Question about Water Heaters
Main 24he not firing up
The boiler wont light its got ignition, but wont firer, have noticed both pins come out on the diverter valve, when it trys to go.
SOURCE: lw 50 ci boiler wont fire up
Found out there was a short on the ignation thanks
Posted on Nov 20, 2008
  • 659 Answers
SOURCE: hot water boiler will not ignite
Check all your limit switches on this unit. One of them is either tripped or bad.
Posted on Apr 07, 2009
  • 150 Answers
SOURCE: heatslave diverter valve
clicking rads are due to pipe expansion when getting hot.
If the hot water [secondary circuit] gets hot and the boiler stays on [does not keep going on and off] even with a constant low water flow then the diverter should be ok.
there is a valve to prevent the primary circuit [central heating] [ CH] from sending water to the rads. this or its control may be at fault.
both the
Both the CH pipes to & from the boiler should have manual valves to turn off. do this then try the hot tap-full on. If the boiler goes into overheat mode and the overheat stat kicks in to turn the boiler off -- then :-
Check also the heat exchanger, it may be furred up especially if you are in a hard water area. It means taking it off and manually checking [pour water through] If you're lucky it will be just muck to be forced out with hose pipe pressure, if not a new one
Posted on Sep 06, 2009
  • 17 Answers
SOURCE: Combi boiler (vailant), pilot light not igniting;
hi there
does the fan start up?
sounds like a faulty gas valve. has there been an interuption in your gas supplie?
hope this steers you in the right direction
Posted on Dec 19, 2010
Testimonial: "The feedback is very helpfull. Kind Regards Tracey"
SOURCE: I have a HEAT MAKER
Check the flow switch. Small black box lower left hand side as you face the from of the unit. Try to jump the connection and then see if it fires up. If it does, replace your flow switch. The flow switch prevent the boiler from firing because it is not sensing the water moving through the pipes. The boiler won't fire if water is not moving through it.
Craig @ Aggie Plumbing & Service
Posted on Jan 14, 2011
I HAVE WORCESTER 24SI BOILER , THE HEATING IS WORKING BUT NO HOT WATER THANKS.
Hi Mustafa, you are going to need a Gas Engineer to fix this one. It could either be the Hot water sensor or the flow switch that activates the water to come on. Good Luck.
Jan 03, 2015 | Water Water Heaters
Baxi boiler no water in hot water taps
If no hot water it is the diverter valve in the boiler. If no cold water the tap in the mains water supply to the boiler may be turned off
Apr 19, 2014 | Water Heaters
How do i fix problem E119 on a baxi duotec combi 24HE - boiler won't light because of lack of pressure but I have no manual to assist me as the instructions on the boiler says.
http://www.bhl.co.uk/uploads/article1477/Baxi%20Duotec%20HE%20Combi%20Boilers%2024,28,33,40%20Installation%20Instructions.pdf top the pressure by the filling loop
Jan 23, 2011 | Water Heaters
Vaillant echoplus 837, leaking diverter valve
Replace valve or if it has the usual diaphragm inside remove valve and replace washer/diaphragm
To prevent water draining from the whole system, turn off the taps on the heating pipes located just below the boiler AND the cold mains inlet
Mar 08, 2010 | Long Life Water Heaters
Hot water wont fire up when hot tap is turned on . but firing up for radiators ok
Check the diverter valve is operating when hot is on demand. Depending on the boiler [valve types differ] most have a small piston [biro refill diameter] protruding which operates an electrical switch/contact.
replace switch.if valve piston works but not the switch OR it piston not working
replace valve [or diaphragm inside]
Nov 15, 2009 | Water Heaters
Britony boiler problem
check diaphrapm chageover valve
Oct 30, 2009 | Water Heaters
Alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
Aug 21, 2009 | Water Heaters
Worcester 24i combi when in shower hot water flicks on and off can hear gas igniting and extinguishing
This is lack of water flow through the diverter valve.
First have you got a good flow from any cold tap? If yes then see below
If I remember there is a pipe carrying cold mains crossing the lower front of the boiler with an in line filter usually clogged. Remove clean & replace
check also any filter in rising mains to boiler
another cause is the diverter valve itself - diaphram inside may be punctured/split
Aug 06, 2009 | Ultra Max Takagi Flash TH-1 Ultra High...
Combi boiler no DHW
if the boiler fires when the tap is opened then the diverter valve is working ok it must be a blocked plate heat exchanger which is the stainless steel rectangular block inside the boiler connected to the pump and the mains cold water.
it will be blocked on the central heating part probably with black scale. it is possible to clean out but sometimes it is better to just change the plate. but remember to flush the system as well or the same thing will happen.
Dec 14, 2008 | Water Heaters
Water Heaters Logo
18 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
