Question about Philips Audio Players & Recorders
Foot pedal not working - Philips Audio Players & Recorders
My foot pedal doesn't work.
Have you tried using a new foot pedal? I think it would be worth the the money because moving parts tend to go bad before internal stationary ones. Amazon com Singer Sewing Machine Foot Pedal Everything Else
Apr 22, 2016 | Sewing Machines
Foot pedal isn't working
if the foot pedal is plugged in correctly, you may need to replace the foot pedal or have the plug that the foot pedal plugs into checked
Feb 29, 2016 | PfaFF Sewing Machines
My Olympus RS25 foot switch stopped working.
Yes, you can assume that after 6+ years, the pedals have gone bad and you need new ones.
Jan 08, 2016 | Olympus AS-2300 PC Transcription Kit
Toyota sewing machine foot pedal unresponsive then goes really fast.
Try to get another foot pedal. If that works then replace.
Oct 08, 2012 | Toyota Sewing Machines
yes, it is possible that the foot pedal can go out,, it would be a good
idea to have the foot pedal checked at a repair shop to see for
sure
Aug 27, 2012 | PfaFF Tiptronic 2040
Foot pedal doesn't work
well if the foot pedal isn't working, you can either replace it with a new one or take the machine to a sewing machine repair shop & let them check the foot pedal & see if it's fixable
Mar 14, 2012 | Husqvarna Sewing Machines
You may need a new foot pedal. Find a small applicance repair shop and ask them if they can test the pedal. Take the machine with you.
Mar 09, 2010 | Husqvarna Designer I
I am a transcriptionist who is remotely accessing a work computer
I looked a the Infinity IN-USB-1 foot pedal, thanks. I would go out and buy a second foot pedal for home then you can remote your work pc by using the foot pedal from home. Make sure you install the drivers for the foot pedal at your home pc. If this doesnt work, you can always take the pedal back to the store. I figure that If you took away your mouse from your home pc, you could not move your mouse on the work pc. It maybe the same with the pedal. Let me know if it works.
WBTech
Jan 19, 2010 | Computers & Internet
I have a 720. Sometimes when I press play it will rewind.
Hello I can read your full problem but when it hapen unplug your foot pedal to see if the pedal is causing the problem here is a link for a original foot control replacement http://www.tvps.com/Products/Philips-LFH-0210-Foot-Pedal---New__PH-LFH-0210.aspx or just send your unit for service at Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Jun 15, 2009 | Philips Desktop 720-T Desktop Cassette...
Foot pedal FF or Rewinds when pressing Play
It's possible that there's a broken wire in the cable that connects the foot control to the machine. This usually happens near the plug that plugs into the machine, or by the end that goes into the foot control.
You can usually duplicate it if you put the auto-backspace up a bit and then hold down the play pedal on the foot control. While holding down the play pedal, try moving the cable near the machine or near the foot control in a circular motion. If the machine stops, rewinds or fast forwards, then odds are that the problem is with the cable.
Mar 13, 2009 | Dictaphone 3750 Desktop Cassette...
22 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
