TOSHIBA 37AV555D HI HAVE A TOSHIBA 37AV555D THAT WHEN I TURN IT ON I GET A RED STANDBY LIGHT THEN GOE'S TO GREEN AND THEN BACK TO RED .I HAVE LOOKED AT THE PSU AND SEE NO BAD CAPS .
SOURCE: Planar PDP42BK Plasma TV
It is the power supply. Replace the C97, C19, and C16 Capacitors with 2.2 uF ones.
Posted on Oct 03, 2007
SOURCE: Does not turn on.
i had my power supply blow on mine within the first year took it in because i had extended warranty and they fixed it, only problem was finding a dealer in my area to fix it, then took over a week, because of customer support issues
Posted on Nov 04, 2007
  • 41 Answers
SOURCE: wont turn on red light flashes
The error code of 2x red flashes tells me you need a Y DRIVE ASSY and the part number is AWZ6649. It should be replaced by a Technician thou.
Hope this hleps
Posted on Mar 30, 2009
SOURCE: WONT TURN ON
Most likely, the problem is a defective Main Processor Board. This is the board with the antenna, RCA and HDMI plugs. You cant repair or replace component parts on this board, so dont even try. You must replace the complete board. The TV says Sylvania, but it is a bloody Funia TV. Several years ago this foreign company bought out broke-azzz Sylvania . They are still carrying the Sylvania name since Sylvania was a popular TV name in the 70s. Every electronic company in the USA is now owned by the Chinese, so call Funai and order the part from them. Dont be surprise if they dont have a clue what the heck you asking for. America and all electronics have gone to the puddles. Do you know why? GREED.
Posted on Jun 10, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: There was a power surge and a loud pop and now the
A job for the technician on this one. I have only worked on several flat screen before, on my last days as an electronic technicians. Half of the ones I worked on was the power supply inside ir the problem was like this. Instruction on how to fix them would require me to write many pages on electronic theory so, I am very sorry It is almost impossible for me to help you on that. Be carefull where you take that tv to. some shop can't fix those. You may have to search your local area for someone who specialize in flat sreen HDTV. Well I hope I have shed a little light on the problem. Thanx for posting the problem.
Posted on Jun 29, 2009
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 | Freezers
Toshiba TV won't turn on
Toshiba? Suspect that if it uses a Lamp for brightness (a model number would help) it may have failed----customer replaceable and if remove look to see it is not shattered inside--2 year, 2000 hour life is normal.
Oct 29, 2012 | Sony Televison & Video
My p315 speaker stays on standby and won't power up?
some design need audio signal in to get it wake up from standby mode.
Oct 25, 2012 | Acoustic Research P315 HO Speaker
Power light is green than goes red
Hi beinhauert,
The symptoms you've mentioned indicated that the unit turned to standby mode. This is an indication that there's something wrong on the TV. To help us narrow down where the fault came from, please access the built in "Self diagnostic Screen". Follow the steps below.
In standby mode (red light is on), press the button on the remote control in sequence "Display", "5", "Volume (-)", "Power". Self diagnostic screen's displays its log of error. Please let me know the error code with corresponding numerical value "1" means error has been detected, "0" means no error.
Jdvillanueva
Jan 06, 2012 | Sony Grand WEGA KDF-60WF655 60" Rear...
Our 60sdx took an electrical hit, and now, when we turn it on it goes to protection mode. What do we do?
All of this involves some testing:
I would remove back cover and look at the several green LED's on the board and the red one as well.
The red one should be lit and the green ones should light when set is turned on; primitive self check as each green one is tied to a voltage in the set's internal power supply.
Usually when an electrical hit parts at the in to the power supply get taken out.
Got a red led lit on the board?
This like all sets has standby power supply built into it: some sources are active 7/24 even if set is off and they usually take the hit.
Not knowing if you have a voltmeter and or know how to check I would suggest look at the led lights on the board.
Before you rate this information LET ME KNOW WHAT YOU FIND.
Sd Tech
Aug 16, 2011 | Hitachi 60SDX88B 60" Rear Projection...
When you turn it on, the green LAMP light goes on, then it clicks and the STANDBY/TEMP red light goes on, then clicks and back to the green LAMP light. It does this a few times, then The TIMER green light...
Usually if all 3 indicator lights come on this could be the color wheel is not functioning or the DINe chip needs to be re-soldered. Be sure the lamp door is closed all the way, but the color wheel needs to be looked at first.
http://tvtechwork.webs.com/
Nov 17, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Bright green picture
defective green picture tube crt. suggest local service center
Nov 09, 2009 | Toshiba 65HX83 65" Rear Projection...
My t v will turn on, the light will be Red, then Green ,then
your tv in protection mode some thing wrong inside tv.mostly power card defective.
Jun 28, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Can't get full power on
I have this exact same issue; search engine took me here. I have been experiencing this problem for about a year now. When you power on, the RED standby light goes out, the power light turned GREEN, you might hear a small pop sound, then the RED standby light goes back on. YOU HAVE BLOWN A FUSE. My problem is this is occuring much more frequently now and I'm going through fused like crazy. So I'm looking for a long term solution. To replace the fuse, turn off the standby power switch on the front. Unplug the power cable. Open the back panel. All logic and power modules are on the bottom of the cabinet. Therer is a large power module in the middle. In the middle of this module are 3 fuses. The one that typically blows is the one in the middle. It's a 5 amp fuse, but double check the rating before replacing. Good luck, Mark
Aug 05, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
