Question about Nokia Unlocked 5310 Xpress Music Gsm T-mobile Phone
Nokia 5310 mobile sudenly display not working how to solve this problem
I press the phone that time display came after not geting now fully gone the display how to corect the problem
    Master:
  • 435 Answers
I believe it is a display problem. Get the device checked to a near by local repair store. Maybe your display is gone and hence you dont see anything on the screen.
Posted on Jul 24, 2013
SOURCE: NOKIA 5310 can't turn on
Okay, so I totally freaked when this happened to me :(
BUT! I think I figured out how to fix it :)
As mentioned by others, remove the parts and put them back in.
1. Remove the Battery
2. Remove the Sim Card (You can't remove without the battery first taken out [SO DON'T TRY :P])
3. Remove the SD Memory Card
Now... I put them all back in and powered it back up... and it did the white/black screens :(
So then I tried again, several times, to no avail.
What worked for me is, when putting them back in, ***do not insert the SD Memory Card***
Power it up with just the battery and Sim Card, and see if it works. For me it did. I think something in the memory was corrupted... :(
I've since tried powering the phone off, putting the SD Card back in, and turning it on... it still loads now, but it isn't registering the memory :(
So, as a lesson, back up your data early and often. Which I luckily did :) And now I think I have an excuse to upgrade to a bit larger memory :P
Hope this helps!!!
~OkamiShonen
Posted on Feb 01, 2009
rafnix
  • 108 Answers
SOURCE: nokia 5310 restriction code
Hello there, your IMEI no. is 359813010646423 and the code master code is this, 5146730640.
When you enter the master code, the current security code of your phone will be override, so i suggest that return the master code to default which means 1234, and then you cab change that lately.
Hope I help... :D
Posted on Feb 20, 2009
jan mczeal
  • 632 Answers
SOURCE: Buttons not working
The volume key is stuck that's why the volume bar keeps on popping out. It is also the reason why the keypad is not working. You have to unstuck the volume key to check if the keypad really doesn't work.
  1. Remove the battery cover and battery.
  2. Remove the camera cover by prying the locks along its sides and lifting it up to expose the volume keys.
  3. Insert a needle between the volume key membranes and the board to unstuck it. The membranes should click when pressed.
  4. Install the camera cover in reverse order.
Inform me if the volume keys work fine but the keypad buttons don't.
Posted on Jan 01, 2010
SOURCE: my nokia 5310 mobile screen showing white display
5310 white display solution
Posted on Jan 11, 2010
SOURCE: 5310 nokia mobile problem
nokia 5130 camera standby problem
Posted on Mar 13, 2010
Solve the contact service problem for nokia 5310
Contact service provider means your mobile is locked with some network , so when you on the mobile it displays as contact service , so for this problem you have to unlock your mobile, if you unlock means after that you can use any network at any where in the world.......
Get the unlock code for your Nokia 5310 model mobile through this site http://www.mobile-unlocker.com/nokia-5310/rs2wp9/ , it has the best instructions and easy methods for getting the code for your mobile from the network lock......
Dec 06, 2011 | Nokia Cell Phones
Freezes up and switches off
HI there its a problem of your mobile software. Please reinstall the nokia phone software from NOKIA website and use it. Then your problem will solve 100%. Thanks.
Mar 10, 2010 | Nokia 5310 Cellular Phone
I need to unlock my Nokia 5310
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
You could ring the phone provider and ask for the unlock security code because you are going overseas and wish to use your phone with a prepaid SIM card from another country. This maybe a free service.
The other way to get your phone unlock is to use a phone unlocking company on the Internet, they usually charge a couple of Dollars for their services. Use Google and search for "Security unlocking code” in your area.
You can also try this WEB site.
www.unlock-free.com/nokia-master
Dec 30, 2009 | LG KU990 Viewty
Unlock code for nokia 5310
http://www.unlocking4u.com/nokia-5310/rs6wp9/ will give you the unlock instructions for your nokia mobile.
Nokia 5310 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Nokia 5310 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 5310 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 5310 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5310.
3 - Compose #pw+CODE+1#.
4 - The Nokia 5310 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5310 mobile phones locked to the network Fido in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 5310
Each Nokia 5310 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia 5310 mobile phone using the form above.
Dec 27, 2009 | Nokia 5310 Cellular Phone
I need an unlock code for nokia 353657011043528 please
Hi michael_rodg,
http://www.mobileunlocksolutions.com/ will provide you with an unlock code for your Nokia 5310 mobile. The instructions are as follows:
Oct 19, 2009 | Nokia 5310 Cellular Phone
Camera and Video are not working on my Nokia 5310 Xpress Music
ur camera module is faulty. same problem here i solved it change the camera module(hardware)
Jun 25, 2009 | Nokia 5310 Cellular Phone
My nokia 5310 does not open my application files annymore.i cant play game
ok look if you have a pc you can download a program called nokia pc suite once that has downloaded you can download a program called nokia update service follow the on screen instructions and this shoud solve the problem
(usb cable required)
Michael (mobile phone engineer)
Universal Mobiles LTD
Coventry
May 27, 2009 | Nokia 5310 Cellular Phone
Unlocking my nokia 5310
You can get the unlock code for Your mobile from the site mobileunlocker.
This site contains the unlocking instructions and codes for the nokia mobiles.
Mar 11, 2009 | Nokia 5310 Cellular Phone
I have no display on my nokia 5310 mobile phone, I am unable to make calls and I cannot receive any calls when my number is dialled it goes straight to my voice mail. any ideas? toby2toby
Toby-
It sounds like the LCD screen backlight died. If you are still under warranty, get it replaced.
If not, you can buy a replacement 5310 LCD and replace it yourself.
A new 5310 display costs about 20 dollars from ebay.
I wrote a detailed guide to help you put in the new Nokia 5310 LCD screen.
Check it out at the following link for the guide and links to buy the LCD
Nokia 5310 LCD Screen Replacement
Hope that helps
Jan 10, 2009 | Nokia N72 Cellular Phone
Nokia Unlocked 5310 Xpress Music Gsm T-mobile Phone Logo
87 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
