Question about Hoover S3765-040 WindTunnel Bagless Canister Vacuum
Hose is there a repair manual for the hose on this kind of vacuum?? it got clogged pretty good and I thought by taking the hose apart there was a place to take the hose out.... I thought wrong and now I have a hundred piece everywhere and no vacuum..
3 Suggested Answers
VacuumRepair
  • 438 Answers
SOURCE: bag was not on good, resulted in dust,dirt, dog
Greetings from GoVacuum,
There are two things that you should check on this vacuum after running it without a bag inside. The first thing you should check is the filter that is underneath of the vacuum bag. This filter is underneath of a bracket, and the bracket can be removed by pulling straight up on the bracket. The bracket and filter are directly below the vacuum bag inside the vacuum bag housing. If the machine was run without a bag (or the bag fell off) then this filter is most likely going to be extremely clogged. You can simly remove the filter, and run it under hot water until clean. Make sure the filter is 100% completely dry before putting it back in the vacuum and using it. Running the vacuum with a wet filter will destroy your motor.
Now in terms of the belts. Where as the belts don't directly control the suction of the vacuum cleaner, they certainly facilitate the pick up of dirt and debris on the floor. Many people assume that since the vacuum is not picking up from the floor, then the vacuum doesn't have suction. You can test this by pulling out the attachment hose and feeling for suction, is there suction at the end of the hose? If yes, then the reason the vacuum is not picking up on the floor is because of the belts. If you don't have suction at the end of the hose, then you have a clog, some where or a dirty filter.
The belts actually are what spin the brush, and the brush basically sweeps the carpet, and throws the dirt and debris into the suction port, and when the dirt and debris are near the suction port, the suction then takes over and takes it to the bag.
There are two belts on this model, it's best to replace both of these belts at the same time. If you replace just one, then the other belt will wear out quicker. It's always best to replace these two belts in conjunction.
The two belts that are used on this vacuum are:
Hoover Windtunnel V-Belt Part 38528034
Hoover Windtunnel Flat Belt, Hoover Part 38528035
Once you have the belts, and you're ready to replace them, here's a great video that we shot here at Govacuum.com that shows you exactly how to replace these belts, as well as some basic maintenance on your roller brush;
I really hope that my repair solution was helpful to you in fixing your vacuum cleaner. If you have any further questions about this repair, or any repair, feel free to contact me at chris.jones@govacuum.com, or request a clarification here on Fixya.
If you did find this repair solution helpful, please kindly rate this repair helpful by clicking the 4 Thumbs Up Icons in the top right hand corner of this solution.
Thank you very much,
Chris Jones
GoVacuum.com
Posted on Mar 19, 2010
dbqsaints
SOURCE: Hoover Steamvac hose won't spray water
SOLUTION#1 If the attachment wont spray water, the white plastic nozzle tip may be clogged. Take the brush attachment off, remove the two screws from the gray retaining cover (BE CAREFUL THE WHITE TIP UNDER THE BLACK PLASTIC TRIGGER MECHANISM IS SPRING LOADED and WILL GO FLYING). The trigger mechanism can be taken apart by lifting the black part off (may have to slide it back slightly), remove the spring from the white plastic valve insert, then take a flat screw driver and carefully pry the two white pieces apart and blow out both ends. You may have to find a hair size piece of wire to push threw it to clear it. The whole process is really simple once you take it apart and see how it works. Putting it together is in reverse order. The white piece will only go in to the black part one way and with the spring on you need to push it through the hole and the trigger part hooks on, slide it back on to the hose, then while holding it all, and put the gray retaining cover back on. Sounds more difficult than it really is. If your not mechanically inclined take some pictures as your taking it apart to refer to.
Solution#2 If the nozzle and trigger are clear, with the trigger assembly off the hose, plug the hose into the shampooer and turn it on (if the hose inside the suction hose is clear you should start seeing water flowing out the hose. If not run a piece of wire through that hose to unclog it. If its still not flowing then the Pump on the unit needs to be replaced.
Solution #3Cost Around $20 with shipping online. Google your make and model, and upholstery attachemnt pump. Mine was called AP4561692 (43582018) PUMP ASSM, from http://www.appliancepartspros.com/. (there real good about the live chat and helping you find the part).There are Youtube videos on taking apart the shampooer, which is pretty easy. The one place that might give you problems after you get down to taking the pump off, there is only one screw holding but there is on the bottom side of the pump a black bump that clips in to the base of the shampooer and you need to stick a screw driver from the bottom up and pry the base one way and pull the pump the other to unhook it.
Posted on Feb 16, 2012
No suction
the hose can clog up insid where you cant see it my husband takes it off and runs water thru it to flush stuff out lets it dry then reconnects it
Sep 18, 2012 | Dirt Devil Featherlite Bagless Vacuum...
Lost suction but no cloggs in line
see the solution; God bless you
How to determine a clog in your hose
Take your central vacuum hose and connect it directly to the dirt canister. After turning on the vacuum if the hose has normal suction here then the clog exists in your tubing.
Click here for help with tubing clogs. But, if you experience reduced suction at the canister then your hose is clogged. See Solutions below.
check.gifPlug hose in reverse into the inlet located on your unit and turn on the system. This should aspirate the clog out.
check.gifOr, remove the hose from the inlet and push a garden hose through hose to push out the clog. Most importantly, the garden hose must be turned off and there should be absolutely no water entering your vacuum hose.
check.gifOr, remove the hose from inlet and drop in a heavy object such as a screwdriver to push out clog.
Jul 23, 2012 | Broan-NuTone VX475 Bagged Central System...
Bissell 8920/9500 ProHeat 2X The Floor Cleaner base doesnt spray any liquid. I would take the base apart(and possibly trigger assembly), but the manual does not cover disassembly and assmbly of the tubes...
I just repaired my Bissell 8960 no spray from the base or the flex hose nozzel. Tried to find a diagram or service manual online but no luck. I removed the 2 jets that spray on the brushes and
there was small pieces of silt that would plug them up. only used this unit twice before but it's been
sitting in the basement for a year. anyways ending up takeing the unit all apart. All of the items you
need to get to are in the base not in the handle sections (except of course the spray switch) I put the whole thing on my large work bench to make it easier to work on. If you do take it apart make sure to take alot of pictures or you may not get it back together again. I labeled the hoses with different colored tape and was glad I did.The main problem was the 700 watt heater that is in the very bottom of the base. it was filled with white specs of silt. the heater can be removed and opened up so you can wash it out with a water and a brush. We have city water here thats supposed to be pretty good but know I know why the wife uses distilled water in her iron. Thats what I will be useing from now on in the Bissell..
Apr 05, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a bissell lift off revalution pet 6860-h and its not picking up very good i think the house could be plugged but I dont know how to take it apart to be able to get to where it is plugged at
First unplug vacuum and remove the dirt container. Remove the upper tank and check for clogs at the inlet at the top. Feel inside the hose from there, as the bend is a common place for fluff and debris build-up. If the clog is here, remove what you can, replace the tank and container, and turn it on. Anything left may get sucked on inside.
If not, hold the hose grip at the powerhead end firmly and pull up.
Check the powerhead passage first. Any clog here can be pushed back through with a wooden spoon handle or similar object.
Turn the vacuum on to check for suction at the end of the hose. If none, drop a marble or coin into the end of the hose and lift so it drops into the dirt cup. If it doesn't, there's definitely a clog in the hose. You should be able to clear it by using a broom handle to push it through to the tank.
See pages 11-12 of the manual if these don't help.
Here's where to get a copy of the manual if you need it.
http://www.bissell.com/assets/0/132/134/228/c5ec572a-8f1e-4ff8-bbbd-5314b7582140.pdf
Mar 05, 2011 | Bissell Vacuums
My rather old cannister vac has something clogging the hose. Any ideas on how to clean it out ?
Attach hose to exhaust port of canister. Switch on. That may be enough to blow out the clog. If not, place wand end of hose to intake of vacuum so you have both ends "attached to the vacuum. This should do it. If not, you might try using something with greater suction. Like taking it a nearby carwash and using a vacuum there. Try placing "wand end" of hose to other hose first and turn in. Then the other end.
You can try pushing a long length of PVC or similar pipe through. No jamming. Care needs to be taken when doing this as it may cram the clog tighter,
If the hose is rather old as well, it may be a good idea to simply replace it. It likely has multiple leaks and great loss of suction.
Sep 05, 2010 | Electrolux Central Vacuum
No suction in the hose/attachments
It sounds like to me that you probably have a clog in the hose port, or that your attachment hose may have a hole in it. Both of these problems are common problems on the Dyson DC07 model.
The first place you should check is the clog part that's directly underneath of the hose. Pull this port out and see if you can see anything lodged inside the clog port:
If you aren't able to find the clog here, then pull the wand and hose out of the vacuum. With the vacuum cleaner off, pull the hose out as far as it goes, and inspect the entire hose assembly from the end that the wand connects into, until the end that fits into the vacuum itself. A lot of times this hose will tear due to the sharp end of the wand as the hose is being pushed back up the wand.
If neither of these solutions worked, please just use the clarification request form here on the Fixya repair page, and I'd be happy to do some more advanced diagnosing with you to figure this out.
If this was helpful to you, please help other Fixya users find this answer by rating the repair helpful, by clicking the thumbs up icons in the top right hand corner of the repair.
Chris J.
GoVacuum
Apr 11, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Disassemble electrolux olympia one vacuum.
Four nuts in rear housing, deep inside. Motor slides out after they are removed.
Jan 17, 2010 | Electrolux Vacuums
Jun 16, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Suction
hello tnwalkergal the hose may have a clog inside the hose at the bend you can take the hose loose and run a broomstick or a yardstick thorgh the hose this is how I find the clog
Jan 24, 2009 | Dirt Devil M086700 Vision Bagless Upright...
Model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kenmore 22313 Bagged Canister Vacuum
Hoover S3765-040 WindTunnel Bagless Canister Vacuum Logo
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
