Question about GE SpaceMaker Microwave Ovens
Surface Lights Do Not Work
I changed out both burnt bulbs and light still does'nt work. Exhaust fan, clock and all other functions still work fine. Is there a seperate control unit for surface lights or is it tied into the circuit board panel.
    New Friend:
Surface Lights Do Not Work - avatar6.jpgavatar6.jpgGet a new one
Posted on Jul 24, 2013
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Microwave Spacemaker oven, Model JVM240
That would almost certainly be a problem on the control circuit board. If the bulbs happen to short / blow out or if they are removed or installed while the microwave is still plugged in, there is often an arc which causes damage to the board. We repair regularly these boards for such problems for $32.50 nationwide.
Posted on Dec 25, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: Surface Lights Don't Work
We regularly repair these control board assemblies for only $32.50 nationwide, and that's much cheaper than replacing the board. For safety, disassembly and other info see http://tinyurl.com/yzjozk
Posted on Jan 15, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Microwave Surface Lights
The control circuits for the cooktop lights and the hood fan are spearate. The problem is indeed with the control unit. It's usually caused by either the filaments shorting when the lamp blows or by removing or installing the bulbs while the oven is still plugged into the power line. We regularly repair these nationwide for $32.50. Details of our service, as well as *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Feb 22, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: JVM1190 Surface light and fan will not go on
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 12, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: JVM1460 surface light problem
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 02, 2008
Controls, heating and turntable function normally, but there is an intermittent failure (approx 80 of the time) where the interior light and blower do not function when the microwave is operating .
follow this test and fix it; God bless you
1)
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
2)
  1. Exhaust fan motorIf your exhaust fan motor is not running, there are a couple of things that you can check involving the motor to locate the problem. After removing the fan motor, you can manually attempt to turn the fan blades with your hand. If the fan motor is working properly, the blades should spin effortlessly. If this does not occur and the blades are taught, the motor will need to be replaced. Secondly, the fan motor itself can burn out due to time and usage. Using an ohm meter, the exhaust fan motor should read open for continuity. If it does not, then the fan motor has expired and will need to be replaced.
  2. ThermostatAnother part that could cause the microwave exhaust fan to not work is a faulty thermostat. A thermostat gauges the air temperature, which activates the exhaust fan when required. If this part becomes flawed, the exhaust fan will not energize and the thermostat will need to be replaced.
  3. Main control boardIf your exhaust fan is still not working and the microwave fan motor, wiring, and thermostat are operating accurately, the root cause could be with the main control board. Replace the main control board.
Oct 31, 2013 | Jenn-Air JMV8100A 1000 Watts Microwave...
GE microwave lights and fan do not work
If one of the surface light bulbs burnt out it may have shorted out the control board. Take the control board out and look for a burnt spot on the board. It may be able to be repaired with a drop of solder or solder in a jumper wire. Or you can purchase a new board, which may cost more than you want to put into the microwave.
Jun 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Surface light "nightlight" will not work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Sometimes this will also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Feb 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile Spacemaker microwave surface lights
William E. Miller
prototech@usa.net
Sep 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
William E. Miller
prototech@usa.net
Aug 26, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave range top lights
This looks like a new entry as opposed to a reply, so I don;t know what advice you got or from whom.
But based on your problem, I'd say I know your problem.
William E. Miller, AS-EET
prototech@usa.net
Apr 13, 2008 | GE JVM1650 1000 Watts Microwave Oven
Jan 11, 2008 | GE JVM1651 Microwave Oven
After changing a blown oven light, the clock works but nothing else turns on, including the fan, light, microwave
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
Nov 27, 2007 | Whirlpool MH7135XE Microwave Oven
GE JVM1450WA01; Lights do not work, -- both blown and replaced.
We see this a lot. The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This often can affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on.
Details: If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 13, 2007 | Microwave Ovens
Feb 21, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
131 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
