?
Having said that, by far and away the most common and the first thing I'd look for on these dryers is the fuse which is located on the blower housing, not likely the timer or start switch.
**Unplug the dryer from the wall before performing any service or removing any panels...safety first**
You can use the link below for a tutorial video to locate, test and replace the fuse that is specific to your model.
**please check the part with an ohm meter or "jump it out" (if you know how, if not, check the second link it will show you) before replacing it...the timer or start switch is possible, just not as likely as I mentioned**
http://www.youtube.com/watch?v=aUQQJAxkZ0g&feature=relmfu
http://www.youtube.com/watch?v=3nicyh6EUHc
Let me know if I can assist you in any other manner going forward and I'll be glad to do so.
If this info provided solves your problem, please take a second to accept my solution and rate it accordingly. Good luck and thank you for choosing FixYa today.
Regards,
Macmarkus :)
Oct 30, 2011 • Dryers
2answers
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
2helpful
2answers
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Top GE Dryers Experts
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
