System error code 39.003.40:15018 has come up on my Xerox Phaser 8860MFP
  • 2072 Answers
SOURCE: xerox printer error code (04,025.46)
This is a print head position issue.
TRY FIRST (Solutions without parts):
1. Check that the wipe mechanism has homed. 2. Check the printhead position and verify that it has initialized properly / manually home the printhead and power cycle the printers power and check for the error to return. If not then the error was most likely due to non-process function (something out of sequence).
Part likely to be the cause:
GEARBOX AND MOTOR,PROCESS DRIVE - PL 4.0, Item 14.
Posted on Jan 21, 2008
myob247
  • 1342 Answers
SOURCE: Phaser 7300 Error Code/Message
Seems to be something to do with the Ram.
More help HERE
Posted on Jun 01, 2008
  • 2072 Answers
SOURCE: i have xerox phaser 8560MFP error cod 07,010.43:14059
there is a stainless steel print head block on the lower back portion of the frame that gets contaminated with spill over ink from the catch tray. That causes the print head not to move properly.
The wiper blade may also be tacked to the print head.
That code means the print head is not moving into the print position properly.
That stainless steel block is about 1 inch square.
Posted on Mar 11, 2009
  • 526 Answers
SOURCE: Phaser 8560 error code
Most likely you are using generic ink or ink not made for that specific machine. The black ink is the one causing the problem. the printer will then need to be reset.
Posted on Apr 15, 2009
  • 7 Answers
SOURCE: error code 09.036.44:38950
09,03x 35 = Cyan 36 = Magenta 37 = Yellow 38 = Black The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error. Turn off the printer. Turn on the printer. As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display. Release the buttons, it will now come up in the service mode. Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok. Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Posted on Jun 10, 2009
System error13,264.42:88656
That error signifies that the printhead reservoir is overheating and the printhead needs to be replaced. The part number is 017K04540 and can be purchased at www.iteminconline.com.
Aug 26, 2015 | Xerox Phaser 8860MFP Printer
What is system error 07,010.43:136328
The code means that the head tile restraint spring is not in place.
This is what engineers check for before replacing any parts:
• Check that the Process Drive gear train is properly homed.
• Check for obstructions or ink spills around the Printhead. Spilled ink could indicate the
system was tipped while hot. Check for blockage in the Purge Tube.
• Verify the Printhead travels smoothly from left to right.
• Check the Printhead Restraint Arms.
May 19, 2014 | Xerox Phaser 8860MFP Printer
1306945131888 system error
That error indicates the Drum Temperature Sensor circuit is shorted out. I you have access to the service diagnostics, run the Drum Temperature Sensor test. If it fails, replace the drum temp sensor. If that doesn't solve the problem, replace the sensor wire harness.
130K75210, Drum Temperature Sensor
Feb 17, 2014 | Xerox Phaser 8860MFP Printer
Where can I find a service manual for a Xerox Phaser 8860
Here are links where you can download the User manual
Quick user manual
User Guide
Hope this helps.
Jul 28, 2011 | Xerox Phaser 8860MFP Printer
I can't find the power switch to turn on my xerox phaser 8860mfp printer
It is on the side. I'm not sure which side, but the side that all the cords plug in.
Sep 21, 2010 | Xerox Phaser 8860MFP Printer
Xerox Phaser 8860 printer is displaying 12.1 error message, what does that mean
12 codes on that machine mean a software error.
You can try removing and reseating the RAM chips , most likely its corrupted and will require a software install. The software ( Firmware) would be found at xeox.com, Click on drivers and downloads, then type in 8860 in the search box then click to drivers and downloads again and scroll down to firmware.
Jul 09, 2010 | Xerox Phaser 8860MFP Printer
Xerox 8860mfp how do I reset the Maintenance kit counter until a new one arrives
It cannot be reset at all.
Xerox makes you buy a new one, either 108R00675 or 108R00676
Whit
Item, Inc.
Dec 14, 2009 | Xerox Phaser 8560MFP Laser Printer
110 people viewed this question
k24674
jasbo
jasbo
