What is the best color settings for panasonic th-42pwd7
3 Suggested Answers
  • 8 Answers
SOURCE: Our 42" Panasonic Plasma tv
As posted for a similar problem:
This is an issue with IC 803 on the Z board. This is a 3.3 V regulator that supplies this voltage to the slot card cage. Most input boards use this voltage EXCEPT the component board which is why it keeps playing along whike the DVI, HDMI, or composite signals will cut out after warm-up.
This is a surface mount multi-pin IC and is a bit tricky to replace.
The entire board is PN# TNPA3198xx with suffix determined by what model 7 series plasma you have.
This was a problem from around Nov. 2004 to Mar. 2005
T Wiz
Posted on Mar 25, 2008
  • 1779 Answers
SOURCE: Panasonic VIERA TH-37PX80B 42" plasma telly
What ever sounds the best to you!. If you have a particular question regarding sound, let me know?
Posted on Jun 24, 2009
I can't get a signal because this tv don't have cable antenna terminal the tv has rgb terminal. I don't know what to do?
RGB is for a computer screen display signal and has nothing to do with TV display of channels. You must have a Component hook up, it is a yellow cable, a red and a white one. Yellow is video signal, the red and white are sound.
Sep 12, 2016 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
How to connect advd player to my Panasonic TH-42PWD7
just use hdmi. if the dvd does not have hdmi then you wull need a aux to hdmi converter but they are not cheap.
Feb 19, 2016 | Panasonic Televison & Video
Panasonic plasma TV TH-42PWD7 blacks out..
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 20, 2014 | Panasonic TH-42PWD7 42 in. EDTV-Ready...
I want to know best picture settings for my panasonic TC-58LE64 LED VIERA SMART TV
Select the default picture settings first. Then adjust the color according to your taste. It will be the best picture.
Sep 07, 2013 | Panasonic Viera TH-42PX80U Plasma TV
How i do tv chanel tunig
Hello Ansarielectr, The Panasonic TH-42PWD7 is a professional grade progressive wide screen plasma display. It's not your normal HDTV. You probably already know this. This display requires a component /composite video terminal Board that mounts to slots 1 & 2, or slots 2 & 3. The item number for this component is TY-42TM6Y and can be purchased through the Panasonic support website here for about $270. Once you have this component, you can connect the TH-42PWD7 to a digital HDTV cable box to receive signals. Just make sure you're on the right input signal. Hope this helps.
Dec 28, 2010 | Panasonic TH-42PWD7 42 in. EDTV-Ready...
Color Adjustment Problems - Reception in Black and White
satelliteand cable TV is only comes in black and white.
this a HTML type plug or a coaxial
select menu and source
very weird... should default to colour
if no luck try plugging in a desk top digital box tune using that
TH-42PX20 TH-50PX20 Operating Instructions High Definition Plasma ...
ftp://ftp.panasonic.com/television/om/th-42px20_en_om.pdf
Apr 24, 2017 | Panasonic VIERA TH-65PV500 65 in. Plasma...
I have a Panasonic TH-42PWD7 flat screen it's hooked up to a receiver and a cable box from time warner. It's not mine. I'm staying at my friends house. I have sound coming through the cable/sat channel on...
There is sometimes a way to turn of the TV speakers, but it usually cannot be set that way by accident. Plan on audio board damage. Perhaps you fed the TV too loud an audio signal, then overloaded the amp board. I would consider them gone.
Nov 13, 2008 | Panasonic TH-42PWD7 42 in. EDTV-Ready...
T Wiz
Feb 26, 2008 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
