Question about managemylife.com
Kenmore dryer dryer will only run if you hold the start switch in
  • 4 Answers
The bit the keeps the switch locked is probably broken. You'll have to replace the switch and the dryer should be fine again.
Posted on Jul 24, 2013
Dyer will not turn on. Can hole the starter button in and dryer will run. remove and the dryer will stop running. When holding the start button the dryer does not heat. Any Idea's as to what may be...
broken belt or broken broken belt switch most likely. Open the door. Hold in the door switch and push the start button. Does the drum turn? If it does turn then the broken belt micro switch is where I would look first. If the drum don't turn of course I would replace the broken belt.
The only Kenmore dryer that has a broken belt switch is the 4 wheel drive model. Here is a video which shows how to get into this dryer and replace the belt:
Jul 08, 2011 | Kenmore 63932 Electric Dryer
Press start button and dryshuts off when start button is released
There is a switch assembly on the motor that activates when the motor is running. Centrifugal switch. It keeps it running when you release the switch. That is where to start. Eric
Jun 11, 2009 | Kenmore 74992 Gas Dryer
Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer won't heat and must hold button down
Switch on fan motor not working sw must prove that fan is running! bad motor sw or loose wireing motor sw will by pass start button is released if working!
Jan 04, 2009 | Kenmore Dryers
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Kenmore Elite Dryer only runs if hold Start Switch
sound more like a control board failure // if it has one,, maybe the belt, starting switch
Dec 07, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 73954 : Only runs when the START button is continuously pressed
The start button starts the motor heater and energizes a relay that latches closed to keep the motor and heater running untill the timer switch or door switch cut the power to the relay and the relay opens.
The latching relay has failed or disconnected
if all the cables are attached to the relay
replace relay
not an expensive item, usualoly good for 10years
dryer circuits look like this, the start switch and relay are drawn just to the right of the motor, this diagram has no relevance to the physical position of the parts
Aug 22, 2008 | Kenmore 63942 Dryer
Kenmore Electric Dryer Will not Run
there is a centrifugal switch on the dryer motor. pressing start energizes the start winding and the motor runs. when the motor is up to proper rpm the start switch is supposed to kick out and the motor runs on its run winding.
Sep 21, 2007 | Dryers
managemylife.com Logo
41 people viewed this question
Top managemylife.com Computers & Internet Experts
thinksewfast
Steve
Paul Bade
Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
