Am having error 732-8888 on my photocopier ir 5185 after restarting
2 Suggested Answers
  • 199 Answers
SOURCE: canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
Posted on Feb 26, 2009
E003 Error code in canon ir2420 photocopier
Code E003-0000 Description Abnormally low temperature (detected by main thermistor)
After the temperature detected by the main thermistor has reached the specified value, it does not reach the specified value during initial rotation. Remedy - Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the DC controller PCB. Error Codes Canon iR2420 Code E003 0000
Oct 28, 2015 | Canon Office Equipment & Supplies
How can i solve the problem of System error E100 in a Canon iR 1020 photocopier?
You should have a PDF Owner's manual on the software install disk. Troubleshooting section should say what the error is and what to do to fix. Or try this:
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Canon&model=iR1020
Apr 02, 2015 | Canon Office Equipment & Supplies
How do i fix Error E007 on Canon IR 2016j?
Dear
Replace the fixing film assembly or fixing film.
Thanks.
Mar 15, 2015 | Canon Office Equipment & Supplies
How do i clear error e000007-0000 on a canon ir 2200 photocopier
Fixing film assembly may need to be replaced if error cannot be cleared. Fixing error codes should be reset by a professional only. Fuser assembly must be examined before resetting the E000, E001, E003 and E007 codes. Enter the service mode this way: Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again. Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here your tech can reset the error codes. Then turn machine off & on again.
Sep 04, 2014 | Canon Cannon Ir 2022 Photocopier
HOW CAN I SOLVE ERROR CODE E000007 0001 IRC 5185
Fixing belt home position detection error.
Replace Home Position sensor - 0,001%
Replace the Fixing unit - 105,9%
Feb 11, 2013 | Canon irc5185i
I am getting this error code message e000020-0000 on my canon ir2870 do you know what it is and how i can fix it
my canon ir 2270 photocopy machine k panel m baar comp. hone ko hota h. phir s restart ho jati h, kya problem hogi sir g
Apr 26, 2012 | Canon Office Equipment & Supplies
Ir 1600 photocopy there is error= e000 .solve it
go to service mode by pressing(additional function - ID) GO TO PRINTER OPTION PRESS OK GOTO PRINTER RESET PRESS OK PRESS LEFT ARROW KEY. WAIT AND RESTART THE KEY. CHECK YOUR MAIN POWER SUPPLY MAINLY COMES BECAUSE OF IT.
Jan 15, 2011 | Office Equipment & Supplies
102 people viewed this question
k24674
