Question about Sharp AR-M450N Copier
Toner sensor reset
Se puede resetear el chip de la ARM 450
4 Suggested Answers
shaggyrat
  • 1224 Answers
SOURCE: Encendido del LC-32GA5U
no abla espanol this is america translate your question first
Posted on May 13, 2008
milkburp
  • 416 Answers
SOURCE: no se si hablan espanol pero mi tv no tuvo ni un
You could replace the TV for less than it would cost to replace the LCD panel. Sorry, Sony will not repair this damage for you, it is classified as abuse. :(
Posted on Mar 13, 2010
gopakumarg43
  • 74136 Answers
SOURCE: Como desbloquear mi televisor marca sharp xflat stil?? No tengo control... se puede hacer sin el control original?
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites Check this site too.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
Posted on Jan 12, 2016
Se enciende la luz del tablero marcada conel 5
No es muy claro; estoy adivinando. Si este es el esquema de su tablero de instrumentos...
El indicador numero "5" se refiere al sensor de presion de los neumaticos.
Esta luz se enciende cuando hay un neumatico bajo condicion de presion . La luz tambien se encendera si existe algun problema con un sensor del neumatico . La luz permanecera encendida hasta que la presion de los neumaticos es correcta o el problema con el sensor se corrige .Esta luz se encendera momentaneamente como una comprobacion de la bombilla cuandose arranca el motor .Cuando el Monitor de Presion de los Neumaticos Light Warning esta iluminado, uno o mas de tus llantas estan considerablemente desinfladas Usted debe detenerse y revisar la llanta lo antes posible ,para inflarla hasta obtener la presion correcta, como se indica en los neumaticos (cartel de informacion del vehiculo). La Ccnduccion con neumaticos no significativamente inflados lo insuficiente hace que el neumatico se sobrecaliente y puede conducir a la rotura del neumatico.
Las llantas desinfladas tambien reduce la eficiencia del combustible y la vida de la banda de rodadura de los neumaticos, y puede afectar el manejo del vehiculo y capacidad de frenado. Cada llanta,incluyendo el de repuesto , se debe revisar mensualmente cuando frio y ajustado a la presion de inflado recomendada como especificada en la etiqueta del vehiculo.
Suerte.
Nov 15, 2013 | 2005 Jeep Liberty
BANDA DE UNOS 4 CENTIMETROS EN LA QUE SALE MAS CLARO O NO IMPRIME.
  • Puede ser que el cartucho de toner se esta quedando vacio ( en este caso sacalo de la impresora y movelo un poco hacia los costados, insertalo en la maquina), tambien fijate si el rodillo de revelacion del cartucho tiene toner en toda la superficie.
  • Otro problema puede ser que el laser no se proyecte en el tambor de imagen (para este caso chequea que nada obstruya el paso del mismo)
  • Y por ultimo el Laser, estan sucios o empañados los espejos del mismo (limpiar con un trapo seco que no deje residuos).
Sep 07, 2011 | Xerox Office Equipment & Supplies
1992 Daihatsu Rocky O2 sensor light on even after replacement of O2 sensor before 80,000 miles. Brake and Battery lights on after replacement of Alternator. Have checked the charging and the braking...
I have a Daihatsu rocky I'm working on with the same thing going on with the o2s light. Staying on .. 88k miles on a 1990 1.69l .. If you find how to turn it off wright me
Jun 09, 2011 | 1992 Daihatsu Rocky
Tengo una pantalla de 37 de tft samsung a la que conecto la ps3 por hdmi hasta hora sim problemas hoy la he conectado y me sale modo no compatible que es lo que puede pasar,e probado la ps3 en otra...
Puede ser que se haya desconfigurado el ps3, en caso de que sea este el problema, no desesperes que la soluci?n es muy f?cil. Conecta tu ps3 a tu tv a trav?s del cable hdmi, ahora, cuando enciendas la consola, deja oprimido el bot?n de encendido por unos 5 segundos, esto resetear? la configuraci?n de video de la consola y esta se ajustar? autom?ticamente a tu tv, presiona (X) cuando la interface te lo indique. Si esto no lo soluciona, y la consola funciona en otros tvs, es otra la situaci?n y es probable que tu tv este fallando.
May 05, 2011 | Sony Playstation 3 (PS3) Console
Se puede resetear el contador de los tambores de la oki c3400n
Trata esto:
When installing the C3400n printer, or when replacing the toner cartridge, be sure to fully insert the toner cartridge into the image drum, and make sure the blue lever is pushed ALL THE WAY toward the back of the printer (fully locked position). If it is not fully closed (locked), a "toner sensor" or "toner empty" message may result. Note: (Picture at bottom shows incorrect position of locked toner cartridge that may result in either of these messages).
Installation Procedure of Image Drum and Toner Cartridge:
          0.408?openelement&fieldelemformat=gif
    >> Insure the toner is fully locked, see photo below showing the correct and incorrect positions of the locked toner cartridge.
CORRECT (Fully rotated to lock position)
    91.28a2?openelement&fieldelemformat=gif
INCORRECT (Not fully rotated to lock position)
179.32a2?openelement&fieldelemformat=gif
Dec 01, 2010 | OKI C3400n Laser Printer
Mi pc PCChips Con la placa madre m955g v3.0 reconoce Enciende discoteca El duro y sí Apaga Que servicios PUEDE , Como lo soluciono , gracias
hola a todos tengo un problema con mi c.p.u.... ella tiene una tarjeta madre M955G V3.0 a Y es una pc chips,,, bueno la primera falla que presento fue que no ensendia.. le limpie la ram y nada hasta q le quite el junper de la bios para resetear.. y desde alli encendio la pc pero ahora no me reconoce el DISCO DURO NI LA UNIDAD DE DVD... SI ME AYUDAN SE LO AGRADESCO
Sep 17, 2010 | PC Chips M955G Motherboard
I have always error code 546 and 960
Error Code SC 546 is for fusing & SC 960 is for Current leakage, If u getting it regurally , change the thermistors for error code 546, & for error 960 change drum & charge roller.
Aug 16, 2009 | Ricoh Aficio 450 Copier
Service code 990 savin 2545 copier
If changing the cylinder, developer and blade the problem is not solved, proves to resetear software pressing by more than 10 seconds the point (.) and the numeral (#) both simultaneously, until it is extinguished and it returned to ignite the machine, this resetea software. If the problem persists, then the problem can be in the hard disk, replaces hard Disk.
Si cambiando el cilindro, revelador y cuchilla no se soluciona el problema, prueba resetear el software presionando por más de 10 segundos el punto (.) y el numeral (#) los dos a la vez, hasta que se apague y vuelva a encender la máquina, esto resetea el software. Si persiste el problema, entonces el problema puede estar en el disco duro, reemplace el Disco duro.
Aug 03, 2009 | Ricoh Aficio 450 Copier
Necesito resetear la motherboard
Hola,
Bueno, lo unico que puedes resetear el el BIOS. Hay tres maneras de hacerlo.
  1. Prende la computadora, entra al BIOS y escoje "load defaults"
  2. Sacar la bateria redonda de la placa madre
  3. cerca de la bateria por lo general hay un "jumper" para cruzar dos patitas y resetear el BIOS
Aug 03, 2009 | Foxconn 6627MA-RS2H Motherboard
Sharp AR-M450N Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
