Question about Tools & Hardware - Others
Schematics paslode 90f 50b
What gauge of nail can be used in this nailer?
rowdy45176
  • 2176 Answers
SOURCE: Paslode framing nailer intermittent firing
OK lets start from the top, gas full, but what is the expiration date, it is located on the bottom of the fuel cell and if out of date can cause a problem. Second when was the last time the tool was taken apart and completely cleaned and serviced with new orings and lube? Lastly look at the nails are they traveling thru the magazine freely? Let me know and I will try and help further
Posted on Jan 11, 2009
  • 4 Answers
SOURCE: paslode 350s nail gun misfire
make sure nails are in correctly, put a battery that is FRESH off the charger in. if this does not work put a NEW gas cartrige in. if still fails read someone else's advice
Posted on Jun 13, 2009
brewerstool
  • 141 Answers
SOURCE: My Sears Craftsman 18 gauge brad nailer won't nail
Your driver is not returning. Depending on the model that you have there could be a couple of problems. The most likely is that your piston stop is crumbled and some of your seals are worn or damaged. Whether or not you can fix the nailer depends on if the parts are available from Sears Parts Dept. If you would like some more information about fixing your nailer please post which model it is that you are trying to fix and I can see if the parts are available. I will post the information back to you.
Posted on Oct 12, 2009
  • 10 Answers
SOURCE: Can I use paslode roundrive nails in a Hitachi NR90GC Gas Nailer
Yes, BUT the paslode Round drive nails and known to cause driver jamms due to the excessive paper used in the spacing of the nails.
Posted on Oct 31, 2009
heatman101
  • 43501 Answers
SOURCE: MY PASLODE NAILER WON'T DRIVE
Check the manual for the adjustment..
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Posted on Mar 06, 2011
I am using senco gas in a paslode 2nd fixing nail gun. Is the senco gas 'bad for' my gun in any way as i am having a few firing problems
You can use most gases in your gun, but paslode is the best that's why its more expensive. Try warming the gases in your pocket that sometimes helps.
Dec 17, 2014 | RTO Paslode 902000 IM250 Ii Cordless 16...
How to open up paslode
Use this link to parts schematic http://www.paslode.co/uploadedFiles/Cordless_16ga_straight_finish_Parts_Diagram_Schematics.pdf
Remove filter cover (1) and filter (2) remove 4 x cap screws (3) then remove top cover (5) disconnect spark plug lead and fan supply led then rotate head anticlockwise and lift it off, slide out front extrusion (56) remove 2 x screws (68) at bottom front of gun (1 each side) remove 4 x screws (80) from left hand housing cover and 1 x screw (59) from left side of handle bracket (83) Note: Do not remove right hand screw from bracket (83) you will now be able to lift the right hand housing and remove it from the groove in the nail channel, the barrel, combustion chamber and nail channel assembly can now be swung up and out of the right hand housing
Jul 01, 2014 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode cordless fires nail but doesn't sink all the way.
The manual give clar instructions on how to adjust this...
heatman101
Mar 04, 2011 | RTO Paslode 902000 IM250 Ii Cordless 16...
I have a paslode 900600 . It cycles but it won't shoot nails.
heatman101
Jan 18, 2011 | BreatheAudio Paslode 900600 Impulse 16...
I am familiar with repairing paslode framing nailers. However, I am perplexed by my current scenario. It seems that the "stop" is not seated correctly. The "stop" is the small metal...
took one apart tonight. I think you have forgotten to put the spring in place that makes the pin go backwards. You can see it in the parts schematic. You can probably see the rub marks on th ein when you look at it.
Dec 15, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
I put in battery green light came on as normal, and strip of nails, gun fired once and light shut off, and will not work at all, what could be the problem? thanks
heatman101
Oct 23, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
MY PASLODE NAILER WON'T DRIVE NAILS ALL THE WAY. THE NAIL ARE RINGED.
heatman101
Sep 12, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
My paslode f 16 nail gun wont fire nails,new gas. it actually fires but nails wo nt eject.
i found this happening to me and i oiled (light oil like 3 in 1) the driver (hammer) in the tip. that way it could retract and drive the next brad.
Jul 30, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
Were can i buy a instruction manual for a paslode
go to Paslode.com and you can download the manual for free. Let me know if you have any problems
Dec 11, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Oct 27, 2009 | Hitachi Tools & Hardware - Others
Tools & Hardware - Others Logo
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
